Visitor Agreement.
via con Dios,
me.
In the city, I drove with the figurative "egg under the accelerator pedal"...no way, no how it's me! It's the car...period. I just hope the mileage get's better...Now don't you feel like an idiot!
It is obvious not all Tributes are having a milage problems and the best way to dismiss a warranty fix is to suggest the customer has a heavy foot.
Is you tribute always in overdrive (no light on)?
If you are in O/D and cruising at 66 MPH your Tach should read 2K RPM. If your RPM's are higher you may not be in O/D.
If you use Cruise control on a flat Hwy the RPM's should stay constant.
Notice if the Tach is steady or if the indicator jumps up in RPM's.
If RPM's spike upward whenever a bump is hit check the brake pedal switch adjustment.
If the RPM's spike upward it indicates the transmission is downshifting.
I hope these suggestions might help you solve your problem.
in response to currey, i'm using mobile 1 5w30 because that seems to be what i've been using for so long on everyting, and the 5w20 is a pain to find.
However, much to my surprise there was a fix, drove the sucker to the Mazda dealer and drove home in a 2001 626 lx v6. I don't look under the hood any more as I don't smell gas, all those other problems have vanished. I just get in and drive, don't really think about anything any more, what a relief, to finally be free of the service department.
http://www.hwysafety.org/vehicle_ratings/ce/html/0105.htm
http://www.hwysafety.org/vehicle_ratings/ce/html/summary_smsuv.htm
Drew
The many Escape-Mazdog recalls, shifting lever on the column and now the test results have negated my interest in the Escape-Mazdog. Several dealers in my area had the guts to add a $2000 additional markup to these "Marginal" vehicles. Good Luck.
If I remember correctly, there were others mini-SUVs with the same issue. It's tough to make a bag that doesn't injure you at 8mph, but keeps from being injured at 40mph. Because automakers faced lawsuits based on government regulations(high powered air bags), they fought for depowered bags. Some automakers just move the steering wheel forward a bit, in relation to the pedals, making for a very awkward driving position.
If you check out other non-SUV vehicles, you will see a bunch of marginal and poors - my last car a Cavalier, ranked poor in most catagories, but has been a top seller for years. Didn't seem to affect my insurance much either.
This test is one of many safety criteria to look at - the NHTSA gave the Trib 4 and 5 stars in their testing, and I've heard of other tests which give the Trib a good safety review. Again, I'm a little disappointed, but no regrets on buying the Trib (especially when my other choices faired no better on this particular test).
I'm sure you can find something similar in another brand. Look in any store that sells computer accessories.
P.S. You arent going to ruin the front end of your Tribute my putting on hideous brush guards, are you?
On a bigger SUV, it might not have that much of an adverse effect, but I had a brush guard on the front of a 2-door Suzuki Sidekick and it *definitely* made it nose-heavy. When driving the thing, it always felt like the nose was on the ground and the rear was five feet in the air.
Unless I planned on taking an SUV off-road on a regular basis where there was a strong possibility of damage to the lights/grillwork from shrubs, trees, etc. (not likely, esp. with a Tribute), I think I'd pass on buying a brush guard for any SUV I ever own.
2 Months with my Desert Metallic LS 4WD and my mileage has been ranging between 19-21 mpg in mixed driving, rarely using the A/C.
I sure was hoping to get closer to that "24 mpg Highway" rating when I bought it.
Oh well, maybe I wasn't being realistic considering the V6 and the size/weight of the Trib.
ALOHA FROM HAWAII...
I've been to four local Mazda dealers and spoke on the phone with two others and they all tell me the same thing - there are no models available with the Abs package, they will make no promises that if I order a Tribute with the Abs package it will ever show up. They talk about "filtering" at the manufacturing plant (pushing the order back until they have the parts for it) and the fact that we're not that far away from when the plant makes the change in model year.
I'd welcome comments from others on whether they are being told the same thing or if this is some form of sales tactic for the dealers to move their existing LX stock off the lot... I'd also like to know if I should hold out for the Abs package; is it worth it?
With that, I would assume you are still safer in the poor mini suv than the ave to good compact car.
Question, can you get the auto tranny in the 4 cyl, 2wd.
I am thinking of downsizing from a v8 explorer, wanting to get over 20 mpg mixed use driving. Not just 22 mpg when I drive dedicated highway, and the 4 cyl looked like it had the cushion to insure that. But, manual is out of the question.
I can not say for sure that this is nnot correct, but from the best of my understanding, production and parts supply is controlled by Ford. I am certain that Ford is responsible for the production mix, otherwise Mazda would be producing far less DX models.
