Visitor Agreement.
I would say that is confirming my thought to add something to strengthen the door where it is cracked. The doors are only 6 years old and I have seen doors that still work well over 20 years old. It also confirms my thoughts they salesman will say whatever he has to to try to sell $3000 worth of doors instead of $300 for a new top beam.
If you get a chance later this afternoon, give the Masters a look - records have and will be broken this year!
The car can handle. We took it through city streets, suburban areas, and the freeway with a long on-ramp to fully test the acceleration. High speeds through tight bends resulted in flat and predictable turns with no feeling of front-wheel-drive understeer. Torque steer was just barely perceptible at full throttle and peak torque, but even then it was easily manageable. What I don't know is if theminimized torque steer was due to the Performance Pack electromechanical limited slip differential. I'd like to drive a non-PP at some point to compare that versions electronic open differential against the PP mechanical diff.
The seats, oh those lovely seats. Deep bolstering on the seat bottom and seat back hugged my body perfectly, providing phenomenal lateral support through turns as well as comfortable cruising. Larger framed folks would probably find the seats too tight.
There was a bit of throttle lag off the line in first gear until the turbo spooled around 1,800 RPM, and then the torque kicks in and accelerates the little hatch like a rocket. The manual tranny was awesome. I do miss rowing gears. Have I mentioned that before? The clutch lever throws were precise, and the clutch peddle engagement light and intuitive. Even being new to the car I felt in full control.
The suspension surprised me. With low profile tires on 18" rims I was expecting to come away sore after driving over winter-ravaged streets. Not so. Don't get me wrong, the ride is far from supple and is not going to be confused with a Camry, but given how controlled the handling is through corners I would have expected a jarring ride. I did feel the road imperfections, but they didn't result in painful impacts through the cabin.
The Performance Pack brakes are absolutely huge for a vehicle as light as the GTI, carrying over from the R. Both front and back rotors are vented, and the 18" wheels are a tight fit over the front calipers. The large GTI badge on the red painted front calipers was a nice touch.
GTI-specific interior bits spruced up the place nicely. Metal peddles, GTI flat bottom steering wheel, textured black trim in place of the faux aluminum, golf ball shifter, aluminum door inserts, and of course the iconic tartan plaid fabric seats.
The GTI is genuinely a mature daily driver hot hatch. I could drive the car as a practical and versatile transportation tool most days while returning respectable gas mileage, and then when my desire for youthful driving arose I could dip into the torque reserves and turn it into a playful toy.
I saw a few interesting cars advertised in the paper at an MB dealer (no haggle) not too far from me:
2012 Prius (has backup camera & hot seats, so a III?). Red with black (stock wheels). 61K miles. $15,449.
2010 (hard to believe this is 5 years old) Miata. Stick. Grey over Black. 38K miles. $$15,794.
2012 BMW 650i Coupe. ///M-Sport Pkg & 6 speed stick. 29K miles. Asking $49,951. Me thinks they took this in on a trade for $38 - $39K?
So the car is gone. These people were horders so there is a huge amount to get rid of. He didn't throw out anything. There is a pail full of WD-40 cans, old rusted tools, old coke and other soda bottles, cans of food which expired in 2008, ancient sewing machine, a wooden stereo in a cabinet, a Motorola works in the drawer TV (hasn't worked for decades) and on and on. You can hardly walk through the garage or upstairs rooms unless you push stuff out of the way.
Even if he wanted something and he knew he had it he would never be able to find it. The rule was if you haven't used it in 3 years you will never find it anyway...so just toss it.
Anything worthwhile will go to an auction house. The rest is junk that will go to charity or a dumpster.
A person at work was having some shifting problems on the auto tranny 2910 Jeep Liberty. We experts asked her if she had checked the fluid level and she said it had no transmission fluid dip stick. Huh?
We thought she was kidding but no, she even had he brother come over and look for it and nope, no dip stick.
What's the thought process behind designing a car like that? As far as I know there was no dash light or other warning for low fluid which could compensate for having a direct way of measurement.
As it turned out she had leaking cooling lines and a few other things which totaled over $900 (dealer prices). How would you know the dealer wasn't hosing you without a means to check?
Are car owners that clueless these days?
But, trannys are still supposed to be lifetime. I asked the dealer (and confirmed with a Volvo specialist indy guy) that unless the trans is having problems, they don't touch the fluid. So even though I was trying to spend money to have it done, they wouldn't take it.
the logic is that the fluid is so special it does not need changing, and doing it can cause more problems (stirring up stuff in the trans I guess) so leave well enough alone.
CHECKING FLUID LEVEL IN JEEP LIBERTY - NO DIPSTICK
I think Jeep is trying to be more like BMW/Mercedes, get your car serviced at their garage. Besides, probably 90% of the population has no idea how to check oil levels, and they will do more harm than good to the car.
Interesting though. Basically, you should never have to add automatic transmission fluid for over 100k miles. It is a sealed unit and the fluid doesn't get contaminated.
In a BMW you can at least check it on your monitor system....witha nice little graphic display.
No need to get hands dirty, or even lift the hood!
My 02 Explorer didn't have a transmission dip stick. I changed the fluid at 30k and 60k. I was trying to be proactive about the maintenance. Transmission went out at 89k.
Just posted a lengthy post and it up and disappeared. ???????
Remember the American Motors Gremlin?
Farmer - must have something to do with that upstate New York slang you use!
I don't personally like the color - should have made the color more in the brighter orange or burnt orange spectrum. Wonder why BMW would come out with such a "blah" color.
My Lincoln developed Torque converter shutter shortly after purchase. I checked for fluid level and when it was normal I knew it was common problem with Ford trannys of the era. Changed the fluid and filter with Ford spec fluid and problem solved. Without knowing that the fluid was ok I might have messed things up good trying to cheap my way out.
Even if 90% of owners don't know one end of a dipstick from the other they should still give you one.
The Masters was great. Speith looked like he might falter a couple of times but it was like as soon as he'd realize anyone was getting close he kicked in another gear.
The Masters is always special to me. My dad, who was a very good golfer - scratch in his day - loved watching the Masters and I'd watch with him a lot. He'd have loved watching it on a HDTV. The course just looks so fabulous and you can read the break a putt is taking so much better. He'd also be very impressed with my Augusta National golf ball I picked up last year. I was in overnight in Augusta last March going from my friend's place in Tallahassee and my my nephew in Apex, NC. I stopped by a guard house and chatted with the guard for a bit. He was mostly tight lipped but after a bit directs me up the little entrance only maybe 25 feet and tells me "You've been on the grounds of Augusta National. You can cross that one of your bucket list," and handed me the golf ball with the logo on it.
I always thought of transmissions as being lifetime things except for Fords.
Driver, cost for a standard GTI is about $25,000 US, and you can add up to about $11,000 in options. The way we'd want it, with xenon headlights and the Performance Pack, we'd be looking at $27,000ish invoice shipped. Not bad at all.
Total outlay, about $2K, and untold aggravation. Even better, he dug up the service history of the original (brief) owner. They had 3 replaced (wonder why they traded it in 6-9 months after buying it!)
Eventually had to garage it, waiting until enough road repairs are done that he can risk driving it again. And yes, the roads in this area (greater Philadelphia) really are that bad.
I think it had 255/35 somethings on it.
Mike is lucky to have pothole free roads in Fla!
The only problem I have been having is with automatic car washes - scraping the alloy wheels against the railings. So the car must be hand washed - no way around that. Luckily my dealer has been gracious enough to repair the right rear wheel and replace the right front wheel when the valets refuse to follow instructions about low profile tires on AMG's or on cars like mine with those rims and tires.
From my research with the powers that be, this happens more frequently than one would think. I could never take this car to a commercial car wash because they would chew the wheels up continually.
I keep 37 lbs of air in all 4 tires and in the heat down here, they inflate up to 40/41 lbs when driven at higher speeds. I could never keep that much air pressure in those tires if I lived up north. I think they recommend 33 lbs front and 35 lbs rear, cold. That's too low according to my mechanic at Mercedes. He said that at those lower pressures, the tires wouldn't last 10,000 miles. At these inflations, which are heavy load inflations, I should get 15,000 miles on the tires.
I tried driving with the standard all-season tires, but the handling was too sloppy for me after coming out of the CLS 550. If ordered with the car, I would have paid $2500 extra for the option. This way, by ordering through the dealer as an accessory, I paid $1290 tax and labor included.
Car handles more like the CLS did and I love it.
area for years.
It's a lifestyle statement, dontcha know (so long as you don't mind driving a nuclear- or coal-powered car with battery life-cycle environmental impact far beyond what most of the people driving these things know anything about).
and it went to a larger version that is upside down? I took it on my Android
phone. Transferred to my PC using the charging cable. And it was upside
down so I turned it 180 deg. in Paint Shop Pro, saved it, and uploaded it
here.
I don't know how to change it. I'll try.
And all the batteries in the US get recycled, so I think that impact is a bit of a red herring - the life-cycle comparison to the Hummer a few years back was quickly shot down.
The biggest factor driving someone to be an "environmentalist" is the money - ergo my replacing my burnt out floods yesterday with LED floods. More money up front but a fast payback in energy savings.
upside down. I infer that even though I turned the picture over 180 deg in Paint Shop Pro,
the picture didn't turn over. I saved the upside down picture. Of course, if on a pad or
phone, I could just turn it over.
I copied and saved a new version of the picture in PPP and then saved that
to the hard drive to load here on Edmunds.
I apologize for upsetting (literally turning some upside down) folks here.
feel like I just got out of school for the summer. I'll be able to go
browse the cars others bring.
