Steve
Hope that helps.
Sid
Any suggestions?
If that doesn't work try a product from Carbona called "Stain Devels 3 - Ink and Crayon". It's a little yellow bottle with a white cap. My wife tells me it has worked when hair spray hasn't. But, be careful with this stuff it will fade some materials.
Hope this helps. Good Luck.
Grand High Poobah
The Fraternal Order of Procrastinators
My 01 SE pathy is making a clicking sound when the fan is on. It is most noticable when it is set to the lowest setting. I would like to get it fixed as it is really really annoying, but am afriad that the work done will upset the fit of the interior components and result in rattles. Can anyone with a shop manual tell me if this fear is warrented?
As I followed the stereotypical male rule of not reading the nav sys manual, I'm not sure if I'll be able to help- but fire away and I'll see what I can do.
On a side note- took the LE in the other week for the 8K service and it was the first one the dealer had seen with the nav system. Kinda funny to see the service and sales guys crowding around it
-Jon
The Pathfinder is a fabulous vehicle with great reliability, but it's disappointing to see in Consumer Reports this month that as a whole Nissan dealer service ranks second from last of all brands sold in the US. Would have been dead last in Canada since Mitsubishi was at the bottom and they don't have Mitsus there yet.
-Jon
I have read the hole book on the navi and i can't seem to fig out the following and either can nissan,
1. In 2d mode what are the black dot marks on some street's or roads?
2. What are the differant colors for land(dark grey on one side of the road for land the other side is white for land? even yellow for land..
hope ya can help me.... tks
For the rest of the gang ... has any one had problems with the sunroof on the le? mine need's replaced ... never used it! yikes!!!!
Thanks All
PIT!
I'm not very tall (5 foot 4), and thought that the step pad might be helpful in reaching the roof rack area, but sometimes great theories don't quite work as well in practice. Do those of you with the Nissan hitch ever utilize the step area? Is it actually useful, or is it more of an annoyance than its worth?
Thanks for sharing your experiences. I have learned so much from this arena!
If you go with an after market hitch, make sure it is designed for an '01 or later model. The exhaust is routed differently than the earlier models. I had an initial problem of the exhaust rattling against the hitch frame.
I heard Nissan was going to redesign the pathfinder.
Trocco
I’m very impressed with Nissan and their products. I think of the big 3 (Toyota, Honda and Nissan) Nissans are the best! Honda makes incredibly reliable cars but is for people who like well built practical cars but would rather not spend a fortune on one. They sacrifice some solidity for lightweight that will bias toward fuel economy and good handling. Toyota on the other hand is the exact opposite. Their cars are also well built and comfort and quiet is sacrificed for some fuel economy and performance. Generally not a lot of frills but all the materials used are of the highest quality. Nissan cars especially the PF are built as solid as a rock and the quality of materials are also top notch. My PF has great amenities for the price and is an overall terrific value for the money. Almost every model they make is tops in the looks department too. Let me know what you think? If you disagree let me know too. You won’t hurt my feelings!!
I have tons of questions but I’ll try to mete them out slowly as not to inundate everybody. So far (1 week, two tanks) my mileage is 16.5 mpg. Not bad. Hoped for better but was expecting worse. I have no major complaints and the only change I would suggest is having the remote pop the rear window really stretching, huh? I have the popular pkg. and the auto climate is a little confusing to say the least. To heat the cars use the ECON button? I’m half-Japanese and still couldn’t figure that one out. On the manual setting how can I get outside air to come in that’s neither cooled nor heated?
Got lots more stuff to say but will hold back to rest your ears.
Happy Pathfinding!,
Steve
If you want just outside air check the outside air button (separate button next to the defog button)and turn the temp down to 65 deg and use the manual button to direct the air where you want it. The air might come out of the vents automatically anyway. Steve
The found the deflector had a crack about 12 inches long. Called the parts dept. They're supposed to accept return items no questions asked as long as you have the invoice.
That turns out not to be true. They insisted that it was the shippers fault and that they would not accept a return. The shipper would be responsible. The carton looked unblemished. I think it was from their parts dept. I found "Bob" to be unpleasant.
The shipper is taking responsibility even though I think the fault was elsewhere. I'm neither promoting nor discouraging anyone to do business with them. Just want to provide the facts and allow you to decide.
Was it a difficult job? Any advice or lessons learned?
Jon
I have a problem I hope someone can help me with. I have a '98 Pathfinder Chilkoot (incidentally, I too purchased it in Canada, although I live in North Carolina - great deal, but a bit of a hassle). Over the last month, the compass/therm display began to work intermittently, sometimes coming on when the car started, and then turning off in the middle of driving. This happened for about two weeks, but now it has shut off completely. I'm sure the dealership can fix it, but I'm also sure they will charge me an arm and leg to do it. I've tried to find anything in a repair manual, but no such luck. If anyobdy knows if there is a bulb that needs to be changed, or a battery, or something that I might be able to tackle myself (I'm a female, so take that into account), please let me know - you can email me at bertha@nc.rr.com
Thanks in advance for any help!!!
Mel
I am looking at buying a used (2001) model pathfinder. Its for the wife and she wants a 2 wheel drive LE with leather and Sunroof.
What know problems do I need to look for?
Tray
I am looking at a 2001 LE 4x2 loaded with 14,800 miles and they want $25,000.
Is that a good price? What are ya'll paying?
Tray
My PF (Knocking on wood) has been OUTSTANDING! I drove it home in the snowstorm the night the Pats beat Oakland (well after the game) from Boston to basically two exits north of the Foxboro where I live and it held the road perfect (no comment on the Pats victory- I'm a transplanted New Yorker). I would say the only issue I have had with it would be every morning when I pull onto the main road and accelerate it seems to want to wind out first gear... then it never happens the rest of the trip (and of course cannot be repeated at the service shop).
Anyway, best of luck in your search!
Matt
the_gladiator -- I was looking to buy one also and am considering nissanpartsusa maybe it's worth paying a litle extra and buying it from the dealer. Any reason you didn't get one from weathertech.com?
tbourgoyne--paid 25,800 for a 02 SE 4x2 with pop.pkg,trailer hitch, body mould.,filter. I know it's a little different than the one you're looking at; no leather, sunroof and other convenience items. My price was fair but not great.
Happy Pathfinding!,
Steve
It seems there are three options:
* Safari basket
* Cargo holder - soft
* Cargo holder - hard
I was originally looking for the hard cargo holder just for being water proof and potentially being able to lock it. On the other hand the safari basket is inexpensive and seems more flexible with regard to what you could put up there. Then the soft cargo holder seems like you could also be somewhat flexible. I am also having a hard time finding a hard cargo holder (checked out nissan-assecories.com and jcwhitney without a lot of luck).
Anyway, if anyone has thoughts as to what might be the best way to go I would appreciate it.
Thanks!!
Matt
P.S. Mine is the Samsonite.
Never heard of weathertech.com. I'll check 'em out. Thanks.
Matt,
I too, was looking at cargo baskets. Changed my mind when I thought about the wind resistence. My shorter stature would make it difficult to load and unload it.
Anyway, I am getting a 12 ft fishing boat. I found that I can get luggage carriers and bike carriers that are mounted on the trailer hitch. That's what I plan to do.
Brad
For Yakima use 17V or 18H instead of 10V or 23H.
For Thule use C35 instead of C27.
I have all of the above and they fit fine. Both Thule and Yakima know the right numbers if you call them, but they don't have it on the web site. The Canadian cross rails are slightly wider than the US rails. Makes for slightly better stability and less noise (maybe better security too since it has tamper-resistant bolts).
-Jon
wildcorgis - I LOVE my Pathfinder. Love, love, love, love, love. Why is it that I can say that about my vehicle but not in my relationships? (Apologies to Domino Pizza's current ad campaign)
Matt
Here in wonderful San Diego where our local legislators cannot get answers to why we pay more gas than most parts of the country, gas at the local Shell station which is pretty indicative of prices around the county was $1.57 for regular and $1.88 for premium. Our neighbors to the north, Los Angeles pay about 20 cents less than we do. Price you pay to live in paradise!! ; )
Happy Pathfinding!!
Steve
They now have two more models: a 15 cu. ft. 20 gauge tarpaulin type for additional waterproofness and a 24 cu. ft.polyester fabric model.
I got mine at BryanGlobalServices.com (http://www.bryanglobalservices.com/luggagecarrier.html). They were excellent to deal with.
I found a PF similiar to yours and with CA tax at 7.75% and $250 for license it was $38K.
http://nissan.mossy.com/new/veh.asp?UntId=0K21289
So you're saving about $1,000 over new. I thought new cars devalued quickly when driven off the lot? But the financing sounds real good. Hard to find a used car loan that low for 60 mo.
Happy Pathfinding,
Steve
And depending where you are, I saw an 01 LE with 11K with all the above goodies for sale(private) in MA for $30K.
Regards.
Jeff
As for the thirty-seven thousand dollar question, it was unclear whether that was the dealer's asking price, or if that was the final cost of everything... purchase price, tax, licensing, doc fees, interest payments over 60 months, etc.
$37K is wayyyyy to much for even a loaded Pathfinder, let alone a used loaded Pathfinder. But add in tax, interest, etc., it could be reasonable.... At any rate, you should be negotiating with the dealer on purchase price, not the "out the door" price. But then again, if the 3.9% deal means you have to pay a few hundred dollars more on the purchase price, it could be better than getting a used car loan @ 6.9% or higher...
One can get a hard roof top carrier and leave it on the roof permanently or store it somewhere when not needed. Hopefully it's available where/when you need it.
One can get a hitch box and leave it on the hitch permanently or store it somewhere when not needed. Leaving it on the hitch permanently looks really impractical to me - parking among other things ... Hopefully it's available where/when you need it.
Personally, I like the soft roof top carrier which, in addition to out-of-the-way-in-the-trunk compactness also leaves the hitch for my 3-bike carrier.
There is more than one type of carrier to allow for our individual needs. For my needs, I made the right choice, except that maybe I'd like to get my hands on the new 24 cu ft Samsonite ...
Jeff
I don't believe any US PFs ('01 or '02...I have an '01) have the power antenna...maybe Canadian ones do.
Many thanks !
