Visitor Agreement.
Had to replace the windshield on my Mustang a few years ago due to a rock chip - guy drove to our house, did it in our driveway, and only charged us $175. No problems with leaks of any sort. I do imagine that a Pathy windshield will cost more, but it's a pretty routine procedure.
Nice looking rig. I will print it out to show my wife, she may let me get one for Christmas. Did it help or hurt the approach angle? Did you put in a second battery for the winch? What winch/pull rating did you get?
mmthomas3
I really like the integrated look of your setup.
But your picture would look much better if mud were slung all over the place. HA! HA!
As far as winch size, you should take the GVWR )Gross Vehicle Weight Rating) and multiply it by 1.5. I don't recall the GVWR on our Pathfinders, but it should be around 5,500# (4,299lbs+passengers and gear). Multiply that by 1.5 and you're looking at 8,250lbs recommended. Since that's between two winch ratings, I'd go for the 9,000lb pull rating winch for the margin of safety. A 5,000 vehicle that's sucked down in the mud is a BEAST to get out!
Anyway, I'm off to San Gabriel OHV (Southern California off-road area) for the day (With mud!).
Captain Ron. . .
BTW, I was quoted $2050 Can. (approx. $1300 USD) by 4Wheel Wholesale Parts here in Edmonton (Alberta Canada). I'm sure there's lots of shipping in there, but still...
Yes it was from ARB website. I didn't know that prior to post it. I found it and link it from 4x4parts BB. I thought it may give a better idea of how the ARB looks like on a 2001. I'll delete it.
My baby: http://www.keywestboatsinc.com/boats/196bayreef.html
I included the weight of the trailer, fuel, etc to determine the weight of the boat. Better to over estimate than under.
I have spoken with several mechanics and my dealer regarding towing in OD. Here is the reason not to under any circumstances.
Automatic transmissions use planetary gears for 1st, 2nd, and OD. Drive does not involve planetary gears and is a direct drive through the transmission. Not directly to the wheels as the final drive does reduction. Using planetary gears generates high heat in the transmission, a critical factor in the transmissions health. That is the reason for NOT using OD for extended highway towing. Does not matter when pulling up or down the ramp unless you plan on hitting 40 mph in the process. I have put over a 2000 miles towing to FL and back to GA with overdrive off doing 70 mph with the engine turning 3400 rpms. This is a good set up the engine is loafing and the transmission is cool. I use Castrol Syntec in the Pathy and I know it is well lubricated.
Even if the engine is not working hard towing in OD, your transmission is taking a beating, trans cooler or not. Even if you purchase a Ford pickup with a 460 V8, the manual will state not to tow in OD. You need to be concerned about avoiding trans failure (usually someplace inconvenient) and voiding your warranty.
Enough of the scary stuff. buying a boat is truly a blast. I spent over a year reading on-line articles and going to boat shows before I made my choice. First consider the boats purpose. Choose boats that fit your need. All boats are not equal, as many boating forums are full of horror stories of choosing a poor quality boat from a company with a poorer reputation. Stick with a company with a proven track record. Take your time shopping before you hand over the $$, as you know by now, they don't give them away.
I did add Airlifts to my Pathy to raise the rear end from the tongue weight of the trailer. These things work great as I would bottom out coming out of my driveway and other places. They cost me $70 and installed them myself in 5 hours.
http://www.airliftcompany.com/al1000.htm
Email my if you have any questions. I know some good boating forums with boaters sharing their experiences.
Good Luck
Les G
I bought them at an audio show in LI this past summer, so the were only about $45.00.
I installed the PIAA SUPER PLASMA (H-76) and was constantly using the high beam on those dark highways to Canada,Ottawa from NYC.
Good lock.
Full5.
I'm looking to replace the stock toyo tires with a new set of winter tires that are good for driving in wet/icy conditions. I would appreciate any recommendations.
Also, has anyone heard any news about replacing the PF's lighting systems with the one found in the QX4?
Dealer offers $30,500 for '01 LE demo (4K miles),
no Nav, no Entertainment. $34.5K sticker
I say $28K.
Whaddya' think?
Pretty lame, huh? Well, you can easily install one yourself, like I did to mine. See this link for info about how I did it. Cost me all of about 5 bucks.
-Jon
I would suggest that you take a look at www.tirerack.com for best fit. I did it, and came to the conclusion that 2 tires are best suited for the Canadian winter. Bridgestone Winter Dueler DMZ-02 or the Michelin LTX A/T. The first is an ice tire with excellent snow and slush performance (ice is where they perform best). The latter is an All Terrain tire, with excellent traction in snow (deep snow), slush, mud and dry pavement (highway) - but so-so on ice (has to do with the rubber used - too hard for ice...). The blizzak (DMZ-02) has a soft rubber that should be good for 2 winter as long as you put them late (November/December) and retire them early (mars/April), but that's the price to pay for maximum ice performance.
Personnaly I ordered the Blizzak, with minimal momentum and some smart driving, anyone with a PF should do ok in snow (this thing is a beast!!!) but ice is trickier, it doesn't matter how many wheels you have, when the traction is gone, well get ready for an unpleasant ride (hope to end up at best in a soft snowbank).
my 2 cents
My driving Lights are connected to the high & dim Lights only. They don't work when the heard Lights are on.
Good Luck.
Full5.
Have you seen the posts here about buying in Canada?? You can take an hours trip up to Vancouver and have a 2002 LE AWD with leather in your hands for $27,500!! That's $4000 under US dealer invoice. $7000 under sticker. Just a little paperwork at the border. I did it and 60 others have done it since. Write me and I'll send you all the info. I'm glad to help out anyone. Don't throw away your money.
-Jon
Has anyone noticed an improvement in accuracy with the bracket (especially on warm or hot days)?
The warning lamp for check engine came on this morning. I've driven 6200km or approx 3750 miles.
Is there a schedule that this warning light comes on? I dont want to take it in to service if they're just going to check fluid levels. If this lamp is on a schedule, how do I turn it off?
Anyone else have this happen?
BigDot, at least consider purchasing in Canada. Good experience in Southern Vancouver. Others in WA and CA will attest to that. Jon is the info man.
Having fun with the Pathy, Gladiator
I checked all I could think of in and around the engine. Remembered that I just filled up with gas last night. Usually fillup at Costco or Shell always selecting 91 octane or better. Yesterday I was on E and knew I wouldn't have time to fill it in a.m., so I used Citco gas. Thought I might have a tank of bad gas. For kicks, I checked the manual on schedule and warning lights.
Among other things it indicated that maybe gas cap was loose or off. What the ----. Sure it enough, the cap was still attached to the clip on the door. With a chuckle I replaced it on filler tube. I will let you all know for sure tomorrow.
4 months with my pathy and still feelin spoiled.
Thanks!!
One big difference is on the Canadian SE. SE's with auto trans come with AWD standard just like the LE. You can't even get an SE in the US with AWD - you get the 4x4 stick version instead.
Just for completeness here's a list of all the differences that I know about:
- All are 4WD - no 2WD available.
- The All-Mode auto 4WD system comes standard on all automatic trans models (not avail on the SE in the US).
- Limited slip differential standard.
- Floor mats standard.
- Block heater standard.
- Cargo net standard.
- Daytime running lights standard.
- Power antenna rather than fixed mast.
- Slightly nicer roofrack mounts (better security).
- Windshield washer fluid low warning light on dash.
- Speedometer in km and miles, odometer in km (can be changed).
- For SE model, sunroof and prem pkgs are standard; leather and auto trans are only options.
- For LE model, leather is standard; no options available.
I think the last time I did a more complete post with more info was at #2610 way above. But with the better exchange rate prices are even lower now. Just write and I'll help out with questions or maybe even some good dealers if you want.
Jon
Thanks for details. Do you know any dealers on the Canadian side near Michigan? I would be coming from Chicago.
No rush, I cannot purchase for another 3 months. Besides, I'm still deciding between the PF, 4-Runner or Chevy TB. TB is just about crossed off. Can't beat the Canadian PF price though. Have you ever driven your PF (short trips) with the rear hatch open while carrying long objects? I'm worried about the hatch glass bouncing against whatever I'm carrying and cracking. That's one feature I like about the 4-Runner. The glass drops into the door.
I have the same problem as you do. An 01 Path LE with a drawtite hitch and the muffler bangs on the the hitch. I engineered a wedge to place between the muffler and the hitch and it has worked thus far (3mos). I should probably go back to the place I had the hitch installed at, but just haven't gotten around to it.
I echo comments on back glass. I've made lots of trips with lumber or such sticking out the back. No problems. Actually really slick.
-Jon
Really enjoy driving the vehicle, nice and smooth.
If you want a more quiet version of the PF, you'll have to turn to the QX4...$$, but it's still loud in the rain.
I'm confident that if you go for the PF, you won't regret it. Based on my own experiences and those posted here over the last couple years, problems are relatively few and typically minor in nature. Driving this vehicle (and my previous 99.5 PF LE) for the last 2 years has been a real pleasure.
I took a 6 inch section of automobile water-pump hose (heavy black kind) slit it down the middle of one side, applied a LIBERAL amount of clear silicone to the inside, and slid it over the right hitch hanger.
14 mos later, no noise, no problems, and the hose has held up great.
Gritz
I did not realize it was so tight under there until I installed the hitch.
Thankfully I must have gotten one of the updated designs.
Are you sure that the dealer is discounting 2002 Pathfinders significantly below invoice? I could understand why 2001 Pathfinders would be heavily discounted, but not 2002s. Thanks.
