Run Flat Insurance
MLB999MLB999 Member Posts: 12
edited November 2014 in BMW
Looking to see if anyone has any thoughts on the run flat insurance currently offered by BMW.
With past BMW's, I purchased their run flat insurance through Fidelity - had several tires damaged via potholes - and never had an issue with their service in covering a replacement.
We are getting a new 2-series convertible, and it appears that the insurance is now offered through Safeguard. There seem to be quite a few complaints on Safeguard through the better business bureau.
Any thoughts on this? Also, any idea what a fair price for this insurance would be? Thanks!
    I'm rather against buying into the whole run-flat scene. First they give you a tire that supposedly will "save" you the anxiety of a flat, only to have you face a $350 replacement cost when you DO drive on it while flat. How much easier to just carry a small spare tire kit? THEN they want to charge you a hefty sum to insurance the run flat from damage. It strikes me as almost a double-dip into your wallet.
    If I were you, I wouldn't take the insurance---I'd run the run flats until they wear out (soon enough I'm afraid) and then get go-flat tires and a spare tire kit, or a tire sealant and air pump.
  • MLB999MLB999 Member Posts: 12
    Mr_Shiftright - thanks! That's pretty much what I was thinking. My car will be leased. Do you know if there will be an issue returning the car without run flats on it?
  • kyfdxkyfdx Moderator Posts: 275,635
    There will definitely be charges for not having run-flats... Take the run-flats off now, and put the other tires on... swap the runflats back on, before turning it in.
  • karhill1karhill1 Member Posts: 165
    Taking off the run flats could be problematic. Since there is no spare tire, having a flat tire could be quite expensive and quite an annoyance. Of course, you could buy a spare rim and tire and carry it in the trunk. However, that would be expensive and a further annoyance.
