Nissan Pathfinder
1106107109111112158
  • weathercasterweathercaster Member Posts: 2
    97 PF (three years)
    00 Expedition (two years)
    02 SE PF (just purchased)
    I commented the other day (in my first post) about spending a lot of time testing the "other" SUV's and settling on a PF. I focused on 4Runner, Explorer, SC Xterra, while driving and looking at a few others.
    I'm mostly driving around town, but I am one of those few who likes to 4 wheel on occasion. 4Runner wins the 4 wheeling battle with PF and Explorer. Xterra competes with 4Runner 4 wheeling, but lacks considerably on the highway and around town. PF can do most of what I like to do off road and the ride “on road” (PF) beats 4Runner by a long shot.
    I live on a 12% grade hill on the Bench area of the Wasatch Front in Utah. Going up and down this hill several times a day to run errands and go to and from work, I can attest to a vehicle's hill climbing ability. I really liked the 4Runner for its off roading, but after several test drives up the hill, it was obvious this truck could not maintain 30 mph going up. (Too heavy for the 183 hp 3.4 L engine). Explorer (4.6 L Engine) had no trouble climbing the hill. PF, on the other hand, was still accelerating at 40 mph in 3rd gear when I had to let off the accelerator. (Speed limit on this stretch of road is 30 mph).
    Since I only 4 wheel about 3% of my driving time, weighing the better (off road) 4 Runner (and its lack of power) and the PF with more than enough power (and a decent off road performer)...in the end there was no comparison (for my personal needs)...PF was the winner.
    Since I have to go up and down this hill every day, the PF's power made it the best choice. Explorer is more expensive, and the ride on the road is not better than the PF, even with the new suspension (my subjective opinion). Then add the great PF stereo system and the reliability of PF and it beats Explorer for the "long hall". Yes, you get extra seating in the Explorer and there are more choices in Explorer, but when it came down to the decision of which to own, I chose PF. Currently I’m coming out of a two year Expedition lease, so there was an additional $1,500 lease incentive to purchase Explorer. But, reliability issues weigh heavy for me. Explorer has been middle of the road before the upgraded and improved 2002 versions. My Expedition has been great on reliability until just before the lease was to expire, and then things started to go down hill (another story). The bottom line is, I think Explorer will last three to five years without major expenses, but I believe PF will last five to eight years before I will have to put major money into repairs. (Again, my subjective opinion). Since I expect to own this PF for at least five years, reliability became a very important issue for me.
    For those looking into PF, I hope you find your answers in this discussion group. In the end, if you want a great ride and superior reliability, and a vehicle that can 4 wheel as good as or better than most SUV’s, PF is the “one”. And, it is a great looking truck.
    Enjoy the ride.
  • johnskevjohnskev Member Posts: 98
    Sure, it wouldn't hurt to use 4hi now and then, but not on the highway at 75mph. Around town isn't too bad, but taking corners could cause slight binding. The auto 4wd systems, like what you mentioned is in the Jeep and the Pathfinder LE (some SEs too, right?), can be turned on at any time because the vehicle will run at 2wd until slippage then it goes 4wd until it gets traction again. As mentioned above, high speed plus good traction will definitely cause binding and cause some serious problems with your vehicle.
  • xplorx4xplorx4 Member Posts: 621
    Bigorange30- it's not neccessary to drive on wet pavement for the purpose of keeping the 4x4 driveline 'lubricated' - any surface will do. Just try to drive in a straight line until you shift back to 2HI.
    The practice of "lubing" the front driveline by using 4HI every now and then applies primarily to trucks with automatic or manual hubs, since on those trucks the front driveline doesn't move unless the t-case is in 4HI. Since the Pathfinder uses full-time hubs, the front differential rotates (and gets lubed) whenever the vehicle is in motion. Moving the t-case lever into 4HI just slides a collar in the t-case which transfers engine power to the front output shaft of the t-case (which is already turning anyway).
    So, "keeping the 4x4 system lubed" is not really an issue with the 96+ Pathfinder unless you install manual hubs. Auto-mode trucks don't even have to worry at all. :)
  • phil47phil47 Member Posts: 394
    Just expanding on xplorx4's excellent description, the part-time 4wd system on the PF makes for a very smooth shift from 2wd - 4wd, but it also results in some parasitic drag and associated power loss even when not engaged. For this reason, a few local dealers are doing a pretty brisk business installing Warn manual hubs on the PFs (with the PT system, NOT the automode) to improve HP and fuel economy in city and especially on the highway. Something to consider for those of you looking for ways to bump gas mileage...
    Don't expect miracles, though. The manual hubs gave me about 1mpg better. They cost about $130 from 4x4parts.com + labor. They're a cinch to install, though, if you want to do it yourself and save. Find out how by clicking here.
  • woodyr1woodyr1 Member Posts: 142
    I had a 95 Pathfinder XE with semi manual hubs. From a dead stop, I would engage the lever, and if I disconnected 4 wd at the transfer case, and reversed a few feet, it would unlock the hubs.
    I have 30,000 km on my 2001 XE with auto shift-on-the fly hubs. I have not noticed a loss in highway fuel economy with the auto hubs, but note that the 2001 is much thristier in city driving than the 95.
    I would like to hear from anyone who wants to share fuel consumption experiences with the install of manual hubs.
    To Phil47: Are you the same individual who installed the exhaust finisher from a QX4, as well the custom wheels? If so, I would like to again see your exhaust finisher photos.
    Woody in BC
    You can find the pics here:
    http://briefcase.yahoo.com/phil99_5
    The wheel/tire package and the exhaust finisher have held up beautifully. I'm very satisified with these purchases.
  • mattman055mattman055 Member Posts: 57
    I have an 02 PF, read about the shimmy at 55-65 MPH. I do not have a shimmy on mine as I have read about on some 01's, but it seems at those speeds on the highway I feel the most bumps even on smooth highways.
    At 70+ the truck feels great! I have to check the spedo to make sure I'm not going too fast.
    Does anyone know anything about it, or what I can do?
  • filodfilod Member Posts: 189
    beautiful pf! can you share the details of the wheels and tires? sizes etc... I loved the way it looks....thanks
    Thanks for the pix, Phil. I am off to Vancouver Island next week and may order one for my XE. I have had my vehicle serviced for years there at the local Infiniti/Nissan dealer. I was quoted about $60 plus taxes.
    From my recollection of your previous post, you recommend stainless steel fasteners.
    Woody
    Thanks. My wife is amused because we always seem to come back to the parking lot and someone is squatting next to the truck trying to get a better look at the wheel package!!
    Go to message #5093 and you'll find all the info you need. This was a very tricky combo to put together...not much out there for the late model PFs. I had to spend a few more $$ than anticipated.
    Woodyr1: Yes, I picked up a couple stainless steel hex head bolts from the local hardware store. They stand up to the weather MUCH better. Highly recommended.
  • pondfull5pondfull5 Member Posts: 53
    Hi Phil47:
    Many thanks to you. With your advice I have my Wheel/Tire just like yours in the picture.
    The dealer was impressed with your knowledge about the above subject. It took about six week of wait, but it was worth it.
    The rides are very smooth and sharp. And for some reason the 5 speed shifting have improve too.
    My trip from NY to Ottawa, Canada and back was great. Less road noise. I was able to cover more road in less less time too.
    Again my thanks to you for all the help you gave me.
    full5.
    Glad to help...post pics!
  • couimetcouimet Member Posts: 130
    Entering 5093 in the Msg# box at the top of this page takes you to Msg # 4896. Entering 5295 takes you to 5093. A little off ...
    It's a feature of our software:
    pat "Lost in the Town Hall? Ask the Sedans Host for directions!" Nov 13, 2001 4:49pm
    Steve
  • marsha7marsha7 Member Posts: 3,703
    the automakers...sell the sizzle, not the steak...tell 'em it's a special feature, a no-charge option, if you will, that they have been given by the grace of the programmers...it works every time...:):):):):):):)
    Bob
  • lancearmstronglancearmstrong Member Posts: 38
    I noticed several options by Velox and Binno for 16 to 20 inch wheels at www.customwheelsmarket.com that would probably be probably less expensive than Phil's Anteras. BTW, you could use the tire specs at tirerack.com to figure the right tires for the non-OEM wheels to match your 16 or 17" OEM tires (width and overall diameter). Just beware of off roading with those 18-20" wheels w/low profile rubber!
    Problem with going to manual hubs--finding wheels with open centers to allow hubs to protrude. Guess I could use the OEM wheels without the centers, but that would be butt-ugly. Guess I'll stick with the OEM "full time" hubs for now on my '02. Can't see dropping that kind of cash right now for new hubs and wheels to gain 1 mpg or less. And thanks to Dean Thayer, who pointed out that the new OEM hubs don't have to be run occasionally in 4WD to keep them "lubed" because they're constantly "engaged."
    Has anyone found anybody who produces "replica" OEM Pathfinder wheels?
  • meca2meca2 Member Posts: 284
    Mike why are you selling your 2001 LE?
    We don't buy and sell on Town Hall. Try eBay Motors or our Edmunds Used PowerShopper .
    Steve
  • captainroncaptainron Member Posts: 58
    Hi all,
    Well, as the subject says, my Burnt Cherry 2001 LE just got key scratched from front to back on the driver's side and across the tailgate.
    How'd it happen?
    I visited a buddy in San Francisco this past weekend and was told by his girlfriend to park in front of their garage door...she told me the wrong one. The guy I was blocking was p!$$@d off! I moved and tried apologizing, but he wouldn't hear it. I came out the next morning and my Pathfinder was keyed down to the bare metal. No real way to tell if it was him or not, but go figure.
    What now?
    This is a car that I keep garaged and Zaino'd on a regular basis. Am I looking at a full re-paint? Does insurance cover this sort of thing? Are there places that can do scratch repair on something this bad? It starts from the driver's door, runs all the way back to the fuel filler and loops back to the front. Not a pretty sight at all.
    Any help is greatly appreciated!
    Captain Ron. . .
    Sounds like you need to open up a big ol' can of Burnt Cherry whup-[non-permissible content removed] to me! Parking in San Fran is crazy, but that justifies a killin' around here.
    I had a similar thing happen (not to my Pathfinder) -- a rolling garbage can with a protruding bolt was squeezed between two parked vehicles and scratched it stem to stern.
    A "touch up" will surely show, especially if it's down to bare metal and can't be rubbed out. You're probably looking at a re-paint of the whole side. This will easily cost a grand if done properly. I would think that insurance would cover acts of vandalism such as this and it SHOULDN'T affect your premium. Body shops all go by a standardized program for estimating hours needed for a repair, so there shouldn't be much variation in the estimates. Just make sure you pick the best shop(s) around to give you an estimate, including the Nissan dealership.
    I'm sure you're sick to your stomach over this. The good news is that a good body shop can work wonders and you shouldn't be able to tell it had ever happened once it has been fixed. Expect the repair work to take about 3 days, and don't try to rush them!
    Bummer! That wouldn't make me very happy either.
    You might get the police to grill him on it considering the circumstances. You never know - the moron might slip up and reveal his guilt.
    tidester
    SUVs; Aftermarket & Accessories
    Hi all,
    While I'm on hold with my insurance agency (ug), I thought I'd pass along what I found on the key scratch problem... The body shops are telling me anywhere from $1500 to $1600 to repaint the driver's side front and rear doors, the rear quarter panel and the tailgate.
    Oh, just got off with the insurance agent (don't go there)...it's covered under my comp ($500 deductable) as vandalism and will show up as a non-chargable claim...so, my rates shouldn't go up.
    Thanks for all the help and sympathy...
    Captain Ron. . .
    PS: It's probably good I wasn't around to see who did this...I'm normally a peaceful man, but all bets would have been off.
    Bummer indeed ...
  • dverespeydverespey Member Posts: 56
    Another reason I always take Bart.
    Anyway,
    I would echo the statement by a previous poster. Give the police a call, this might not be the first time something like this has happened in the neighborhood. It may not help you, but it might be better for someone else down the road.
  • bgritzbgritz Member Posts: 139
    We get off into the UT backcountry (Needles/Maze) a few times/year and I was VERY pleasantly suprised at the Pathy's off-road ability. While it is substantially softer than out old Cherokee, it will do amazing things in 4L in 1st gear as long as you keep your speed down. We are going over Elephant Hill again in 6 weeks for our annual fall Canyonlands trip and can't wait to get back into the red-dirt. ;-)
    Cool! I'm planning on heading out there next April, for the 2nd annual goneMOAB (Gathering Of Nissan Enthusiasts). Even if we don't run a lot of the trails around there, it will be fun to watch the Jeepers during the Easter Jeep Safari (same time as goneMOAB).
    Are you interested in showing up for that event? More info here.
  • bob_pathbob_path Member Posts: 14
    Does anyone know where I can purchase a chrome exhaust tip for a 2001 Pathfinder? I saw the picture in message #5409 by phil47 and it looked great. I checked with my local Nissan dealer in New Jersey to no avail. Also has anyone upgraded the speaker system in their pathy.
    Check out the Accessories and the Mods boards in the Owners Club linked above too.
    Steve
  • sivi1sivi1 Member Posts: 82
    did nissan replace rotors under warranty. i had a 96 4runner and they took care of it. now have 02 le, just wondering.
    His chrome exhaust tip was for the Infinity QX4 Platinum Edition. I think he got it from an Infinity dealer.
    Don't know yet? I was out there 3&4 years ago for the EJS. I also lived in Durango CO, for college in the late 80's and got kinda used to UT as a place to go to get away from people.;-) Boy has Moab changed!! As much fun as the EJS is, it's a bit nutty. It would be cool to hook up w/other Nissan folks though even though I'm still runnin the Pathy almost stock. I'll have a better idea this spring.
    To anyone who has never been to the Moab area or Easter Jeep Safari (EJS), it is amazing country, and I would whole-heartedly recommend it!
  • nissangirlnissangirl Member Posts: 186
    Thinking about getting a brush/grille guard for an '02 LE Bronzed Gray....but can't find any pics to see what it would look like anywhere. Any clue as to where I might go to view pics?
  • mikelvonmikelvon Member Posts: 4
    Does anyone know why they softened the springs on the 2002 le? I had 4 average size adults in it with a picnic basket in the back and it bottomed out on every bump. Only 4500 miles on the new Pathfinder and I am certainly not impressed by this problem. Same thing happened the other day with 4 guys and 4 sets of clubs in the back. One of the guys owns a 2000 and says this has never happened to him. Do I need a fix from Nissan or go to after market air bags in the springs for such a light everyday load?
    thanks for any help you can give me.
    mike
    The springs weren't softened just for your 2002 LE. The rear springs have been 'soft' since 1996. Virtually every 96+ Pathfinder owner who has towed a trailer/boat or hauled people/cargo around has had this problem.
    The springs are designed to make the ride comfortable for empty/light loads. Otherwise your car-like Pathfinder smoothness would turn into pickup-truck harshness.
    Carrying 4 adults plus stuff isn't particularly a light "everyday" load. It's occasional. More likely an "everyday" load is driver + kids (which is far lighter). 4 adults plus stuff weigh in at at least 500 pounds, probably closer to 700. The guy with the 2000 will likely have the same issue, but he probably hasn't carried the same load as you over the same roads...
    Anyway, the solution is air springs. More info here.
  • crikeycrikey Member Posts: 1,041
    This also happens on my 2001 Pathfinder LE, so not sure if the spring change happened then. One thing is for sure, though, it is really jarring when that backend bottoms out.
  • austin_paustin_p Member Posts: 27
    FYI... for those of us in the US that want to obtain one of these beauties, your US dealer won't be able to find it. I just ordered one from a dealer in Canada and it was no big deal, even had them in stock. Cheap too, converted it was 56 bucks delivered.
  • smokey75smokey75 Member Posts: 434
    Hey SIVI1, the rotors were replaced on my 2001 warranty free of charge, no questions asked. I'm about to have them replaced again for the same problem...
  • li_sailorli_sailor Member Posts: 1,081
    Hi folks,
    I posted this a week or two back and got no reply so I thought a second try might help.
    I need a replacement for one of my rear seatbelts...our dog chewed almost completely through it. I know I could get it from my Nissan dealer, but I was looking for an alternative and I plan to do it myself. Anyone know of a source? I have tried every parts/accessories web site I know of with no luck.
    thanks,
    Tom
    There may be some liability issues with non-OEM parts or owner installed OEM "safety" parts that deters web sales. Salvage yard seat belts would be suspect since they may have "taken a load" in the accident that sent the Pathy to the wrecking yard. Or maybe there's so little call for them they aren't regularly stocked?
    Steve
    Does anyone know where I could see a picture of an '01 or '02 Path with a front grille guard or tail light guard?
    Never thought of that...maybe you're right. I assumed the installation would be straightforward, perhaps it's not.
    Has anyone ever replaced a seatbelt themselves?
    I guess if I don't hear anything otherwise, it's off to Nissan for me.
    The back seat lap pieces are probably straightforward but from a safety and liability perspective you're probably best to go for dealer installed new OEM parts.
    Never mind.
  • sallyann1sallyann1 Member Posts: 3
    I have a one-week old automatic SE with 650 miles on it. I have used three tanks of 91 octane gas with an average of almost 11 m.p.g!!! I noticed some pinging while gently accelerating - it stops when I reach 40 (or maybe I just cannot hear it at that speed.) While I expected lower gas mileage, I am very disappointed my mileage. I do not accelerate quickly and I attempt to keep steady speeds and I do not drive faster than 65 on the highway. The manual recommends 91 octane and one dealer told me to use 91; another dealer told me that I will get the same mileage if I use 89 or 87. I would like to use the lowest octane that will not harm the engine or diminish its performance. Can someone enlighten me about octane and offer suggestions as to whether I should have a dealer adjust something (you guessed it-I know very little about cars!!)? Thanks in advance.
  • bigorange30bigorange30 Member Posts: 1,091
    That is horrendous gas mileage. The Pathfinder/QX4 should get at least 14 in the city and 18 on the highway. Have you got something attached that would increase the air drag or the weight significantly? The octane issue has been discussed here at length before and someone said that this is a high performance engine and that high performance engines need the high octane. Some have even noted knocking or pinging with low octane. I use at least 91 octane because the manual recommends it. I would not want them to use it for an excuse to think they could void my warranty. They would not recommend this unless it was needed because they know it is a drawback for a potential buyer.
    No, I don't have anything attached nor have I towed anything. As far as weight, this mileage was with two average sized adults and a few bags of groceries, nothing heavy. I felt uncomfortable with the salesperson who told me that 87 or 89 octane was ok--he gave that 'I'll tell you anything to make a sale' presentation. I think I will take the car to the dealer and have it checked out. I don't think they did much in terms of preping the vehicle as I bought it rather quickly--I drove in, selected the car, and drove it off the lot within two hours. The only thing they did was give it a quick wash. Maybe something needs tuning up. Thanks for the response.
    The first 500 miles are the 'break-in' period anyway, and mpg is normally lower during this time until the engine 'loosens up' a little, but 11mpg seems too low.
    A couple of questions for you, though:
    What altitude do you live at?
    (lower octane is OK to use at higher altitudes. Most high-altitude fuel stations sell 85 octane in addition to 87 and 91.)
    What have the outside temperatures been like for you lately?
    (high outside temperatures can contribute to pinging with lower octane fuel and/or heavy engine loads)
    How are you calculating your mpg?
    Based on the figures you provided, here's the breakdown.
    650 miles / 11mpg = 59.6 gallons.
    59.6 gallons / 3 'tanks' = 19.69 gallons per 'tank'
    The fuel tank of the Pathfinder holds 21.1 gallons, but the "low fuel light" glows after about 17.5 gallons are used. Unless you've been driving pretty far after the lamp glows steady for each 'tank' of gas, you may be calculating your fuel economy incorrectly...
    The recommended procedure: fill up to pump shutoff. Do not overfill. Zero trip meter. Next fillup, record trip miles. Fill up to pump shutoff and record gallons pumped. Divide trip miles by gallons pumped to calculate MPG for the previous tank of gas.
    Note: Unless you consistently fill up to pump shutoff, you cannot accurately calculate MPG for every tank of gas. Also, the fuel gauge will read "F" for approximately 30 miles before it starts to move. This is due, in part, to the design of the Pathfinder's fuel tank.
  • wildcorgiswildcorgis Member Posts: 84
    I hope this doesn't sound patronizing but here's how I determine my gas mileage. I usually wait till I fill up and then I set my odometer to 0. When I fill up again I record my odometer elapsed miles and divide by the number of gallons I pumped in. Like xplorx4 say you have to consistent on how full you make your tank. I usually keep filling till the fuel pump handle has clicked off on me three times. The more you pump in the worse your mileage. I calculate mileage even when I fill half tank. My mileage has been around 17 with 50/50 cty/hwy driving. But with the A/C on and the change in gas formulation for the summer I got as low as 16.I experimented with regular gas and found it just wasn't worth saving a few bucks.
    Happy Pathfinding!!!
    Steve
    my 02 le pulling a 2500# trailer to fla never got less than 13 mpg. was going 75 to 80 mph just to stay with traffic. checked mileage every fillup. PS Smokey thanks for info on rotors.
