Visitor Agreement.
I have noticed the exact same thing mentioned above with respect to the window clicking noise on the driver's side. Mine only seems to do this when it is really hot outside. I mentioned it to the dealer and he said it might be just an adjustment. Wasn't hot that day so I couldn't duplicate it for him. It seems to me that the window is not correctly aligned. One thing to consider. The dealer told me to address this problem with them before 12,000 miles as Nissan will not pay for any "adjustments" after 12K. Would like to hear some more feedback regarding this.
Good luck!!!
I have 10,700 miles on my PF..so if that 12,000 rule mentioned above this post is true...guess I better get it done asap.
I've never owned a brand of car that within the 3yr/36K or 5yr/60K warranty didn't cover any type of malfunction, problem or issue other than routine maintenance. Having a window that clicks isn't routine or maintenance. Eventually your clicking window will 1.) burn out the motor, 2.) cause an electrical problem. If Nissan actually misrepresents it's policies to save a buck or two and screws their customers with small issues like window clicks, then i don't think i'll be a return customer.
Unless Nissan defines minor adjustments to include switch and electrical problems i can't see it not be covered under warranty. I'd call NMAC and ask them to define "rountine maintenance" and "adjustments". If you find anything out could you post it on this site.
Sorry so long,
S-66
The Pathfinder had a damaged/scratched mirror when i bought it and the dealer said they would replace. Well i've had my Path in there 3 times now to have it replaced, and still don't have a new mirror. They've ordered the wrong mirror 3 times (apparently Nissan has the wrong part numbers listed in the parts book) and finally after getting the correct mirror painted they lost it somewhere between the body shop and the service dept. Now it's not that i don't understand the parts numbers causing an issue, but the service dept continunally tells me they have the right part and to leave my Pathfinder for the day to be fixed. Well after the 3rd time of being without my new Path for the day getting it back with the same scratched mirror, you can understand my frustration.
Also since i bought my truck, they've fired the saleman that sold it to me and the service manager in charge of fixing my Pathfinder has resigned. Kinda makes you wonder what kinda place it is. They also screwed me out of the $1500 dealer cash and financing by lying to me when i asked whether any incentives were coming up. They said no there aren't any even though it was starting on August 1st (i bought mine on July 31st).
Now don't get me wrong, i love my Pathfinder LE and think it's a great vehicle, but you really have to wonder about the dealerships and service these days.
Just my $.02,
S-66
I guess I mis-wrote.
My windows were not having a switch problem; they were making a "cracking" noise after I would roll them up similar to that of the "cracking" noise my wife's Accord made a few months before the driver's-side window wouldn't stay all the way up any more (that one cost $300 parts & labor).
I asked them to fix it, specifically stating that I thought it was under warranty. They said that the window needed a "track adjustment" or something and proceeded to charge me for 1/2 hour of labor, even though "it actually took the technician 45 minutes--so I'm cutting you a deal." Thanks for the $37.50 window adjustment "deal".
On a positive note, that was a couple of months ago and the window hasn't started making the noise again, yet.
I only use the dealer for 15,000-mile interval services and I keep the receipts from the rest of the oil changes. In my past dealings with Nissan service, this was good enough proof to keep from voiding the warranty. Otherwise, I hate working with Nissan service...with the exception of 2 dealerships in Texas: Robbins Nissan in Houston and Courtesy Nissan in Dallas. I still prefer my local mechanic.
-Jon
system is build by Clarion. Some one back several messages (100-200) installed very nice speakers on the pillar and in the doors. Even installed a amp and sub- woofer. He said it work very well.
I haven't been here in a while and it's good to see that the board is still going strong. I just hit the 15,000 mile mark and I'm taking my PF (2001 SE) in for it's scheduled maintenance. No problems yet except that the driver side window rises very slowly. Going to have the service people look at it and It by tootin better be covered. Other than that, I love it. Unfortunately so does my fiancee, so I don't get to drive it as much as I'd like. Please post any updates on trying to get those windows fixed....
Cheers.
Also - I've noticed significant humidity comming from the vents after the A/C is turned off and the vent is still on. I've tried warming the air temp to ambient prior to A/C shutoff and this helps a bit. Never had these issues with my Accord.
Anyone else notice this? How about those with climate control? Is this system broken of just poorly designed?
so, if someone said the stereo sounds bad at high volumes, would that mean my best bet is to get some speakers? and maybe an amp since my current stereo seems to have a pre-determined cutoff level?
For those that just want to improve the sound of their Bose system without major surgery a good start would be to upgrade the puny tweeters in the A pillars. Each is 4 ohms with a 3.3uf cap which results in a high pass crossover point of approximately 12khz. (This is the frequency to warn away bats and torment the neighborhood dogs.) This means that most of the musical information is coming from the door speakers and the tweeters' only function is add a little zzzzt to bring the soundstage up a bit. I ran test tones through these tweets and they just flat out sounded terrible.
I replaced the tweeters with leftover MB Quart tweeters from a previous install. They are rated at 50 watts at 7 ohms. I added a 10uf cap which results in a highpass crossover point of about 2.3khz. This then brings the upper midrange frequencies higher up in the soundstage area and because these tweeters are "better" than stock, the music becomes more clearer and sharper.
I have no problem with the door speakers so I left them alone.
I added a 400 watt amp and a 12 inch subwoofer back in the hatch to dry my hair.
I have read about the last 100 posts and have solidified my views on buying an '01 SE PF. The buy on this is a tad steep, but the dealer is offering a lease option and I need an opinion...
Based on a sale price at invoice of $26788
$444 at signing..(1st month,fees,title)
$379/mo @ 39 months
$14450 buyout
that is a .00139 money factor(3.34%)
Also was wondering like others if the APR might drop to 0.9%/60 months after Labor Day.
Might be able to swing that 1
thx
Mark
5 weeks ago I BOUGHT an American 01 PF SE with mats,micro,cargo net (what a joke) with 17 miles on it for $25,560 plus TTL.
Please enlighten my ignorant mind on the benefits of leasing.
Do-It-Yourself Guide to Leasing
Steve
My parents like to drive new cars. They budget the monthly car payment as a "utility bill" and never look forward to the day when they "won't have a car payment." So they lease based on what they can afford, and what their needs are at the time of trade-in.
I bet your monthly payments are higher than that lease, I'd guess your payments are over $400 on a 5-year loan, and I doubt you got away with putting only $444 down.
A smart way to work any car-buying deal is to first negotiate the purchase price. Never let the sales guys get you to discuss the "monthly" payment before you work out the purchase price. That's how they sucker you into buying something you don't need. Once you've nailed the purchase price, then talk about the financing or lease. Walk away if you don't get what you're looking for. Another dealer will be more than happy to get your business.
Am on the verge of buying a 2001 4x4 LE, fully loaded except nav and entertainment systems. Dealers seem willing to deal. Best offer so far is 31500 then after rebate of 1500 my price is 30000, invoice is 31600 according to Edmunds or 32000 according to the dealer. Anybody else shopping or just bought who can tell me if this is a good price in the current market. I saw one person got one for $1000 under invoice, but need more specifics, sometimes the dealer will do this but keep the rebate to himself.
Dealers of course are emphasizing purchase today, last day of the month. As this is my first auto purchase, does anyone have any input as to whether rebates will get even better after Sept 4th when the current promo ends. I saw someone post the possibility of 0.9% APR for 60 months. The dealer I am working with has a lot of these to move!
Thanks for any help/advice.
Tony
just wanted to let you know that in the October issue of Motor Trend there is a advertisement for the 2002 Pathfinder and it looks the same as the 2001 except for new wheels, a new steering wheel (the one from the 2002 Altima) and I think a new navigation system.
Always drive a new vehicle,
Most always under warranty.
Can be sold just bought from the lease company for a payoff value just like any loan.
(Just a few positives.)
Never owning a vehicle,
over the mileage penalty,
always having a payment.
(Just a few negatives.)
1) How does this vehicle do in the rain when in 2WD mode? I'm thinking of wet, looping, freeway onramps. Does the back end want to come up to see what the front end is doing? (Obviously I'm thinking of just the usual drizzle, not a hydroplane situation.) Or do you just keep it in 4Hi between November and May? Any tire recommendations?
2) My wife is pushing for leather (and thus LE). I never liked leather in the NW - felt clammy in the morning, didn't dry as quickly, etc. Any opinions?
Thanks in advance. I've read every message on here (the most recent 3500 anyway) and this is a great board.
I've been lurking here for a while, and I am ready to buy a Pathfinder LE. I need some help.
1)I have read posts on this board about buying in Canada, but I can't find detailed info in one place except for the FAQ. Does anyone have some type of step by step guide that would tell me more than the faq? If not, I'd be happy to take advice from everyone and put something together.
2) Can anyone recommend a Nissan dealer in Quebec, close to Burlington, VT?
Thanks in advance for your help....
I guess it's time I post another big summary here, but for those who have not seen this before take a look at post 2610 for some general info. Basically you can save a bundle by taking a short trip to Canada to get your Pathfinder. Prices are the best yet lately. Here is what I've heard of recent: LE with leather for $26,500; SE auto with sunroof for $24,000; Infiniti QX4 loaded for $28,900. Also you get some more goodies with the Canadian versions (like the All-mode 4WD system on the SE that you can't get in the US). All these are four wheel drive - no 2WD avail in Canada.
I have a lot of info written. Anyone can just email me and I'll send it off or answer questions. I'm kinda having fun helping others with this.
-Jon
The dealers won't tell me anything over the phone, and Edmunds.com hasn't updated its rebates & incentives listing yet. Help me, please!
Thanks, Janice
One salesman said that unlocking your door with a specific keyless remote could adjust the seats to a preset or your last seating position. Is there any correlation between the keys and auto-adjusting the seat position?
Do the preset memory buttons on the door also adjust the side mirrors?
Anybody have any problems with the power seats? the seats sliding back to let you out and sliding forward when you start it up? Opinions.
I noticed that the AT shift lever feels sloppy and not locked into the current gear selection. "D", "2", and "1" all have slop when in gear and the release button is not pushed.
Is this normal?
