The flush replaces a all liquid and a bit more (what is in pipes and the flush machine). This is about 16 quarts for my car. Dropping the pan replaces only about 50% of the liquid, 7-8 quarts. On the other hand, when dropping the pan technician replaces as well the tranny filter.
I decided for flush, but brought my own transmission liquid, the synthetic Mobil-1. The dealer's technician started with flush, but then proceeded with dropping the pan and replacing the filter. They do it when a dirty liquid comes out while flashing. I did not save on the procedure, but cleaned my tranny much better than if I would decide to drop the pan from the very beginning.
Being a superior liquid, Mobil-1 dissolves a lot of deposits and contaminations...
A simple fluid change should be all you need.
Sounds good in theory though.
>changing half the oil in you engine for an oil change
Trans fluid doesn't have combustion leaving contaminants in the oil. It's a closed system, more or less.
I'll bet it's even better than the power flushes.
Changing the fluid regularly by dropping the pan and changing the filter, reusing the original GM pan gasket sounds best to me. I know it's not going to cause a problem.
Guess doesn't help. My service manager actually talked to one of several small town service managers with whom he shares information on GM cars and service. I stood right there. That service manager, who does have one and had used it, did NOT recommend it on my car. He mentioned problems after flushes. My car had been changed at 65K and had a little sticking going on.
Good Luck
I'd suggest alternating and having a drain the next time you do service. Good luck with the flush however. His solution was to do both at one time if you really want the flush.
Of course, severe driving conditions include very usual environments, like city and/or hilly terrains. Changed the fluid at about 40k miles, but the transmission died about year later, at 47k miles or so.
We have a 98 saturn wagon with a dead trannie. the question is, do we get a junkyard trannie with a 3 month warranty, or a rebuild, with a 3year warranty. the difference in price is significant. So, thoughts about how reliable junkyard trannies tend to be? I know it depends on the particular one you get, but we're looking to improve our odds.
Thanks for your replies.
Doyle Sely
BUT, here is my problem.
A few days ago, when I put the car into drive the engine revs as though it is in neutral, after a minute or so it drives. It happens slightly with reverse, though not to the extent as with drive. I had a mechanic check my tranny fluid, he said it is slightly low and off color. But not to the point that it should cause my problem. After talking with others and reading I am hoping that it is because of the battery causing something to malfuncion? Is that plausible?
I am starting at changing the spark plugs and moving on from there. I am being told that the timing belt needs to be replaced or it might be the vacuum advance. My brother has suggested we start simple and move on from there. Any other suggestions? engine temp is good (not even halfway). It bucks from start to fifth gear when accelerating. I have a mechanic who thinks my clutch needs to be repaired. The same mechanic thinks the fuel filter needs to be changed. I had it changed in Dec. The thing is, it happens when I accelerate. It sometimes dies, but I can start it up immediately... for now. I have noticed that when the car isn't warmed up, it doesn't buck until it has warmed up.
I just had a possum underneath my hood removed, but I doubt if that has been the problem for the last five months since it was a baby. Any suggestions?
Toyota Avalon Quality Problems
Avalon shows dent in Toyota quality; fixes sought for 'problematic vehicle'
I have developed a stiff clutch in my Honda. I did find one post that said that it is probably on its way out.
If I really floor it on acceleration it think I can feel it slipping.
My question, is how much to replace a clutch?
Can any reputable mechanic do this job or should I go to the dealer?
Could something else be wrong?
Do I need to act on this immediately?
The fluid level was down in the resivor, I added more, but it still is stiff.
Leggo
Pricing depends on where you live, as labor rates vary widely in the USA. I'd guess you are going to pay at least $750, perhaps more if you have a bad clutch master cylinder as well and definitely more if you have a scored or damaged flywheel. Yes, any competent shop can do this job, no problem.
He looked around and was able to see it leaking out of what he called the sleeve cylinder - that directly attaches to the transmission.
He gave me a quote of 90$ parts and 1/2 hour labor to install and bleed the clutch. Does that sound good? I thought it did.
I have an appointment at 1:30 for him to do it today.
When I asked him if it would make the clutch easier to push in, he said it should. (but he didn't say it very convincingly?)
So do you think it will help the stiff clutch?
Leggo
:confuse:
Well - the parts supplier sent the wrong part to my mechanic, so we could not put in the slave cylinder on Friday as planned. He wanted to do it Monday, but I have to be traveling this week for work.
I did go to a dealer and found a honda OEM part for 39.99 -MUCH less than the 90$ the mechanic quoted me!!!
Anyways I put the part in on Sunday, and bled the clutch system.
The clutch is working fine, but it is still hard to depress - not quite as hard, but still feels harder than my CRV.
A co-workers husband who is a mechanic, said that it could be the pins on the pressure plate get dry, and there is nothing to do about it. I just need to run it until I get tired of the stiff clutch, then replace the Pressure plate and the clutch if need be.
thanks for your help.
Ed
Another question on my Honda. ( I recently wrote about replacing the slave cylinder, and the stiff clutch)
When I shift up thru the gears with hard acceleration, and get about 4k rpm, 3rd gear, about 55mph, I can feel a significant vibration coming from the front end (i think). It is the same feeling that one would get when the tires are out of balance, in my experience.
It is not as pronounced when I go passively up thru the gears, but I can feel it. When I get in the 65-80 mph range- the car smooths out significantly.
I tried hard accleration to the 55mph, till the vibration occured and then pushed in the clutch - vibration went away.
One other test I ran, I would be on the highway in 4 gear, about 65 mph and hard accel -- same vibration but not as pronounced. This occurs in 5 gear as same.
I just had new rims and tires put on. They did a 4 wheel alignment, and the camber is out in the rear(front is perfec). This needs to be fixed. I do feel that the tires are not perfectly balanced yet. Note that I did feel this vibration with the old tires as well, but not as pronounced.
Anyways - do you feel this points to a clutch issue? (Or a combination of clutch and new tires out of balance) What other kinds of diagnostics can I run, or should I rush to the mechanics.
leggo
Both the dealer and Subaru of America say shifting from 3rd to 5th is not normal and they refuse to do that. The WRX has a synchromesh transmission. Correct me if I'm wrong, but the occasional skipping of gears, like the 3rd to 5th shift should be completely normal. In fact, I pointed out GM mandated a 1st to 4th shift in the Camaro and Vette under part throttle application in order to meet fuel mileage requirements. This fell on deaf ears.
Am I wrong here? How do I go about getting proof SOA and my dealer are giving me the "shaft"? Nowhere in the owners manual does it state the transmission must be shifted like a sequential transmission (found on motorcycles and race cars), nor does it state what constitutes "normal driving conditions".
Mike
Ask them to stop weaseling and to get the job done for you, or have your attorney write them a letter.
If they use the "we can't break the law" defense, tell them to rent a dynomometer.
