Visitor Agreement.
I am having the same problem. I have an infiniti g35 and the 6 disc cd player will not eject cd's it gives me a error code " cd err fo " could you tell me if i can remove discs from this code stand point or do i have to pay the 460 dollars to have them removed?Also, is it difficult to remove the center panels to get in to the switch itself with a meter?
thanks for the response!!
thanks so much.
i will defenatley keep you posted once we find out. again, thanks so much
Does anyone have more information on this issue ?
I have a little problem. When my Pathfinder is running or is shut off, I can really smell gas. There are no leaks. In fact I had one repaired because Nissan stopped
manufacturing the one line I needed. The smell is on the driver's side of the vehicle. It's like the odor from fuel comsumption is being pushed out somewhere and sometimes into the cabin.
Thanks for your help guys.
Tony (Tnich94@yahoo.com)
I need to know if my 2002 SE model Pathfinder is strong enough to haul and get a 19 to 21 foot boat out of the water using the ramp, because I want to put a trailer hitch to my PF but don't know if it has the power to get the job done or will it stay burning tires on the ramp while I have the boat on the water ready to come out. If someone knows please help me. Thanks
1. Is there a way to retune the engine so that I can use regular gasoline? (Or does someone make a computer replacement that does this?)
2. Does anyone have information about replacing my gasoline engine with a diesel? (Or is this too difficult/expensive?)
The first is that I have seen some reviews that there is transmission problems at 40 mph or so. Most refer to the the V6. Does anyone know if this problem is resolved or limited to V6 model? I did not notice it on my test drive.
Second item is handling over potholes. I noticed in the test drive the truck gets out of sorts when the front wheel hits pothole or any other bump in the road. Shakes quite a bit. Is this normal for this model?
Thanks for your help.
In Quebec, snow tires are now mandatory. Just wondering about the PFs in Quebec 1) Have you used snow tires before the new law and 2) If you bought snow tires for the first time because of the new law, what did you purchase ? I'm wondering just in case Ontario starts getting the same idea !
He says I will still have braking, just not ABS braking. Assuming I won't be driving on ice and snow, can I get by without ABS, or will my 'normal' braking be affected? I don't want to drive unsafe, but I don't want to drop $900 now if I can get by.
since the rad cap seal was deformed also (from trans fluid leaking into the coolant)
i was curious how many other parts are affected by the fluid?
(i told her to replace the radiator, cap, water pump and heater hoses too).
she will have to go back to the dealer for a trans flush, pepboys doesn't do a sealed tranny.
Moonroof standard on Pathfinder LE V6
Navigation system standard on Pathfinder LE V8
New LE V8 Value Package added, featuring DVD player, 7-inch color monitor for rear passengers and moonroof
New SE Premium Journey Package, featuring 17-inch machined aluminum-alloy wheels, RearView Monitor, roof rack crossbars, 10-speaker Bose® audio system, XM® Satellite Radio (XM® subscription required, sold separately), Bluetooth® and Intelligent Key
One new exterior color – Dark Slate
Simplified exterior and interior color combinations
I have the same problem for a 2002 Nissan Pathfinder. If you figured out the problem then can you please share how this was fixed.
Tony
