Mazda is not going to stop selling Tribs and Ford is still selling mucho Escapes. I'm just trying to cut my odds of making a bad choice.
Clear as mud, right?
And sho wha if I been drinkin'? Wash it to ya?
Actually, I just wanted to put up post #1000.
frank
murocflyer5@hotmail.com
I bought a loaded ES 4WD Trib at invoice COST! I used a fax attack to narrow down my choice of dealers in the Atlanta area who were interested in making a deal. With over 3000 miles on the vehicle, the only issue is the wind noise on the driver side which I can live with. I still think the Trib is the best value in a mini SUV. Good luck in your search. Spinner
frank
I won't be towing,and I'm looking for best economy.
Is anyone here driving this configuration, or is everyone driving the V-6?
Just thought it was interesting. Nothing on the Tribute still. Ours is going on 3,000 miles and no problems encountered. Runs great, handles like a car and looks good. Wife is still very happy with it.
Peace...
A noise can be heard when I brake in traffic, sharply when the front end dips.It is a sqawking noise.Whhen I turn RH at speed say 20km+ a clicking noise can be heard.I have had my vehicle at the dealer for the the past 4 days and they have changed some bearings.The problem still persists and I want my car back.They are still looking for the problem and are messing me around no end.Has anyone had this problem?If so please let me so I can let the clowns at the mazda Australia know.
Perhaps you already found out that dealers, transmission repair places, and some oil change places use a Fluid Change Pump that pumps the new fluid into the lines so that all of the old fluid is pushed out in front of it and there is almost no mixing. Otherwise, if you do it manually using just the drain, a lot of old fluid trapped in the torque converter and lines stays and contaminates the new fluid
Non mixing of new and old fluid is impossible. This was the procedure used on both my Honda and Toyota. If it was good enough for them, it should be good enough for my Ford. As easy as it is, I could change the tranny fluid out when I change the oil. The biggest reason to change the fluid is to check for particulates in the fluid. I didn't see any metal shavings on the magnetic pickup. I usually change the fluids out once a year, but if I step up the tanny fluid change now that I know how much it takes to quarterly, I shouldn't have any problems. Taking my Trib to the dealer is way too much of a hassle, not to mention the cost and the possibility of them screwing something up.
I'm looking at getting a Tribute this week, but I'm so worried about all the complaints on this board, ect... Is this car a lemon, or is it mostly negatibe hype? Are you guys happy with your Tribute, any complaints? Thanks much
sizzla123, there have been no recalls or investigations into the 02 Tribute. We are very happy with it. Now the minor fit and finish items could be improved a little, but you are getting so much vehicle in the Tribute for a little less cost. You simply need to drive one, and do some research on the NHTSA, IIHS-HLDI, Edmunds and other sites. I think after looking over everything you will find that the Tribute is a very good SUV for the money.
Zoom-Zoom
The air conditioner wiring harness may have been improperly installed, allowing some wires to rub against each other and eventually wear through their insulation, causing a short circuit, Honda said Wednesday."
No, Honda is not the perfect vehicle, but I have yet to discover one. But if you remember, the 01 Honda CRV had the lowest number of reported problems of any car made for that year. I would have to say that's pretty darn good, even competing with vehicles 3 times as much. In my opinion, Ford is bringing the quality of Mazda down. I was really dissapointed to see my wiring harnesses made in the phillipines. I thought I was buying a Japanese car, built by people who take extreme pride in what they do. Not by whomever can build something the cheapest because they pay their workers the least. What kind of quality can you expect from that?
I am interested in buying the Tribute or Excape, but I am interested in city and highway mileage that you are getting with the V6, auto and 4 wheel drive. I have been looking for a replacement for our 97 Ford Explorer and gas mileage and hauling are important to us. We a popup to pull.
Rey
Suspension - Maneuverability, handling and driving comfort.
Transmission - Driving feel.
Appearance - Exterior and interior.
Powertrain - PT control.
Details:
http://www.autoweb.com.au/start_15/showall_/id_MAZ/doc_maz0102164/article.html
I've owned ES-V6 Tribute since Oct 2000.
No stalling or major trouble. There was
fuel smell problem that was finally fixed
by a TSB.
Just recently, I removed the cross bars
from roof rack. Wind noise at highway speed
has gone done remarkably. I'd suggest this
simple fix if you don't use roof rack often.
I.I.
Good luck!
Steve
Steve
BTW, no action on the CRV Vs Tribute site since '01.
This makes me think of a couple of questions.
1. What is the viscosity of mercon ATF.
2. If 1 Qt works OK, why not use more or even run pure ATF while letting your motor idle in your driveway then drain?
3. I have seen how well ATF breaks down oil gunk, will it hurt your motor doing this?
4. What ratio is too much?
5. What will work better than this procedure without actually tearing into your motor?
Thanks for the info.
I wasn't aware of the stalling issue that some people have had with their vehicles. Guess I didn't do all my homework. Oh well, it seems to affect a small percentage of them, so maybe I'll get lucky.
As for noise, it's a lot quieter than the 1989 Nissan Sentra I traded in today.
Rich
I wonder if any Tribute owner has tried
those high performance exhaust system
for Tribute, like
Gibson's Single 2 1/2inch Stainless Steel Cat Back Exhaust System
Is it worth it? I'd like to get improved
acceleration. Thanks in advance for any
feedback!
I.I.
Granted I have only 100 miles on my new Tribute and no problems yet... Love it so far!
Informative board and I'll be sure to report my experiences with all.
FYI...My Tribute was built in June 2002....bought 8-15-02....Dark Titanium, LX, V-6 Auto...Moon Roof, 6 Disc CD changer, tow package, etc.....
Compared to all others...Tribute, hands down for quality and features for price is the best bet! Warranty is a plus....3 yr/50,000 mile bumper to bumper...free rental car and roadside service included... to much too pass up.
BTW...I've been driving Mazda Pick-ups for 17 years straight. My current vehicle is a '92 Mazda B-2600i extended cab that I have owned since new, just turned 100,000 miles and still going strong. Before that was a Mazda B-2000 single cab pick-up that served me well for 7 years and I sold for a nice sum after 7 years loyal use.
Traded a '97 Ford Mustang for this new Mazda Tribute...love it!
http://www.autoweb.com.au/id_FOR/doc_for0110114/article.html
Hopefully Mazda will bring out a tribute version if they do bring the Escape version to the states.
Odie
