It was the starter. Once I replaced the starter it fixed that particular problem with the car.
quiet in 1 and increasingly noisy in 2, 3 and 4.
Any suggestions would be appreciated.
Ludwix
I have a 2000 thats leaking small amounts of oil but i discovered it pretty soon and have been able to keep it under control. To anyone else who has this car beware the engine, sensor module on the tranny, and timing belts.
On the downside, one of my spark plugs was covered in oil. Sounds like I may have an engine overhaul in my distant future. Can't wait.
When i was a few blocks away from home the engine light started flashing and my car began chugging and making some noise.
When i got home i borrowed a roommates car and purchased oil. Unfortunately when i was filling it the bottle slipped and i poured the entire gallon in, so it is now overfilled.
I have driven it a few times this week since then (it's finals week at school and i had no other choice but to go or fail) but it still chugs while idling or stopped at a light etc. But while driving above 15-20 mph it runs fine, just as it did before. I took it on the freeway today and it did 60 just fine. The exhaust wreaks of oil and is quite noticeable.
The car is a 2005 dodge stratus sedan (special model, can't remember the letters) with around 130,000 miles on it. I bought the car with around 20,000 miles on it and have taken decent care of it until now with no problems.
The only issue it's ever had is the check engine light has been on since it was purchased. So now when i start the car the engine light is on and after a few seconds, or when i begin to drive it flashes. I don't think this is pertinent to the problem but figured id mention it.
The other thing i have noticed is it consumed gas much more quickly than before.
I have read a lot of posts on various sites (including this thread) about similar issues but i couldn't find consistent information, especially dealing with running it out and overfilling. I am taking it as a good sign that it still works, but want to know if it's just a matter of time before my engine kicks it? or if the current problems are due to overfilling?
I will hopefully be draining the oil and refilling it properly tomorrow, but am looking for more information. Please, any insight you might have would be very helpful.
Also, how far should the temperature gauge rise? Recently, a local mechanic changed the thermostat. However, now the temp gauge only rises to the first mark and stays there. Never goes any higher and then drop back down when the thermostat opens. Is this normal? I thought there might be air in the system or the thermostat was faulty. He put another thermostat in it last week and with the same result. It's a 185 degree thermostat but a computer says the coolant is 180 degrees when fully warmed up.
I'm not sure if a false temp. reading could cause the dying problem.
I realize this is a long overdue answer, but if anyone out there still has this issue, hope this post helps!
