Here's a summary of the arbitration program from the BBB:
http://www.dr.bbb.org/ComSenseAlt/bindArb.asp
I was thinking of an attorney because arbitrations tend to be compromises and I don't think you should compromise in this case if in fact you are certain the vehicle sustained no water damage at any time.
Anyway, read over your arbitration agreement before you decide to do it so you know what to expect as a possible outcome.
Carla Cothran
I HAVE THE SAME PROBLEM WITH MY 1996 MAZDA PROTEGE. THE TRAANMSISSION WON'T SHIFT INTO 3RD OF 4TH GEAR. AND WHEN I GET TO 20 MILES AN HOUR THE CAR HESITATES AND PULLS FOR A WHILE BEFORE IT GOES PAST THAT. WHAT DOES THAT MEAN? DO I NEED A NEW OR REBUILT TRANSMISSION? I ALREADY CHECKED FOR LEAKS AND THERE ARE NONE, AND I CHECKRD THE FLUID REGULARLY AND ADD AS NEEDED BUT IT DOESN'T SEEM TO HELP MUCH. EVEN WHEN I PRESS MY FOOT ON THE GAS LIGHTLY IT SEEMS TO JERK A LITTLE. WHAT DOES THAT MEAN??? I'VE BEEN DRIVING IT FOR ABOUT 7 MONTHS LIKE THIS. HOW MUCH LONGER WILL IT LAST ME UNTIL I CAN GET A NEW ONE? THIS CAR IS DRIVING ME CRAZY, I ALREADY SPENT OVER $800 GETTING OTHER REPAIRS ON IT. IF SOMEONE COULD GIVE ME SOME SOUND ADVICE AS TO WHAT I NEED AND WHAT I SHOULD DO IT WOULD BE GREATLY APPRECIATED. THANX MUCH
:sick:
Anyway the first thing to do is go to an autoparts store like Autozone that can scan any codes that maybe set.
And before you do that check and clean the battery connections real well. And check electrical connections to the transmission. It could be a problem with the selector switch. It could be a solenoid problem, It could be internal. It could be a filter partially plugged. Droping the pan draining the fluid would let you know. It would be nice to have someone check some pressures for you.
It could be skipping 2nd and going into 3rd.
That is a band that breaks. Or the apply piston could have issues.
Please let me know.
Brad
Anyway, if that's the problem, I'd be SURE you got a new transmission with a re-inforced sun shell case or you'll have the same issue again. There are vendors who know this issue and are building stronger cases for that every reason.
I don't know if a whole new trans is in order but since youare taking everything apart it might be a good idea to just plug in a new one and have your worries ended.
02 ? Wow they planned that one good. Just outa warranty.
So with the weak parts it wouldn't matter how good you took care of it. It would still break.
I don't have an application chart for that trans. If you use manual low instead of D drive range, what does it do?
Could be a low sprag or roller getting bad.
It could be sticking valves, or some other control problem. How are up shifts? Maybe throttle valve adjustment.
Overdrive is 4th gear, they're one and the same. At 3,000 rpm+ there's no question that it's not upshifting to 4th, time to take it to a trans shop which can properly diagnose it. Could be an external cause, could be internal electrics, or could be internal mechanical.
I found some information about some common problems with the transmission and drivetrain in that year and was wondering if that was possibly the cause.
Occasional problems with this vehicle are failures of the Transmission Pressure Control Solenoid (PCS) and the connections at the Transmission Pass-Thru Connector. Failure of the Transmission PCS is identified in TSB # 00-07-30-002B. Failure of the connections at the Transmission Pass-Thru Connector is identified in TSB # 02-07-30-022B. The cost to repair the Transmission PCS is estimated at $45.61 for parts and $273.00 for labor. The cost to repair the Transmission Pass-Thru Connector is estimated at $10.00 for parts and $65.00 for labor. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Like so many others here I really don't know all that much about this kind of stuff and I certainly don't want to have to pay for a whole new transmission if it is not really needed. Thank you in advance for any insight that you can share as to what this might be.
http://car-part.com/index.htm
I remember wrecking yards used to have an interchange book. I think it was called a Hollander or something like that.
Have you looked into rebuilding it yourself ?
ATSG sells for $20.00 a nice book worth the read
Most general repair shops won't attempt a job like that. They farm them out to a trans shop.
Even if a person had the skills, they sure wouldn't have the necessary tools and equipment!
You were kidding...right?
A filthy job too and who knows what you might run into.
