The problem with PT 4WD is that the front and rear axels are "locked" meaning that there is a 50/50 distribution NO MATTER WHAT. You seem to know that there is a problem with taking curves, meaning that the outer wheels are spinning at a different rate than the inner ones.
LSD is only on the REAR axel, hence it won't help.
Again, I can't help but mention that the AWD is a great system that requires no driver intervention. It will stay in 2WD drive under normal conditions and kick when it is really necessary (the action of the wheels provide the direct feedback) not when the driver "thinks" it's necessary. You still have the ability of "locking" the system into PT 4WD mode if conditions permit or warrant it. THere is both a PT 4WD lo- and hi-mode that is user selectable. But again, unless you at the beach, dirt road, continous snow, etc. there should be no reason for PT 4WD.
Hope this helps.
Largely because of your great forum I just purchased a new Pathfinder LE and am really enjoying it. I do have a question about basic operation and would really appreciate your comments.
Is it OK to downshift the auto transmission from drive to 2nd or even 1st to preserve brakes on hills? I've done this for years with manual transmissions but am not that familiar with automatic transmissions. Appreciate any thoughts you can provide!
Jim
Best of luck and happy new year!
Drew
Host of Vans and Aftermarket & Accessories message boards
Hope 2001 is good to all of us here on the Town Hall boards!!!
Best Wishes!
Heres the details, nothing is set-in-stone just yet, but I have done the following:
I put a $500 (refundable) deposit on my credit card to hold a 2001 Sierra Silver LE loaded with all options (minus the NAV & ENT Systems and no Tow Hitch) at Tischer Nissan in Laurel, MD.
My price right now (out the door) is $31,000 for my purchase date of 6 January. I could have gotten this same vehicle for $30,500 if I would have done the paperwork this past week, but I wanted to make sure IN PERSON that this was the vehicle I really wanted. I would also like to see a Bronzed Gray PF to compare it to the Sierra Silver PF, which I already know I like.
Hopefully things will go well at Tischer. If I remember correctly another member here on Town Hall purchased from this same dealership as well. (Scraff are you stil out there?) I'd like to get some feedback from you if I could!
Thanks need to go out to everyone here! I feel like this is going to be the most informed purchase I have ever made!
Let us know how it goes.
Me, I should hopefully have my home equity credit line closed this week. Then it's probably off to buy either a JGCL or a PF LE or a Lexus RX300. Haven't decided yet.
TC
I did a lot of research on the NHTSB site and it seems that the TSBs for the 2001 JGCL model are practically non-existent. It leads me to believe that the freshman and sophmore kinks have been worked out. I've learned my lesson and would never buy the first-year design/redesign of any car ever again (I did in the past).
Like I said, I haven't made up my mind yet. The big thing on the PF for me (and we have a '97) is that there is not enough "luxury" for me. I'd like a trip/systems computer, more power seat adjustments, and other little things like better use of the cabin space/design.
Spending $30,000+ on a car is a big decision.
TC
BTW, what is the link to the class-action site?
Before you make your decision about the JGC, you may want to check its IIHS 40 mph offset crash test results, as well as the NHTSA's 35 mph full width front crash test.
I was extremely disappointed that such a new platform only managed to get 3 stars (reflected in its IIHS result). In addition, some of the injury figures were high in the (newer) MY1999-current JGC model than its predecessor!
http://www.nhtsa.dot.gov/ncap/cars/784.html
http://www.nhtsa.dot.gov/ncap/cars/650.html
Drew
I appreciate the links and safety is something I seriously consider for my family. It is dissapointing, the only good thing that it is actually an improvement over the '98 design.
Like I said it's a tough decision. Certain things like auto-climate control are a must for me. Not many vehicles in the $30 - 35k price range have this, plus the AWD feature. For about $36K I could snag a Lexus RX, but it's not my perfect choice in terms of features, plus its hard to get it configured the way you want it, the dealer pretty much sets the features.
Oh well, decisions, decisions....
The one you saw advertised for approx. $23k was probably a 2WD model. $25k - $26k for an SE with the options you listed is definitely doable.
MSRP: 30,869
Inv: 28,112
CD: 27,143
THe above info is from Carsdirect.com. The reason you can get almost $1000 less than invoice is because Nissan has cash-back until 01/02/01.
So yes, $27k is doable, but you better hurry. Plus, the above price is for an SE/auto without any other options. Dealers sometimes don't have them "bare-bones" and hence the cost might be higher.
Good Luck.
For detailed info about All-mode 4WD vs. PT 4WD
check the following site:
http://carpoint.msn.com/browse/win_2917.asp
Hope it helps.
I should have a Loaded Sierra Silver LE waiting for me in Maryland this Saturday. Hopefully all wil go well, but if it does not I do have some time to look elsewhere as well.
Loboy (Jon)- Turns out I won't have the time needed to purchase in Canada. It would have been great to save the cash, but I won't be able to swing it on this purchase anyway. Maybe next time. Thanks for emailing me the information (twice!) that you put together, you really have saved alot of hassles/money for alot of the Town Hall PF owners, that's for sure!
Tonychrys- Good luck on your upcoming purchase, no matter what vehicle you finally decide on! I'm hoping the PF I pick will be a good one, but I'm not too worried about getting a lemon with all the positive feedback here from actual PF owners. Again, best of luck to you!
I'm sure I'll be back on here again after my purchase, but it may be a few weeks, as I'm also in the process of moving to Biloxi, MS.
Happy New Year to all!
(Go there and look at how poorly it's rated)
http://www.nhtsa.dot.gov/cars/testing/NCAP/SaferCar2000/table1.html
(Go there and see how well it's rated)
Weren't you all a little disappointed with the rating the PF got in the crash test?(in the first web site) It rated BELOW the durangoo!?!? How could anything rate below that? Other sites I have seen rate the PF much higher (second site), what's up with this? Which one do you think is right?
Personally, I take the 2nd (IIHS) test a lot more seriously since it closely reflects real world performance of an (albeit) serious collision. It is much less likely that one will crash into a non-deformable object (concrete wall), as the NHTSA does, in real life. FYI, the NHTSA's test standards haven't been updated since the 1970's. Most other countries now use the offset crash test, or a combination of the side impact/front offset/full width test in their new car assestment programmes. It is possible for a vehicle to do well in the NHTSA's test, but poorly in the IIHS test. However, all vehicles that do well in the IIHS's test also do well in the NHTSA's test.
The Pathfinder's heavier (against most cars) curb weight, as well as the height of that the passengers sit at should help overall. But hopefully, the next generation Pathfinder/QX4 will do a lot better in both of these crash tests.
Hope this clears things up!
Drew
TC- Had a Cheap Wrangler, Engine blew at 30,000 miles. Took a year for Chrysler to settle up with me. A friend of mine recently bought a 2000 JCG with 10,000 miles on it for a "steal". It's been in the shop constantly and he's trying to sell it. I'm not saying that all Jeeps are bad...just be careful.(It is a very comfortable car. Makes waiting for the tow truck almost enjoyable).
Cheers.
Try this link regarding JGCs /direct/view/.ee95171/0It seems that the Class action posts have stopped with the conversion, but can be reviewed with the townhall search function.
I"m starting to lean more towards the Lexus RX300, even if it does cost me a few thousand more. My family comes first.
I'm also waiting for my home equity credit line to close (maybe next week) so I couldn't get the 1K rebate. Does anyone have a guess as to whether there'll be another one anytime soon? I'll be looking to buy in 2 weeks or so. I heard Toyota is starting a new rebate program so I'm hoping Nissan will need to counter that.
I'm just hoping their rebate makes Nissan extend theirs. I'm pretty set on getting the PF. Sometimes I think the only real competetion is the XTerra...which, as others have pointed out, is more 'bare' than the PF. But also, it has less power, less cargo space and you can't get side air bags(which is the only reason I'm getting leather/moonroof...4K...ouch!).
It also seems that this test is only looking (objectively) at injuries sustained by the driver, which were low in this case. If I'm looking at the safety of my family, how do I rate the PF? The NHTSA results look at injury levels to front and rear passengers during full frontal and side impacts and have rated the PF highest (5 star) in both cases. So now I know that the driver of a PF is unlikely to be injured in an offset or full frontal collision, and my passengers are unlikely to be injured in a full frontal or side collision, how about my passengers in an offset frontal? I don't know...I suspect pretty low injury level but does anybody measure this? I ended up buying a 2001 Honda Odyssey to haul the kids around in partly because it rated so high on both tests (IIHS and NHTSA).
wife decided I should go out into the storm and pick up a pizza in my
'01 PF LE. To get the truck out of the driveway, I proceeded to slip it
into 4 Low. I got out of the driveway no problem, but when I tried to get it back
into 4 High or even Auto, I was refused. It just continued in 4 Low. I tried everything
I could think of - nuetral, park, etc... - it wouldnt budge. After continuing fiddling
around with it for a while, it suddenly jumped back into 4 high. I dont if it was something
I did to "fix" it or it just warmed up enough - I dont know. Is there a certain proceedure
for shifting out of 4 Low that I didn't see in the owners manual or do I have
a problem??
One thing that really opened my eyes had nothing to do with saftey... the 5 mph bumper crash tests. Look how much money you'll sheel out to fix the PF compared to other vehicles in it's class. Sheesh. The more expensive Lexus actually costs less to fix.
I've never smacked up my '97 PF so i can't prove if any of this is true. Maybe it's time for a science experiment....
mcc32 - I had the same problem. I think I ended up putting it in park and holding in the button on the shift with my right hand and switching it back to 4hi w/ my left hand.
To all - I was coming up the access road at Stratton Mountain in VT on Saturday and saw several SUV's that had been coming down the mountain skidded off the side of the road. But my pathy had no problem!!! A foot of fresh, unplowed snow in the street and driveway, and again no problem!
As for the 5 MPH bumper test, ouch... I wonder if the 2001 PF would rate as bad. I noticed they only say for 1997 PF. I suspect any changes were only cosmetic.
Thanks guys, I'd been following the posts here for about six months and it had made my decision a lot easier to by the PF. The only problem I have is that I've had it for a little over
2 weeks and I have a hard time getting out of it( I already have 1200mi. on it). I love the power
and smooth ride. My only question so far is I have the in-cabin microfilter and it's rec. to be replaced every 7500mi. Can anyone tell me where it's located.
Also, have heard complaints here on this forum lately about mpg. Although the PA isn't the greatest, with a SUV, especially 4wd, I am not sure what is expected. I came from a Dodge 97 Ram pickup, that consistently got no better than 10mpg. I also had to use premium in the dodge, so there was no change for the PA, except it gets a lot better mpg. Although I too have heard the prediction that the market if dropping out for the SUV, for many of us, that live in snow areas and have to get work, etc. a 4wd of some sort is a necessity, not a luxury. Pickups are certainly no better on gas, and some are much worse. Most of the SUVS on the market are rated around 15mpg.
What are other folks paying? I am located in the Long Island area near SUNY StonyBrook. From what I remember the dealer service costs were much lower for my Honda Civic based in Palo Alto, CA (San Franscisco Bay Area)
PF = PathFinder
AWD= all wheel drive
LSD = limited slip differential
NAV = navigation system
ENT = Entertainment package
More than happy to help.
Follow this link (it may be wrapped):
http://ownership.carpoint.msn.com/ownership/Period.asp?veh=2817354&idTrim=3446&st=0&pd=15000&sched=7914&stype=107&Year=1999&Make=Nissan&Model=Pathfinder&src=ownership
Jack0565, the micro-filter probably required the most work (25 mins), because I had to disassemble the glove box and cut a plastic slot in the a/c filter box for the filters. That shouldn't be an issue for you, since you're looking to replace an existing one at the maintenance interval. When you purchase the replacement, you'll find instructions and pictures to show you how to remove the glovebox and replace the filter.
synthetic. I have used amsoil and it is probably the best but at 6$/qt.I chosed other. I also installed an amsoil
foam air filter. Some people I know are using Mobile 1 but on one of their web sight
Mobile 1 seems to have a sludge problem. It does not hold the sludge insuspention.
Also it's up to the owner to decide how often to change the oil I don't drive my much
except on the weekends so I will change it every 6 Mths. To keep the warrenty??
Castrol syn is meneral base and not a true syn. I also use synthetic oil in the diff.
and have good luck but not very many meet the spec on LSD . The only oil that met
the latest MIL spec was meneral oil not synthetic even they say it's approved for LSD.
Looking at other EDMONDS sights on oil people are mixed for both good reasons.
Cheers
*Kind of off the Subject* -- Are any of you computer games? I just installed the 4X4 Evolution Demo on my Macintosh. And the default vehicle was a BLUE 01 Path DE ... Just like mine..... Neat .. now I can pretend I am racing in the raja desert! Happy New Year from one happy PATH owner.
5w-30 vs. 10w-30: I am not suggesting that anyone used the heavier oil but I am curious if the oil consumption will go down.
I will send out an oil sample at 5K miles to see what lab says. I will let the list know.
cheers!
