Visitor Agreement.
Like I said, the NHTSA Service Bulletin Number does work on the Chrysler dealers' computers. This is the only company that I have had experience with in the past 2 years with my piece of crap 300M. When I gave the dealer this number, they were able to access the TSB with only that info. The programs you use are evidently different and require a different process to find what you're looking for.
At any rate, I'm glad you're able to help so many people find the info they need.
fastdriver
NO problem. I just was knocked for a loop when I read your message because I've been here for 2 years and have never had a problem with anyone in any Edmunds topic- well, maybe one jerk in the old wax/polish topic. That was ages ago.
I come to these boards for info, help and to share my experiences with others in the hopes that they will NOT have to suffer the same problems when trying to get their cars fixed right the first time by the wonderful "5-STAR" Chrysler dealers! If they don't improve their quality soon, no one will have to worry because there won't be any Chrysler left. How much lower can their stock go before everyone bails out?
fastdriver
I'm not sure how this relates to TSB's. Do you suspect that there is a TSB for this problem?
Your host, Bruce.
Pat
I am new here. Just got a 2000 Pontiac Grand Prix GTP last week and have three problems with it:
1. There is a crackling noise coming from the fan
2. A clinking noise from the rear door/passenger seat area on rough roads.
3. A metalic jarring noise over pot and holes at speeds over 30 mph.
Have had the car in with the dealer already. For the fan they said "cleared leaves and debris." Noise still there. For the clinking noise, they replaced some spring. And they couldn't duplicate the jarring noise.
Wanted to find out if anyone has any information that can help me. I am taking the car back to the dealer next week.
Can't help you with your problem, but I have a question- you've had the car for a week and they cleared leaves and debris for the crackling noise with the fan?? HOW did you get leaves and debris in there in a week? It's summer. What leaves are falling already? The only thing I can think of is that they have had this car on their lot since the fall and had it parked near trees?? And I thought my "5-STAR" Chrysler dealers came up with some good excuses! LOL.......
You might try to post this question in the Sportscar area, topic #1615- Pontiac Grand Prix.
fastdriver
I have no clue how the leaves got there. Mentioned it to Pontiac customer support and they also wanted to know how leaves can get into the HVAC. Anyways, will be taking the car back to the dealer this week. Called up Pontiac and they called the dealer to fix the problem. Thanks for the info on topic 1615.
aam1
Pat
Thanks ahead of time.
JRG48
Try these-
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm
http://www.alldata.com/consumer/
fastdriver
Don
One thing you can do to learn is check out the automotive bulletin boards,forums or message boards.As far as I am concerned,there aren't that many good forums on the net.
I have three favorites(not necessarily in this order):
Edmund's (you couldn't have guessed that one)
Automotive Rebuilder
BAT Auto Technical
Those are my favs,there may even be more good ones,but most are kind of light on the technocal info.Hope this helps.
I have a 1993 Chevy blazer that is giving off an odor, and idles and runs rough. I took it to the dealer and they said it is CMFI and that it would cost over $1000 to replace.
I looked at alldata and there is a TSB (476516) that says to "check" the CMFI. Should i extrapolate this to mean that they should replace this for *free*. What does a TSB means in terms of repairs.. when is it free to the vehicle owner ?
I also did some checks and the CMFI is around $500 (more expensive than i want ot hear). I was thinking of doing it myself. Any pointers or advice on doing this would be appreciated.
Thanks for the response. The Chevy dealer (i hope) already did the diagnosis, because my local mechanic said it was an EGR valve and that there was a TSB for that. So i took it to the Chevy dealer and he said based on the diagnosis, it was not the EGR valve, but the CMFI.
I cam home and start doing my homework .. and then found that there is yet another TSB for the CMFI. My question is: am i entitled to get the CMFI replaced for under TSB with no charge ?
Thanks again,
Paul
After engine warmup and at about 1000 rpm and
under light acceleration I have a shrill whistling
noise coming from the engine, firewall area or
dash, can't really tell. It goes away after about
1700 rpm. On slowing down it comes back when almost
stopped and while idling you can press the
accelerator just barely and it whistles.The fuel
press. regulator and IAC valve have been replaced
with no luck. Of course the shop can't duplicate
the problem. Other than that I love the car. Plenty
of pep and good gas milage.The noise is there with
the A/C on and off so not that. Anyone else had a
similar problem?? Does anyone know if there is a TBS out on this subject?
When I replaced the plugs the first thing I
noticed is that one plug was burning with a white-
spray paint type of coating on it. The rest were
burning dark as normal for the 70,000 on them . But
the one in the back cylinder was white. I replaced
all of them . 1000 miles later the mis is back
So I replaced the plug in the one rear cylinder
with another plug and the car ran a little better
but the new plug was burning white again.
Does anyone have any clue what that means when a
plug burns white. The car runs with a bad mis and
when I rev it sometimes it backfires in the
cylinder. Could it be a hung up valve doing this or
could it be an injector ??? Anyone with info please
help I am losing my mind over this thing...
THANKS.
83-96-07 AM Station Switching, Cross Talk or Overload
SUBJECT: AM STATION SWITCHING ON STRONG LOCAL STATIONS, "CROSS TALK" OR "OVERLOAD" (INSTALL IN-LINE ANTENNA JUMPER)
MODELS: 1998-99 BUICK CENTURY, LESABRE, PARK AVENUE, REGAL 1998-99 OLDSMOBILE INTRIGUE 1999 OLDSMOBILE ALERO 1998-99 PONTIAC GRAND PRIX WITH REAR WINDOW ANTENNA SYSTEM
CONDITION:
SOME CUSTOMERS MAY COMMENT ON SWITCHING BETWEEN LOCAL STATIONS OR CROSS TALK IN METROPOLITAN AREAS WITH SEVERAL STRONG AM STATIONS. THEY MAY ALSO REPORT A HIGH PITCHED WHINE WHEN CLOSE TO HIGH TENSION POWER LINES. RECEPTION IS NORMAL WHEN OUTSIDE METROPOLITAN AREAS OR IN RURAL AREAS. THIS CONDITION OCCURS ONLY WITH THE REAR WINDOW ANTENNA SYSTEM.
THIS IS NOT A POOR RECEPTION, STATIC OR FRINGE AREA/WEAK STATION ISSUE. IT SHOULD ONLY OCCUR WITH THE REAR WINDOW ANTENNA SYSTEM, NOT WITH A FIXED MAST OR POWER ANTENNA.
CAUSE:
VEHICLES WITH THE REAR WINDOW ANTENNA SYSTEM MAY EXPERIENCE CROSS MODULATION FROM MULTIPLE STRONG LOCAL STATIONS. THIS IS ALSO REFERRED TO AS AM CROSS TALK OR OVERLOAD.
THIS CONDITION WILL BE CORRRECTED EARLY IN THE 1999 MODEL YEAR WITH INTERNAL CHANGES TO THE RADIO.
CORRECTION:
1. TEST DRIVE THE VEHICLE TO DETERMINE IF THE CONDITION CAN BE DUPLICATED. IF IT CAN, UNPLUG THE ANTENNA FROM THE REAR OF THE RADIO AND TEMPORARILY PLUG IN A FIXED MAST TEST ANTENNA. TEST THE VEHICLE AGAIN AND DETERMINE IF THE CONDITION IS CORRECTED. IF IT IS, PROCEED TO STEP 2. IF IT IS NOT, USE NORMAL RADIO DIAGNOSTICS TO DETERMINE THE CAUSE.
2. REMOVE THE RADIO AND ADD AN IN-LINE ANTENNA JUMPER WITH INTERNAL SUPPRESSION (P/N 09369442). THIS JUMPER PLUGS INTO THE RADIO AND THE ANTENNA PLUGS INTO THE JUMPER.
IMPORTANT:
PLUG THE JUMPER ONLY INTO THE BACK OF THE RADIO. ADDING THE JUMPER AT ANY OTHER POINT IN THE ANTENNA SYSTEM WILL LOWER THE EFFECTIVENESS OF THE FIX.
ADDING THIS JUMPER WILL NOT CORRECT ANY RADIO NOISE CONDITIONS, NOR IMPROVE ANY OTHER AM OR FM RECEPTION CONDITION EXCEPT THE SPECIFIC CONDITION LISTED ABOVE. THIS JUMPER CHANGES THE IMPEDANCE OF THE ANTENNA AND MAY ACTUALLY RESULT IN A SLIGHT DEGRADATION IN FRINGE AREA PERFORMANCE.
PARTS INFORMATION:
P/N DESCRIPTION ================ ====================================
09369442 CABLE ASSEMBLY, RADIO ANTENNA JUMPER
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
WARRANTY INFORMATION:
FOR VEHICLES REPAIRED UNDER WARRANTY, USE:
LABOR OPERATION LABOR OPERATION NUMBER DESCRIPTION TIME =============== ================================== ===============
R0750 RECEIVER, RADIO RETURN TO AC-DELCO USE PUBLISHED REMOVE + REPLACE LABOR OPERATION TIME
ADD: TO INSTALL JUMPER 0.1 HR
USE TROUBLE CODE 93
FIGURES: 00 ATTACHMENTS: 00
GENERAL MOTORS BULLETINS ARE INTENDED FOR USE BY PROFESSIONAL TECHNICIANS, NOT A "DO-IT-YOURSELFER". THEY ARE WRITTEN TO INFORM THOSE TECHNICIANS OF CONDITIONS THAT MAY OCCUR ON SOME VEHICLES, OR TO PROVIDE INFORMATION THAT COULD ASSIST IN THE PROPER SERVICE OF A VEHICLE. PROPERLY TRAINED TECHNICIANS HAVE THE EQUIPMENT, TOOLS, SAFETY INSTRUCTIONS AND KNOW-HOW TO DO A JOB PROPERLY AND SAFELY. IF A CONDITION IS DESCRIBED, DO NOT ASSUME THAT THE BULLETIN APPLIES TO YOUR VEHICLE, OR THAT YOUR VEHICLE WILL HAVE THAT CONDITION. SEE A GENERAL MOTORS DEALER SERVICING YOUR BRAND OF GENERAL MOTORS VEHICLE FOR INFORMATION ON WHETHER YOUR VEHICLE MAY BENEFIT FROM THE INFORMATION.
COPYRIGHT 1998 GENERAL MOTORS CORPORATION. ALL RIGHTS RESERVED.
© Copyright General Motors Corporation. All Rights Reserved.
Pat
Service Bulletin Number: DCS 2105
Bulletin Sequence Number: 006
Date of Bulletin: 9510
NHTSA Item Number: SB046378
Make: VOLVO
Model: 960
Year: 1992
Component: ENGINE:PULLEY:CRANKSHAFT
Summary: A COVER PLATE WAS INTRODUCED INTO PRODUCTION DURING SPRING 1995. THIS COVER PLATE WILL HELP PREVENT INGRESS OF WATER/DIRT ONTO THE REAR CRANKSHAFT SEAL SURFACE AND/OR THE STARTER.
Now, according to the paper trail (all the invoices) the above mentioned cover plate was not installed until the last time the seal was replaced (about 2 weeks ago). Notice that the date of issue of this service bulletin was 4 months before my seal was replaced the first time (while under warranty). My question is, shouldn't I be reimbursed for the last two times the seal was replaced since it wasn't done correctly the first time?
Oh, by the way, the car is BACK in the shop and now they are telling me the starter is bad...isn't that coincidental that the cover plate in the above TSB mentions the starter too...
I would certainly bring this TSB to their attention and let them look it up on their own computer to get the full printout. Sounds like they messed up. If you don't get results from the dealer, call Volvo customer service and see what they say.
fastdriver
engine.
During cold starts the engine knocks. The Ford
dealer changed the fan clutch and belt. No help.
Now Ford says they have several reports of engine
knocks and recommend replacing the engine with a
new and improved model.. WOW!!Has anyone heard of
this service bulletin?
My problem is that I have a 97 Suburban with option code KNP (Auxillary Transmission Oil Cooler) and this option is not on my truck, meaning I paid for it and it is also posted on inside glove box with all other option codes. But there is no Trany oil cooler installed.
WHATS UP WITH THAT?
fastdriver
My problems is that I found out 3 yrs to late. If anyone else out there has option code KNP (Auxiliary Transmission Cooler) just beware, you may not have it.
Also, I guess it is just 1999 models with the TSB for that.
Service Bulletin Number: 8195
Bulletin Sequence Number: 123
Date of Bulletin: 0002
NHTSA Item Number: SB612409
Make: FORD
Model: CONTOUR
Year: 2000
Component: SUSPENSION:SINGLE AXLE:REAR
Summary: SOME VEHICLES BUILT ON DECEMBER 13, 1999, AT KANSAS CITY ASSEMBLY PLANT MAY EXHIBIT A CREAKING
OR GRUNTING TYPE NOISE FROM THE REAR SUSPENSION.
Service Bulletin Number: 000101
Bulletin Sequence Number: 103
Date of Bulletin: 0001
NHTSA Item Number: SB610343
Make: HONDA
Model: ACCORD
Year: 2000
Component: LIGHTING:GENERAL OR UNKNOWN COMPONENT:INSTRUMENT LIGHTS
Summary: INFORMATION ON AVOIDING DASHLIGHT FLICKER ON SOME VEHICLES. *TT
Or does this only apply to a recall?
-MazNut
TSB= Technical Service Bulletin- that car companies issue to their dealers. Some are for informational purposes only and some are for how to's on problem areas.
Your car only has a 30,000 mile warranty and not 36,000? There is a possibility that if you paid for a repair that was discussed in the TSB's that you could get a rebate. Not sure exactly how that would work, but Mazda should be able to clarify it for you.
You can check here to see all the TSB's issued for your car. Just put in the appropriate info.
Hope this clarifies things somewhat.
fastdriver
http://www.edmunds.com/edweb/editorial/features/tsb/index.html
Pat
Sedans and Women's Auto Center Message Board
Coolant Seepage At Underbody
Auxiliary Rear Heater Line GROUP: Heater & A/C
Hose Connection(s)
MODELS:
1996 - 1997 (NS) Town & Country/Caravan/Voyager
1996 - 1997 (GS) Chrysler Voyager (International Market)
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH REAR AUXILIARY
HEATER.
SYMPTOM/CONDITION:
Coolant seepage at rubber hose crimp connection(s) and/or the quick-connect fitting(s) of the underbody auxiliary rear heater coolant line hoses.
DIAGNOSIS:
Raise the vehicle on an appropriate hoist and inspect the crimp and quick-connect fittings of the underbody auxiliary rear heater coolant line hoses. If coolant is evident, perform the Repair Procedure.
PARTS REQUIRED:
2 04882938AB Hose Assembly, Heater Aux. Rear, with Quick Connect
**2 04897046AA Hose & Clamp Assembly, 15 mm Heater**
NOTE: DO NOT USE ANY OTHER CLAMPS FOR THIS APPLICATION. IF SCREW
TYPE CLAMPS ARE USED THE LEAK WILL REOCCUR OVER TIME
BECAUSE OF SHRINKAGE OF THE HOSE MATERIAL AND RESULTANT
LOSS OF TENSION APPLIED BY THE CLAMP TO THE HOSE.
It isn't covered under a warranty.Unless you have an extended manufacturer's warranty.
Sorry, but unless you have an extended warranty, it is at your cost.
The article has great information and features one of our best contributors to this board - although you might not recognize him right off the bat (er.. sorry)!
(Hey 0patience - that's great work you are doing at your site!)
Pat
Sedans and Women's Auto Message Center Message Boards
It is taking longer on some stuff than I have patience for though. LOL!!
It goes to show you that there are many professional mechanics who are honest and care.
Tony is providing all kinds of help at his website, including the full text of TSBs free for the asking.
Of course if you ask him in any of the discussions on this board, he'll provide whatever information he can to help you out, and you won't even have to go to his site. But check out his site anyway - he has been so helpful to all of our Town Hall members, you should take a look at what he and his colleagues have put together, all in the spirit of being helpful to we, uh, rather, um, not-so-knowledgeable consumers.
Thank you, Tony. You truly have the spirit of our Town Hall community!
Pat
Sedans and Women's Auto Center Message Boards
We are fortunate to have many professional mechanics who frequent our site and provide what they can. Including alcan, who frequents here(I figure he can e put on the spot too.)LOL!!
Guys who like to help and are proud of the job they do.I'd like to take the credit for our site being where it is, but we have 100 professional mechanic members and there is little the guys can't figure out.For us, Edmunds is a great place for us to see some of the problems that consumers are having on a large scale.
