They are still in the process of updating their online catalog, so if you can't find something, try giving them a call.
The greasable shaft is the one that connects the front differential housing to the transfer case. It's located under the driver's side of the vehicle. There should be a Zerk grease nipple (for grease guns) on the driveshaft, about 1 foot from the transfer case.
On slippery surfaces such as wet asphalt roads, vehicle wheels may spin when the vehicle is accelerated. This wheel spin reduces acceleration, or causes the vehicle to swerve, thus decreasing vehicle stability. When the vehicle drive wheels begin to spin, the traction control system (TCS) controls the engine torque using an electronic control system, and it also controls automatic control shifting if necessary (for automatic transmission models). This reduces spinning of the drive wheels, and result in improved vehicle acceleration performance. It also improves the vehicle stability by swerving motion.
VEHICLE DYNAMICS CONTROL (VDC) SYSTEM (if so equipped)
When driving on slippery surfaces or suddenly avoiding obstacles on roads, the vehicle might swerve or slip. With the vehicle dynamics control (VDC) system, sensors detect these movements and control the braking and engine output to help improve vehicle stability while driving. The VDC system uses a Brake Limited Slip Differential (LSD) system to improve vehicle traction. The brake LSD system works when one of the driving wheels is spinning on a slippery surface. The brake LSD system brakes the spinning wheel to distribute the driving power to the other driving wheel. If the vehicle is operated with the vehicle dynamics control system turned off, all VDC and TCS functions will be turned off. The brake LSD system and ABS will still operate with the VDC system off. If the brake LSD system or the ABS is activated, the slip indicator light will blink and you may hear a clunk noise and/or feel a pulsation in the brake pedal. This is normal. While the VDC system is operating, you may feel a pulsation in the brake pedal and hear a noise or vibration from under the hood. This is normal and indicates that the VDC system is working properly.
This is a shot of the t-case with skid plate attached, taken from the passenger side.
Why do you wish to install the skid plate?
I had the same question for this forum a few months ago. I was told it was normal when in "Auto" or 4WD. In 2WD this doesn't happen. It has something to do with the engagement of 4X4. Glad you like your ride. I'm extremely happy with mine.
For the way these things perform and everything they give you, I think that's pretty good. I do run high test gas in it all the time, for what that's worth.
Dave
You can't miss it if it happens to you.
PS. The term "normal" is kind of a vague way to describe people, since everyone's perception of "normal" is different. The weight of "Normal" x 4 can vary by quite a bit! (i.e. a "normal" healthy man might weigh 180 lbs, and a "normal" healthy woman might weigh 140 lbs. for a total difference of 160 lbs- about the equivalent of an extra passenger).
Is $17,000 a good deal, considering the rust spots? We would be purchasing from a Nissan dealer.
wishnhigh1 "Nissan Patrol" Sep 15, 2002 1:34pm
Steve
I am still researching SUVs on the web (have not reached the stage of visiting the dealer yet) Does Pathfinder have a cramped rear seat? - have heard a number of views on this. The measuremnt is 31.8" of rear seat leg room. Most other SUVS of this kind provide 34" or more. Is there something in the design that makes the 31.8 livable with?
Dean, I just went to your site to pick up that part #, but it's "under construction". Could you post it again if possible? I'm gonna throw one on before our UT trip in a month.
Stinky Vent-
I has made a HUGE difference in our '01 SE if we run a bit of "clean" outside air through the system before powering it down. When I pull into our neighborhood, If re-circ. is on, I'll turn off the re-circ. button and let it pull dry air from the exterior for the 5 mins or so it takes me to get to the house. Granted the relative humidity here in Denver is usually 10-15% max. I think it also makes a bit a difference on how much you use the re-circ. vs. the fresh AC air-fresh air being drier coming into the system.
just some thoughts,
good luck,
gritz
What do y'all think? TIA.
My rule of thumb is that if they push to sell something then I won't buy because I know they are going to make a profit out of me.
Well, over labor day weekend, I drove a Trooper, Escape, & Explorer. We also drove a Pathfinder as well for my wife's review - I had already driven one.
First off, I'm about 6'4" tall. When I drove the Trooper, I couldn't see the traffic light when we were stopped! My eyes were at the same level as the top of the windshield! Plus, the seat didn't go back enough. Didn't like it. By the way, also sat in an Axiom - worse leg room than the Toyota Corolla we traded in.
The Escape was a little tight for leg/knees, but had plenty of headroom. Not bad. Not 0% financing however. Couldn't justify paying for a new one when I could pick up a used SUV with not too much mileage for a lot less.
The Explorer was awesome in a lot of ways. Fit-wise, it was the best. Seriously. We drove a 2002 or 2003 I think. Lots of bells and whistles. I wasn't up to paying new car price however, so I started researching older models, and found that the optional 3rd row of seats wasn't offered until 2002 I believe. Anyhoo, we nearly started looking hard for a used one anyway.
Then I found 2 2001 Nissan Pathfinders with less than 20,000 miles for around $21,000. We drove about 5 hours on a Friday night (as you might remember, my wife is (was) pregnant and was actually due on that date!). She was feeling fine... so it was okay. We ended up purchasing one for $21,200 with 16,000 miles, putting down @ $7,000 (including trade in here) and financing $14,000 @ 4.75% interest.
Whadda deal!
Reasons for buying:
Good headroom - no probs there. Leg room was just right at it's maxed out seat position. Wheel was very comfortable to reach to. Amenities were fine - we bought an SE w/ Bose CD player & power everything. No sunroof, and cloth seats - but I like the seats.. not your normal cheap-looking cloth seats. Additionally, after doing the research, we found that the 2001 version had a bigger 230HP engine - and has great pickup. Finally, the deciding factor over the Explorer was probably the reliability - as Consumer Reports lists it as one of the only recommended used SUVs out there.
- Mike & Jenn
2001+ all have a minimum of 240HP. 240hp in all the models with an auto tranny, and 250hp in the SE mated to the 5spd. ;-)
You will love it! We all do!
Gritz
With Recirc on, oxygen is only being replenished through leaks. And, Carbon Monoxide and Dioxide and odours go up ...
And with our Florida hot summers, recirculate really cools the engine down fast. Actually, I find that if I let fresh air in, the cabin becomes warmer. Without any rear vents, my kids perspire quickly. Recirc fixes that for me.
Most owner's manuals state that recirc is good to quickly heat up or cool down a vehicle (or avoid someone's poor exhaust emissions) but to avoid extended driving like that (I'm not sure about the PF manual, buy my 2001 Honda Odyssey manual sez somthing to that effect). Of course some fresh air is entering the vehicle even under recirc, but not nearly as much as when it is off. With 3 or 4 adults in the vehicle, I'm willing to bet the % O2 will drop.
Incidentally, I just found some billet grilles for 2000-2003 PFs at grille-tech.com. They look pretty good. Anybody use this outfit (or installed these grilles?). I'd like to get something installed before Winter when the gravel starts flying again (my rad looks like a war zone).
The ride seemed pretty bumpy, is that normal for Pathfinders? Every bump, joint, man-hole cover seemed as though it could be felt. Also when pulling up at traffic lights the bumpy asphalt (from heat during the summer) seemed to be felt easily and it would kind of rock back and fourth over it.
The steering also seemed to be affected a little bit by bumps and man holes. It would lose its track a little bit.
Overall we liked it, but we just would like to know if this is how all Pathfinders are.
Thanks for your time
http://dean.thayer.net/off-road/upgrades/tcaseskid/
Regarding recirc mode vs fresh air mode, I seriously doubt that hazardous gas levels are going to be an issue with continuous use of recirculate mode. The Pathfinder is hardly air-tight! What if you don't turn on the vents at all? I mean, come on, do you really think you're gonna suffocate because you're not sucking fresh air from the outside?
I nearly always run with the vents set to "fresh" air because, well, fresh air is nicer.... right? It helps keep from making the air feel 'stuffy' and keeps humidity down. It's also quieter to use than recirc mode and it really helps when you've got some passengers with strong BO. j/k...
Anyway, on really hot days or when I have drive in very dusty conditions (such as off-road), I run with "recirc" full-time. On especially hot days, its actually better to run the AC in recirc mode because the interior air temp will be lower than the exterior air temp. Same goes for really cold days- your heater does a better job heating warmed-up interior air than outside air.
I've never felt dizzy, short-of-breath, etc. due to lack of oxygen or excess of CO or CO2 when using recirc for extended periods of time. Moreover, I notice that the air tends to feel "sticky" after a while, mostly due to buildup of humidity. But it sure beats having dust blow all throughout the cabin!
Just my .02 guys.
