First, buy a 6 pack, then drink one.
Work on it for a while, drink another one.
Make some calls for tech help, drink another one.
Look on internet for a while, drink another.
Forget where you were. Go in and finish the 6 pack.
In the morning, take it to a shop.
Sorry, I couldn't resist. LOL!
I changed the battery and the locks defaulted to the factory standard.
Bummer and a pain!
EL009-00
Title:
ENABLING/DISABLING AUTO DOOR LOCK
Models:
'00 Avalon
August 4, 2000
Introduction
To clarify the existing procedure for enabling and disabling the Auto Door Lock function on 2000 model year Avalon vehicles, the following procedure has been developed. Refer to Repair Manual RM746-U2, Page BE-86 for previous enabling/disabling procedure.
Applicable Vehicles
^ 2000 model year Avalon
Clarification Procedure
To Disable Auto Door Lock:
1. Enter vehicle and shut all doors.
2. Insert key into the ignition cylinder and turn it to the "ON" position (not "ACC".)
3. Open the driver's door. KEEP OPEN.
4. Turn the key to the "OFF" position and remove key from the ignition cylinder.
5. Insert and remove the key into the ignition cylinder 4 times. (You will end this step with the key out of the ignition.)
6. Push the "UNLOCK" button on the driver's door master switch 5 times within 10 seconds. Wait at least 10 seconds and shut the driver's door.
7. Verify auto lock operation has been disabled by starting the vehicle, putting the vehicle into a gear and taking your foot off the brake.
To Enable Auto Door Lock:
Follow the same sequence as above, except in step 6, push the "LOCK" button on the driver's door master switch 5 times within 10 seconds. Wait at least 10 seconds and shut the driver's door.
I can't imagine why they don't have the info in the owners manual.
Jim Bryant
Exactly from the manufacturer.
As for making sure the doors were unlocked, I would have thought that it was a given, beings how it states to open the door and leave it open. :confuse:
NUMBER: 08-019-02 REV A
GROUP: Electrical
DATE: Dec. 6, 2002
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. THE MDS2 MUST BE OPERATING WITH CIS/ISIS CD2123 OR HIGHER AVAILABLE DECEMBER 23, 2002.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-019-02, DATED SEPTEMBER 30, 2002, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES A REVISED NOTE, DIAGNOSIS AND REPAIR PROCEDURE.
SUBJECT:
Flash: Digital Displays Flicker
OVERVIEW:
This bulletin involves reprogramming the Body Control Module (BCM).
MODELS:
2001 - 2002 (RS) Town & Country/Caravan
2001 - 2002 (RG) Chrysler Voyager
NOTE: **THIS BULLETIN APPLIES TO VEHICLES BUILT BEFORE OCTOBER 1, 2001.**
NOTE: **IF SB 08-19-02 WAS PERFORMED ON A VEHICLE, THE BCM SOFTWARE WAS REVISED TO 04836965AE. THIS MAY RESULT IN THE FOLLOWING ON 2001 AND 2002 VEHICLES: VEHICLE THEFT ALARM (VTA) LAMP INOPERATIVE, VEHICLES EQUIPPED WITH A (RAS) RADIOS WILL HAVE NO DAYTIME BRIGHTNESS, AND THE BCM MAY NOT POWER DOWN WHEN THE IGNITION KEY IS TURNED OFF. SB 08-019-02 REV. A NEEDS TO BE PERFORMED ON THOSE VEHICLES WHICH WILL REVISE THE BCM SOFTWARE TO 04833855AD.**
SYMPTOM/CONDITION:
When the dimmer control wheel is set at maximum brightness, just below the parade mode (daytime brightness) position, the Vacuum Fluorescent (VF) displays for the odometer, transmission range indicator (premium cluster), Electronic Vehicle Information Center (EVIC) or overhead console, radio and Automatic Temperature Control (ATC) may flicker between maximum brightness and daytime (parade mode) brightness.
NOTE: THERE ARE NO BCM FAULT CODES FOR THIS CONDITION.
DIAGNOSIS:
**If the customer complaint matches the Symptom/Condition, the vehicle was built before October 1, 2001 (MDH 1001XX), and the BCM software is NOT p/n 04833855AD, OR SB 08-019-02 was previously performed, perform Repair Procedure.**
NUMBER: 08-015-04
GROUP: Electrical
DATE: April 27, 2004
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-021-03 DATED JUNE 27, 2003 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES CORRECTING THE SUBJECT.
SUBJECT:
ABS, BRAKE, TRAC OFF and Security/Vehicle Theft Alarm (VTA) Cluster Lamps Illuminated on Vehicles not Equipped with ABS Brakes or **SKIM**.
OVERVIEW:
This bulletin involves using the DRBIII(R) to clear the instrument cluster of all learned features instead of replacing the instrument cluster.
MODELS:
2001 - 2003 (RS) Town & Country/Caravan/Voyager
SYMPTOM/CONDITION:
Vehicles not equipped with ABS brakes may have the ABS, BRAKE, and TRAC OFF lamps illuminated on the instrument cluster or vehicles not equipped with Sentry Key Immobilizer (SKIM) may have the Security/VTA lamp illuminated on the instrument cluster.
DIAGNOSIS:
If the condition is present, perform the Repair Procedure.
EQUIPMENT REQUIRED
REPAIR PROCEDURE:
1. Connect a Battery Charger and set as close to 14 volts charge as possible.
2. Flash reprogram the BCM using the MDS2(R), operating at CD 2121 or higher, and the DRBIII(R) operating at software release level 55.3 or higher. The BCM software must be p/n 04833855AD.
EQUIPMENT REQUIRED
NOTE: THE DRBIII(R) MUST BE AT LEVEL 55.0 OR HIGHER AND THE MDS2(R) AT CD 2111 OR HIGHER TO PERFORM THE REPROGRAMMING.
REPAIR PROCEDURE:
1. Connect the DRBIII(R) to the vehicle diagnostic connector, using cable CH7000.
2. Turn the ignition key to the ON position (engine off).
3. From the DRBIII(R) Main Menu, select # 1 - DRBIII(R) Standalone
4. Select # 1 - 1998 - 2005 Diagnostics
5. Select # 1 - All
6. Select # 3 - Body Interior
7. Select # 2 - Electro/Mech Cluster (MIC)
8. Select # 9 - Miscellaneous
9. Select # 1 - Reset Learned Features
10. Follow the directions on the DRBIII(R) screen.
11. When the DRBIII(R) returns to the Miscellaneous Menu, select # 2 - Reset Module.
12. Erase fault codes using the DRBIII(R).
13. Disconnect the DRBIII(R) from the vehicle.
14. Verify the ABS, BRAKE, TRAC OFF, and Security lamps are no longer illuminated.
02-08-64-014 MAY 02 Body/Frame - Outer Door Glass Surface Scratches
Most of it is paperwork forms for the tech to fill out when performing the resurfacing.
It is about 15 pages long.
There is a list of parts to be replaced and some body modification to be done.
File In Section: 08 - Body and Accessories
Bulletin No.: 02-08-64-014
Date: May, 2002
TECHNICAL
Subject:
Door Glass Scratches
(Widen Door Metal Inner/Outer Panel Opening)
Models:
1999-2002 Oldsmobile Alero
1999-2002 Pontiac Grand Am
Condition
Some customers may comment that the outer surface glass on one or more of the vehicle's doors is scratched. This condition appears on both the two- and four-door models.
Cause
The scratches may be the result of the door metal inner and outer panel opening being too narrow. This allows dirt and debris to become trapped between the outer sealing strip belt molding and the outer window surface.
Correction
1999-2001 Models
Widen the door metal inner to outer window paneling opening and replace the sealing strip outer belt molding.
I was at a drive in the other night and heard the very same noise, my husband laughed and said it sounded like his car, when we turned around to see what kind of car was making the noise it was the same make and model. I am betting others are having the same problem. If so can you help or tell me what is causing the noise?
Also did you get it fixed by Ford? Is there a TSB for the problem?
If there's no evidence of ATF in the rad, then the vacuum modulator on the trans is probably leaking. Pull the vacuum hose off, and if there's any ATF in there change the modulator. Make sure the push rod is transferred to the new modulator.
NV002-05
Title:
DOOR WIND NOISE IMPROVEMENT
Models:
'01 - '05 Highlander
February 10, 2005
Introduction
Some vehicles may exhibit wind noise coming from both the front and rear door window glass. The following repair has been developed to improve this condition.
Applicable Vehicles
^ 2001 - 2005 model year Highlander vehicles produced BEFORE the Production Change
Involves replacing the door trim molding
http://www.autozone.com/images/cds/jpg/small/0900823d800bad37.jpg
http://www.gmtechlink.com/images/issues/nov04/TL_Nov_04.pdf
I've been doing some investigations, as far as TSB's go. I found one...03-06-04-012A. Does anyone know what this is for??
Has anyone else experienced this same problem??? If so, what did you do???
I havae 2000 chevy venture it has a harsh shift ( when it shifts it give the car a push forward). this always happens when there is a strange sound (humming, whining I am not sure how to call it) I think it is comming from transmissionn or at least from the drivere side in the front of the car, No sound No harsh shift.
I have changed the filter and fluid newely it is missing little bit than the full, this happens only after drving for a while.
some of them told me there is internal problem in the transmission and the reason why it happens after driving for a while that the transmission gete warm up?
but last time I drived the car for 6 minutes inside the city no problmes, then I swiched off for 3 hours and the weather was very cold, when I start driving it after these 3 hours of rest it starts that strnge noise with a harsh shifting.
* When it have that noise it will stay even when I sop and shift to the "P" or "N" just pressing on the accelrator will show it.
Sorry for the long message
your help is very much apperciated
Next, Post this in the Vibe board (if you haven't already).
Take it to a trusted mechanic that can diagnose problems. Anything I can think of would trip the check engine light.
They replaced the alternator, battery and serpentine belt. Still have the problem.
It's a 2001 Alero 50,000 miles V-6.
Any ideas?
Mary
The light keeps coming on and I'm wondering if this has any info.
Mary
i'm driving. on braking, the car pulls to the left and right and the wheel drops/turns to either side. i had new tires put on for tire cupping and the rim was bent (i didn't do it) and the tire was bad/chord. since then, i am experiencing an hard/high pedal. of course doesn't happen to anyone but me...ride after ride after ride...i have a complaint in with general motors dealer doing nothing if they can't recreate it too and have gone to a 2nd dealer this week same thing. new front struts too. i don't know if i'm in the right forum. they tell me there are no recalls or bulletins but somehome i don't trust either one of them and the more i read...it's frightening.
Please advise a solution for the technicians to fix my car
Cat
It has no dashboard lights..
Would you know what has to be replaced to fix it??
Is it a fuse or a modle ?? Any help you could give me would be wonderful..
We totaled our 1995 Plymouth Voyager and purchased this vehicle to replaced it but I can't drive it at night.
Would you have any infor on this for us??
Thank you Thunderbird3
