Visitor Agreement.
Thanks for your feedback.
The brake pedal is also very mushy. There is a lot of pedal travel before the brakes actually work. My car has only 8000 miles on it, so it can't be brake pad wear. I just want to make sure this is normal or if it's a defect with my car.
Thanks for your help.
thanks!
Hello mesnwear,
The accelerator on my 01 auto SE PF is also quite sensitive, but i've gotten use to it. I don't have any issues with the brake though. I've found the pedal feel of the brake to be excellent.
tidester
SUVs
Dano
be "burned in" to make them work proper. Also
the rear brake shoes must be adjusted. They work
alot better after about 10k.
As usual, I'm glad to help out anyone with the info on how to buy in Canada. We're up to 60 successes now. Just drop me a line.
-Jon
Dano
My 02 SE has the new roof rack with the XTierra look...the rack has a front air dam (you can't call it a deflector!) and there's a 1/2 inch gap between the bottom of the air dam and the roof...the wind noise w/ the sunroof open is considerably higher than the '00 with no air deflector or the '01 with the Nissan installed air deflector.
Anybody having this problem with the '02 SEs? The dealer's parts manager is sending a query thru Nissan channels. If other '02 PF SE owners have a similar situation, we might try and make some group noise to our dealers and see what happens. Only the '02 SE has this rack with the air dam in the front...the LE's are like last year and most have the air deflectors installed.
Ed
I did notice a low brake pedal, and mentioned it to the dealer, who compared it with other new Pathfinders on his lot, and concluded they all had low pedals, so must be normal!
Who suddenly found herself wealthy,
With the luck of the draw
And a hot powerball,
We spotted her driving a Pathy!
tidester
SUVs
Pathfinder is $110-140/each
QX4 is $60/each..
Why is that? I thought Infiniti one should be more expensive that other.
I also considered an 01 4runner, but wasn't impressed with the 3.4 v6. Power seemed merely adequate without towing. After test driving a pathy the 4runner was no longer a consideration.
enjoy
Also, can anyone share any experiences with purchasing in Canada, process, hints details, etc.... I would be financing it here in the US., is this a problem? I live in Seattle so the drive to Richmond/Vancouver is no big deal.
TIA,
email me ofline if you like, just take of the "no_spam_". no_spam_bryanw@speakeasy.net
TIA,
If you wish to email me offline, just take of the "no_spam_". no_spam_bryanw@speakeasy.net
However, I wouldn't pay dealer invoice for a used vehicle. 1300 miles isn't much, but as far as the DMV is concerned, it's used, and its value has already gone down.
Put it this way: You can generally pick up a NEW vehicle (usually with less than 50 miles on it) for $300-$500 over invoice, and with dealer incentives, many times you can get a new vehicle BELOW invoice.
You also don't know how the vehicle was driven and broken in during the first 500 miles, which has a significant impact on engine life.
Just something to consider...
-Jon
Diagnosed problem as faulty Mass Air Flow sensor. Changed out the sensor and everything seems good again, except for the "confidence factor". Was hoping for a problem-free experience, but I guess that is relatively improbable. Nothing worse than seeing your $30,000+ hunk of steel get hauled away from a crowded K-Mart parking lot!
Just to make you feel better, my 2001 Honda Odyssey had 100 miles on it when it had to have the ECU replaced. After replacing it, I drove it home no problems. Next day it wouldn't start. It had to be towed out of my garage (in front of my laughing neighbors). Turns out they hadn't reprogrammed the keys to the new ECU, which allows 4 or 5 free starts for troubleshooting/diagnosis before requiring reprogramming...
Thanks for all the help.
Path LE AWD with leather, LSD $27,600
Path SE auto AWD, popular pkg, sunroof, LSD $25,300.
Hope this helps.
-Jon
As I knew they would, the service mgr said both were in spec. Although I don't agree totally both only happen intermittently. The squeal occurs only when the car has been sitting. Possibly glazed pads. The trans slip, well, it has been documented three times at the dealer and I am not worried about it. If it goes, well I'll deal with them then.
Until then, we're going to enjoy it!
Dano
Thanks for everyone's help
email me in private if you like
Thanks for your interest in looking up the key programming procedure.
Woody in snowy British Columbia (keyless start time?)
Austin_p, this seems like a very good deal compared to what I've been finding the nearly loaded PF LEs (no DVD or Nav) here in the Seattle area. Is this too good to be true in terms of other fees and what not for buying out of the country? Unless I'm mistaken, 26,700 is a few thousand cheaper...
Can someone give the pros and cons for purchasing in Canada and bringing to the US? If it's worth the trouble, I'm seriously considering this as I'm in the market right now!!
Thanks all!
The only real downside is that you have to go pick it up, and there is some paperwork to do for customs and Canadian tax refunds. The forms are real easy though. Initially it can look like a lot of work, but actually it's quite straightforward. Since I did this myself I know of over 60 others who have too. Drop me a note and I'll send off the info on how I did it.
For others - I'm always glad to help out. Let me know where you live (or where you might want to buy) because the sales tax rules are different in each province. Toronto and Vancouver have the best prices usually, but other places are certainly possible too.
-Jon
cabin/outside temp)
They are not tied to anything external. There are two heating elements in the seat. On low, one comes on. On high, they are both on. I checked the electrical diagram in the Nissan shop manual.
-Jon
-Jon
Gasoline-(from post 4071)See also post 4060
I have done tests in both our '96 Jetta GLS (2.0 litre 5-spd, drinks mid-grade), and our '01 Pathy SE (3.5 litre 5-spd, drinks premium). I ran the fuel requested by the manufacturer for 5 tanks and recorded the mpg. (30 for the Jetta and 18.5 for the Pathy). I then switched one grade lower for each auto for 5 tanks and again recorded the mpg. The Jetta fell to 28 mpg, and the Pathy fell to 16.25 mpg. With the Jetta, the car averaged about 30 miles less, per tank,(one gallon of gas), while the Pathy averaged 40.5 less per tank. (two gallons of gas)
In the Jetta, the cheaper fuel, but fewer miles per tank about broke even in terms of cost. Because of the lower mileage, the Pathy was actually a bit MORE expensive to drive using the cheaper gas..... funny but true.
Factoring in the reduction of performance, especially in the Colorado Mtns., plus the ADDITIONAL COST of using cheaper gas, the Pathy drinks Premium to this day, and the Jetta dines on Mid-Grade.
Tire Pressure-I ran my original Duelers @ 33 front and 31 rear, the 24 psi was way too "disconected" for me.
btw-We have new tires now and they are 100x better than the stock Bridgestones that came on the "Pathy" on Rain Snow and Ice.
Run Premium fuel. If you plan to keep it, it is not worth the possibility of engine wear and tear.
Bridgestone "strongly recommends" running the tires at 35psi. I have run mine at 32-34 PSI and they still have a lot of tread left. They are also wearing very evenly. I expect another 20-25k out of them.
I have no rattles other than the license plate frame. However, that was my install. Looking for better alternatives to the lic plate.
