Visitor Agreement.
However, good winter tires could mean the difference between life and death in some situations. How much is that worth to you? To me it's priceless, so I get the best winter tires I can buy, evne though I drive an AWD car.
I love winter tires. That said, I generally stick with all-seasons, unless the car comes with summer-only tires.. Nobody in my car has died.. yet.
I suggest trying out the all-seasons... You'll find out pretty quick if you'd rather get the winter tires.
If you are asking if I recommend winter tires, then that is a different answer... I definitely do... My wife's car has them, and they are magnificent.
regards,
kyfdx
They appeared to perform really well, excellent traction and braking performance on icy surfaces. I could only break traction if I floored my Outback XT and let the turbo boost build up.
It is hard to make a direct comparison with the Blizzaks since I now have a totally different car. But the X-Ice does appear to be top-notch on ice.
They are a nice to have IMHO. Here in the NW 'burbs they do a great job of clearing the snow as long as it isn't rush hour so snows are not an absolute must have.
One big reason for my getting them for the Ody is my wife hauls around the kids in it so safety was in my head. Second was that I've never had good luck with Honda alloys and winter - the ones on both my 91 and 98 Accords looked horrible after a couple of winters so steelies and snows protect the Ody rims.
Also... I was thinking of placing them on my stock steelies (with covers) and then getting summer rims and tires in spring? Any thoughts? Will the winter wear be too much on the stocks?
Your advice is appreciated!
Possible sizes for that rim on a CR-V:
215/65-15
225/65-15
205/70-15
regards,
kyfdx
Winter tires are called winter not only because of of snow/ice performance.
Krzys
Has anyone tried the Kumhos through a full winter season, and if so, what's your verdict? Any complaints or regrets?
One concern I had is that Tirerack.com seems to have discontinued this model...
Thanks a bunch!
I get mine mounted at Wal-Mart so I didn't have to buy extra wheels. They are more convenient to store unmounted.
My Outback XT equipped with new X-Ice got through it all with flying colors. It felt sure footed on all these surfaces, from icy dirt road to 6" of snow. Twice in the last, several 4WD vehicles with lesser tires were unable to get up our long steep hill. I never had any problems, I was even able to stop half-way up the hill to offer help, and continue at will.
I think they offer about 95% of the Blizzak's ice traction. On smooth wet ice they are not quite as sticky as the Blizzak WS-50. But on every other type of slippery surface, they did just as well. Given that they are superior to the Blizzaks in terms of handling, steering response, ride, noise comfort, and braking on dry/wet pavement, I think they are an excellent choice. This is especially true for a performance car and/or someone who does a lot of highway driving. Since they are not as soft as the Blizzaks, I also expect they will have better threadwear.
Sly
Can anyone suggest a tire available in both 18" and 19" that is rated for snow?
connortirerack, "Ask Connor at The Tire Rack" #574, 17 Dec 2004 5:14 pm
Any advice would be greatly appreciated.
I run them at my regular pressure and they seem fine.. Setting them at a higher inflation would help in theory, since you would have less tire on the ground, and more pounds per square inch of contact patch..
But, if you are spinning, it is possible that the high pressure is keeping the "grippy" part of the tire from making contact... lower your pressure and see if that helps...
regards,
kyfdx
I hit the crest of the hill and started down at about 10 - 15 mph, and immediately hit the brakes, with the ABS going all the way down. The Legacy stayed straight down the center of the road and came to a stop at the bottom. White knuckles, but OK. If I had been on the RE92's we would been in the ditch.
It's snowing on Mad Town today and now I will get a chance to try the Blizzaks on the Civic! Yee Haa!
You are a true believer. Thanks for the great post. I enjoyed every word of you experiences in the WI ice. Keep us posted.
Bob
Well said! I'm always amazed at how many people are willing to compromise on the single most important safety feature on their car: those 4 little patches of rubber!
Bernie
But, that is just me..
kyfdx
(And Yes, they are great in the snow.)
The one of the things about winter tires is that they are heavily siped (for increased "bite"). When the tire is worn down to the point of there is little to no more siping visible, it's time for new tires
Heard of it.... no experience..
Click on the link that Steve provided... then just search that discussion for "siping" (no quotation marks).. You'll get quite a few messages about it....
Most times in the winter the roads are fine for 2WD, I drive a front wheel drive Focus as my commuter, rarely do I need to park it in favor of my 4WD Titan.
Just remember not too get overconfident with your all season tires, make sure you buy winter tires. Lots of people make that mistake and end up rubber side up in the ditch.
