Are you having a problem with the transmission?
That TSB is a new release and even some of the dealers don't have it yet.
Sorry if I came off wrong. I like to know why folks are looking for certain TSBs, as sometimes the one they think they need, isn't. But other ones may be.
Plus, ones like that can be a bugger to come up with.
This is the only one I could find remotely related to your problem.
I wonder if you can help me get Chrysler TSB 19-002-04 (clicking noise in steering column)? The column in my 2002 Dodge Neon was already replaced in February under warranty because of this problem. That seemed to help for a while, but now the new column is starting to click too - and I'm out of warranty. It seems that the TSB was issued in April. I'd very much like to know what the problem is really about, and if it is safety related. Many thanks in advance.
any help would be GREATLY appreciated!
STEERING
S0006-01
December 21, 2001
Title:
STEERING RACK END NOISE
Models:
'98- '99 Corolla
TSB Update Notice :The information contained in this TSB updates ST001-00 dated January 28, 2000. Revised text is shown with asterisks and underlined.
Introduction
Some 1998 - 1999 model year Corolla vehicles may experience a squeaking noise from the front suspension. To improve this condition, production parts have been changed.
Power steering rack end sub-assembly.
Part numbers can be obtained from your dealer.
It is in a pdf file and some versions may not open it. If it comes up blank, let me know.
Dealer confirmed that it needs the intermediate steering shaft. Is there such a thing as a "silent recall" on this repair? Any chance a letter to GMC customer service would help me?
If there is no special "silent recall" deal on this; I guess I'll order the part myself and have my local independant shop do the fix.
Is the steering shaft grease job the kind of repair that most independant shops would be familiar with; or is it a GM dealer type job?
Any repairs on the TSB would be subject to your cost and not under warranty.
97-021
March 28, 2000
Applies To:
1996-00 Civic 2-door with certain VINs
Front Windows Bind or Have Come Out of the Run Channel
(Supersedes 97-021, dated February 22, 2000)
SYMPTOM
One or both of the front windows are binding or have come out of the window run channel.
PROBABLE CAUSE
1996 and 1997 models thru the affected VINS:
Faulty window regulator, and the glass run channel is not seated correctly in the window channels.
1997 models after the affected VINs, all 1998-99 models, and 2000 models thru the affected VINs:
The glass run channel is not seated correctly in the window channels.
Replace the window regulator(s), and reinstall the glass run channel.
Reinstall the glass run channel on the vehicles shown.
CORRECTIVE ACTION
1996 and 1997 models thru the affected VINs:
Replace the window regulator, and reinstall the glass run channel. Replace the glass run channel if it is damaged.
Reinstall the glass run channel. Replace the glass run channel if it is damaged.
I am taking my 2003 Outlander (AWD) in for service Monday. It has a strange vibration (noise) that seems to be coming from the exhaust while accelerating. I have inspected the exhauset myself, and do not see anything that is loose. The Edmunds site shows a TSB 03-15-002 for this particular vehicle, that is labled as "Strnage exhaust noise under acceleration". I was wondering if anyone had any info on this TSB (cause, corrective action, etc...), so I will be a little better armed when I take it in on Monday. Thanks
earlier message:
After replacing the alternator and a fairly new battery Jeep still had the same problem of not charging. An auto electric shop diagnosed the pcm as the problem and the price for one is quite expensive. As a fix he suggested we could install an external voltage regulator but he would not provide any help to how I would install it. The voltage regulator is a Transpo 2 plug electronic type. I have read my Hanes book but it was of no help. Any help, suggestions or opinions would be greatly appreciated.
As stated in the summary, owner's and service manuals for my vehicle (and similar) do not show or refer to axle/differential service intervals. GM does not usually number service bulletins that way and I've been unable to find any reliable information. Hopefully, someone can help.
Here is what I got when I used the search on GM's information system.
Sorry, No documents matched the number: 3001
Here is all I came up with on the maintenance schedule from GM's information.......
Add fluid as needed. A fluid loss could indicate a problem; repair as needed. Check vent hose at transfer case for kinks and proper installation.
DIFFERENTIAL FLUID
FRONT AXLE (FOUR-WHEEL DRIVE)
SAE 80W-90 Axle Lubricant (GM Part No. U.S. 1052271, in Canada 10950849).
FRONT AXLE (ALL-WHEEL DRIVE)
SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 12378261, in Canada 10953455) meeting GM Specification 9986115.
REAR AXLE
REAR AXLE (STEERABLE)
Synthetic Axle Lubricant; use only GM Part No. U.S. 12378557, in Canada 88901362.Do not add friction modifier.
DRIVE AXLE FLUID CAPACITIES
Front Drive Axle (8.25") 1.40 liters (1.48 quarts)
Front Drive Axle (9.25") 1.53 liters (1.62 quarts)
Rear Drive Axle (8.6") 2.03 liters (2.15 quarts)
Rear Drive Axle (9.5") 2.6 liters (2.75 quarts)
Rear Drive Axle (10.5") 2.6 liters (2.75 quarts)
Rear Drive Axle (11.5") 3.62 liters (3.83 quarts)
NOTE: ALL capacity specifications are approximate. When replacing or adding fluids, fill to the recommended level and recheck fluid level.
If they can provide the GM document number, I can get the info.
Does anyone has a copy of TSB (40I) for 2004 Toyota Sienna regarding radiator leak? Thanks.
Title: Interior - Seat Headrests Uncomfortable
Replace the headrest.
There are 4 part numbers, depending on whether your's is leather or cloth.
Vehicles under warranty, use labor operation C6690.
If your vehicle is under warranty, see your dealer.
Any help in location the information relevant to this TSB is greatly appreciated.
Build Prior To VIN Breakpoint 5F112989
Part Number Description
10375552 Restraint Asm - P & D/Seat HD (Leather Gray)
10375553 Restraint Asm - P & D/Seat HD (Leather Neutral)
10375555 Restraint Asm - P & D/Seat HD (Cloth Gray)
10375556 Restraint Asm - P & D/Seat HD (Cloth Neutral)
A TSB that has just been released a few days ago and you are asking for it?
Not surprising, I couldn't find any TSB for transmission lag. The latest TSB I find for the Lexus was released April 1, 2005. But it wasn't for the transmission.
Do you have a TSB number?
Mostly informational TSBs.
Title:
MAIN BEARING JOURNAL DIAMETER
STAMPING LOCATION REVISION
Models
'04 - '05 ES 330 & RX 330
Title:
ENTERING VIN DURING ECM (PCM)
REPLACEMENT AND/OR DTC P0630
Models:
All '05 Models
March 15, 2005 is the newset TSB I can find.
These TSBs were released in March for all Lexus.
04-05 ES330 Engine Controls - MIL ON and or DTC P0346 Set
98-05 LX470 Exhaust System - Tailpipe Joint Clamp Installation
04-05 RX330 Fuel System - Underhood Ticking Noise at Idle
01-03 RX300 Fuel System - Ticking Noise From Engine Compartment
04-05 ES330 Computers and or Controls - CAN Interface Module Initialization
So I am still confused: is there a new TSB for the transmission fix in 2005 Lexus ES330 or not?
Lighting - Stop/Tail Lamps Inoperative/Water Inside
Bulletin No.: 00-08-42-007C
Date: August 24, 2004
TECHNICAL
Subject:
Stop/Tail Lamp(s) Inoperative or Intermittent and/or Water in Lamp (Replace Circuit Board/Gasket and/or Lamp Assembly)
Models:
1997-2003 Chevrolet Malibu
2004-2005 Chevrolet Classic
1999-2005 Pontiac Grand Am
Supercede:
This bulletin is being revised to add the 2005 model year. Please discard Corporate Bulletin Number 00-08-42-007B (Section 08 - Body and Accessories).
Condition
Some customers may comment that a stop and/or tail lamp may not work correctly, or that the tail lamp has water in it.
Cause
This condition may be caused by the circuit board and/or gasket.
Correction
Remove the lamp assembly from the vehicle. Use the information below to diagnose and repair the lamp assembly.
1. If the base of the stop/tail lamp bulb is distorted, replace only the circuit board and gasket, as well as the bulb.
2. If the lamp leaks (has water in it, as opposed to condensation) but the reflective surfaces inside the lamp are not discolored, replace the circuit board and gasket.
3. Replace the lamp assembly only if the following condition(s) exist:
^ The lamp is discolored internally.
^ The lens is cracked.
^ A locking tab is broken.
^ The reflective surface is discolored.
4. After replacing the circuit board, ensure that all locking tabs are securely fastened to the circuit board.
Parts
Part number Model Description
9441839 Malibu & Grand Am Bulb (3057)
22622414 Malibu Board, Tail Lamp Circuit (Right)
22622415 Malibu Board, Tail Lamp Circuit (Left)
Toyota has announced computer software upgrades that it says should help eliminate hesitation problems in five-speed automatic transmissions in 2002 to 2005 models, a company spokesman said. The upgrades produce "incremental improvement in shift quality," spokesman Wade Hoyt said. The problem may still exist for some owners, and the company continues to work on other fixes, he added.
If you had the number, I might be able to come up with something.
But really, if it is a 2005, it is under warranty and since the newspaper has it in it, then the dealer should have the bulletin.
The dealer here couldn't find anything.
Here is what I found after much of digging: April 1st Lexus transmission TSB. Looks like it is a recent update to the TSB issued in August 2003. Since the update refers to the 2005 Lexus ES330 model as applicable, I'll have it done.
Are you able to get the PDF file or fulltext for the following TSB?
2002 Lexus ES300
Bulletin Number: 00104
Bulletin Date: JAN 2004
Summary: A RATTLE OR TICK NOISE FROM THE BASE OF THE WINDSHIELD. THE COWL COVER (LOUVER SUB-ASSEMBLY) HAS BEEN MODIFIED TO IMPROVE THIS CONDITION. *TT
It will be there for a week, then it will be removed to make room for new stuff.
Could I bother you with a few more noise/rattle-related TSBs?
2002 Lexus ES300
Bulletin Number: 00403
Bulletin Date: APR 2003
CREAK NOISE AT TOP OF WINDSHIELD AND/OR BACK WINDOW GLASS.
Bulletin Number: 00404
Bulletin Date: MAY 2004
REAR DOOR TRIM PANEL LOWER SEAL RATTLE
Bulletin Number: 00302
Bulletin Date: NOV 2002
REAR INTERIOR DOOR TRIM PANEL RATTLE
Bulletin Number: NV01001
Bulletin Date: DEC 2001
INFORMATION ON REDUCING POTENTIAL SQUEAK AND RATTLE NOSES FROM THE INTERIOR OF THE VEHICLE
Caroe
click on my name and you will find my email there and I may be able to help you with some of them.
