Visitor Agreement.
The new Jeep Patriot is taking some of the interest away from the classic Cherokee too, and then there's the Dodge Nitro concept that's based on the Cherokee platform that the media is following. Not to mention the Compass and Commander grabbing headlines.
Cherokee owners aren't getting any respect. :-)
Check out the Jeep Owners Club too.
canoeman
Canoeman
Anyone have any Ideas?
I've driven 60 miles on it already and still need it to get to and from work.
Please Help! :sick:
http://www.usjeeps.com/forum/viewtopic.php?p=21590&highlight=&sid=c566c83b7d938875a644b98e- e904607c
That is the code set on your computer? I checked several other websites just to confirm what your website said. Have you checked all your fuses?
Is this normal?
have 4.0 inline 6. 4 speed auto trans. 68000 miles.
With the head warped, the head gasket has probably blown. That will cause those symptoms.
This is my first post on here, I'm in Edinburgh in Scotland and I'm thinking of getting a 1994 Chrokee 4.0 Limited straight six. One I've looked at has 95,000 miles on it, but has had a LPG conversion, so I would get the equivalent of 50mpg.
What should I be looking out for if I buy it? Any advice you have for me will be greatly appreciated!
Triplechop
Do any standard Cherokees have heated seats?
Thanks, CK
Have a 2001 Cherokee Sport and want to install some good driving lights (moose up here in the dark can be scary). Probably on the front bumper, but wondered what you guys could recommend? I don't want to put in some super babies that require all kinds of space and extra electrics, just a relay and switch for me if possible. Maybe the Hella 500's?
What have you used, and how did you mount them?
Just let me know please!
When I have the heat on- the car while in idle (when it is not rattling) makes this strange noise that sounds like breathing~ it is a long ssssssssssss noise, then it sounds like it is being let out.
I thought maybe it was a vacuum leak-but can't find any of those........
the other noise is an occasional sharp CRACK seemingly behind my speedometer area or under it or something. It almost sounds like a rock or something hitting at the base of my windshield. Obviously it is underneath...but it happens about 1-2 times a week when I am going over a bump or something. It is like something is loose and it pings off of the body somewhere in there....
any thoughts on either of these strange noises???
:confuse:
I would suggest a bottle of Techron/Chevron Techroline injector cleaner for a few tanks of gas and see if it smooths out. If not have the injectors professionally flushed, it's not that expensive. Also for good measure change the disti cap and rotor and even the plug wires. That is the first thing that I do when my 4.0 starts acting tempremental. Not a big $ loss if it desn't fix it.
Always put injector cleaner in the tank about every 10 fill-ups. I buy a few bottles when on sale. Also run Chevron once in a while. It has techroline which is a very good cleaner.
Now I have a few floating lifters but after 215k miles I can't complain. I'll do a top end for $400 parts and get another 200K miles easily. I may even rebuild the engine for around $800 parts (since I just put a 33k mile rear axle in it) and get a million miles outta her. I love this Jeep!!
I mentioned "soft" brake pads. There are differing performance levels of brake pads. The "soft" pads tend to offer better braking performance, less noise, but at the expense of how long they will last and the large amount of brake dust created. The "hard" pads tend to last longer, create much less dust, but at the expense of performance and more noise. I tend to stay in the middle.
I have a problem that hopefully someone can help me with, being that the mechanic couldn't. In the morning when I start up my Jeep (92 Cherokee 4.0L HO) it runs decent, but if I drive for say five minutes, shut it off for a minute or two, and then start it back up it will idle from 1500 down to about 600 and when I hit the gas peddle to kick the idle up there is no change. It's almost like I am not touching the gas at all, so then I floor it and the RPMs will gradually build and there is a backfiring sound in the header. After the RPMs reach 3000 exactly then it breaks loose and everything is hunky dorry again until I shut it off and have to redo the whole process again. I was thinking that it could be the Idle air control valve, but I am not sure. If anyone can help I would sure appreciate it. Thank you.
