stick-on weights are a pain to use. You have to thoroughly clean the brake dust from the inside of the wheel before sticking them, and unlike hammer-ons, once you have them on, you can't slide them from side to side a 1/2 inch for micro-adjusting a perfect balance. Plus they leave behind adhesive residue when you pull them off.
See? That's why I'm such a Michelin fanatic. They make no compromises. They don't care if their tire costs twice as much as that of the competition. As long as they can honestly say their tire is unmatched in quality or performance, they can rest easy. But they don't. Just as Dunlop can subract a belt (thinking no one will know any better), Michelin can add a belt (D+E load range truck tires) without people noticing. While one company is screwing over unwitting consumers, Michelin is protecting them with equal secrecy. Why? Because they don't waste their time telling you why their tires are better because most people wouldn't understand, anyway.
Colin, The 265/75s will fit, but your acceleration will be slightly decreased; there isn't really any benefit to upgrading to this size. However, I've upgraded several new Toys to the 75s and the customers were satisfied with the ride. The Dunlop Radial Rovers are considered a higher grade tire, but they're not even close to the Michelins. They're usually cheaper, but not by much at a discount retailer. I see that Tire Rack has them for around $90 in the 265/75. Sam's club is currently selling the X-Radial LT (nearly identical to the LTX M/S) for $116 in the 265/70. This is primarily a highway tire, but it utilizes the same casing construction as the LTX A/T. The tread is slightly less aggresive than the LTX A/T, but it will be just as good as the Dunlop RV off road and twice as good on the road. Tire Rack has the LTX M/S for $115. This is a smidge better than the X-Radial LT off road, due to the slightly higher-void tread design. You really can't go wrong with this tire; if you take a gander back a few hundred posts, you'll recall that the participants of this forum almost unanimously agree that the LTX M/S is the best truck tire on the market. The Dunlop is a serious compromise. Judging by your vehicle choice, I wouldn't think you were the type to sacrifice handling, performance and safety over saving $100 on a set of tires. I promise you'll be satisfied with either of the LTX models. If you decide to settle for the Radial Rovers, expect to regret it.
I need a bit more to go on than just the GVW. What is the make and model? 14s, 15s or 16s? What kind of driving do you do? How much do you want to spend? Are you concerned more with comfort, performance, traction, or price?
Your vehicle is supposed to wear a 205/50ZR16, however, this is not the minimum rating required for your vehicle. You can safely downgrade to the 205/50VR16, which was standard on the later model 850 turbo wagons. Do not downgrade to an HR tire. As far as the differences in handling, that depends on the brand you choose. A Michelin XGT V4 will handle better than a Futura Ultra Z.
The best tire for your vehicle is the Michelin X-One. The MX4s are very good, and cheaper. No, you don't need light truck tires unless you load it like a light truck. There are light truck type tires readily available in P215/75R15. Most actual light truck tires start at LT235/75R15 and this is too big for a windstar.
Thanks for your help on the question of VR vs HR rated tires.
Do you have an opinion on the Kumoh, Dayton and Cooper brands of the VR rated tires for my Volvo 850 Turbo? All of these brands are offering fairly decent pricing on the tires -- but I know nothing about the reliablility or handling capabilities of the tires.
I have a 99 Passat with about 15,000 miles and I blew a tire and then while I was waiting for AAA My car caught fire from the tire region. The insurance company is saying electrical problems and VW is saying the tire is to blame. Does anyone have any idea? Or has anyone heard of this happening before. If so please Email me. Thanks
I just bought a 1997 Pathfinder XE 4x4 that came with the 31 x 10.50 x 15 tires. They appear to be causing quite a bit of road noise, and when I make a sharp turn at slow speeds (like pulling into a parking space) the side of the tire rubs against the inside of the front wheel well. Most of my driving is on streets and highways, but every couple weeks or so I'm on the "roads" in the mountains or the desert.
Would smaller tires improve gas mileage or reduce road noise? How about regular snow/ice traction? Is it worth changing?
I would fit the tire size installed at the factory. If you have aftermarket wheels, make sure they are the correct offset. The brand and type of tire will affect NVH and traction MUCH more than size. I've had very good luck with Pirelli and Dunlop LT tires. Michelins are an excellent choice as well. Just my $.02.
I am going from factory 15X6 steel rims to 15X8 Split Star 2000 Durango style factory wheels, on my 1998 2WD Dakota. My question is, what is the maximum size tire I can run on this 2WD truck, without rubbing something??? Of course looks are important but secondary. Thanks - Peggy
Thanks. I've had MX4s in the past and really liked them. I looked briefly at the X-One but only briefly. Guess I'll take another look. Speaking of which, Tirerack's survey results suggest the Pirelli P400 Touring compares favorably to the X-One (slightly better snow traction, slightly worse tread wear) but at a significantly less price. What is your experience with the P400? Price isn't a big factor for me, but I'm also not into just paying for a name.
I have a 98 Accord EX V6 with Michelin MXV4 Plus 92V tires from the factory. 205 65/R15
One tire is damaged, but the other tires have very little wear on them (17k miles). I looked into replacing it with the same tire, except it costs $160, and it doesnt seem worth it.
I was wondering if I could...
1. switch it with either a lower speed rated tire, or 2. even a different brand tire with the same rating (for like half the cost).
I know I've heard you shouldnt mix tires on the same axel, but that was from tire stores. I was wondering if anyone has any different information on the question.
i'm not a tire guy or a tire store... just a relatively hard core driving enthusiast... i would NEVER EVER EVER do what you are thinking about... it's dangerous... it will adversely effect the handling of your car... it's worth the 160 bucks to match your existing ones... you might want to try www.tirerack.com for prices, i don't know what these cars come with, but 160 bucks sounds a little high for oem honda tires...
Have driven a lot with mixed tires-once put some wider M&S rated Pirelli's on the front and had narrower Bridgestone's on the back. Did cause it to try to swap ends in the snow. Did not have any problems with other tires that had similiar characteristics.
I would not go cheap-check out the ratings at www.tirerack.com . I prefer Michelin X-One's over the MXV4's-much better handling, wet traction and quieter. If you take any long trips poor handling or noisey tires can make life miserable. In my neck of the woods we have something called Farm & Fleet that sells X-One's for a good price.
Always buy tires at least two at a time, unless there truly is STOCK tread depth on the one you're replacing. It may not look worn, but after 17k miles I assure you that tire does not have full depth any more.
Plus the new tire may not necessarily be the same rolling diameter even though it is marketed as the same size. I would buy at least two tires, your differential(s) will thank you. Even if that odd tire is on the back of a FWD car, it will be on the drive wheels after rotation so don't do it.
Do not even consider switching to a tire of a downgraded speed rating. Some people in this forum seem to think it is okay to put T-rated tires on Accords. This is barely allowable on the 4 cylinder, but not on the V6. First, whomever gave you a price of $160 for a V-rated MXV4 Plus is on crack. You should be able to find this tire for around $130 elsewhere. You do need to replace at least two. They don't have to be the same brand as your rears, but they must be the same construction and designation. Mainly, they must be V-rated. Most people like to match up the same brand, just to retain the full performance capabilities of that line and also so your handling doesn't change every time you rotate the tires. If you haven't rotated your tires, the rears should be nearly new. The Michelin Energy tires usually won't start to dry rot until eight or ten years of service.
I know a guy whose 99 Passat burned up without a tire failure. Sure a bad bearing could cause a fire, but I have a feeling it probably was an electrical problem. Tire fires are not common.
The P400 is a cheap tire. Do not be misled by the Tire Rack's subjective reviews. "A no-compromise tire" they say. Only a fool would believe that he's buying a no-compromise tire for $54 (in your size, for example). There is nothing special about Pirelli broadline touring tires. They go out of round; they blow out; they slide around on the wet pavement. Check out the b/s features of this tire: synthetic compound, full depth grooves. Every tire has full depth grooves; the depth of the tread is determined by the grooves. Pirelli made really good high performance tires a long time ago. Pirelli-Armstrong makes garbage tires under a name which is strangely familiar to most people and conjures up images of red Italian sports cars racing through the Alps. They still make some decent high performance tires, but their broadline tires fall short. The Michelin X-One is the best damn broadline touring tire money can buy. Anyone who tells you different is either misinformed or wouldn't be able to tell a difference in handling between a McLaren F1 and a Geo Metro. Check out the real features of the X-One: Full depth sipes, allowing the tire to maintain its wet traction for nearly its whole life; silica compound, allowing the tire to remain flexible at very low temperatures, less rolling resistance; wider contact patch, giving the vehicle much more stability, cornering, braking... the list goes on. I don't work for Michelin, as a matter of fact, as of last month I don't even work in a tire shop, since I've just taken a commission in the Marine Corps. But after working my way through college selling and installing thousands each of Goodyear, Michelin, General, BF Goodrich, Pirelli, Firestone and a few off-brands, I have come to a few conclusions: Goodyear makes wildly overpriced cheap tires; General makes cheaply priced cheap tires; BF Goodrich (owned by Michelin) makes excellent high performance and off-road tires, and decent broadline tires, at a low price; Firestone makes medium grade tires at a medium price; and Michelin makes the best freakin' tires allowable by our age's technology, at a price which is often double that of the competition. They play in a whole different arena. They don't make Michelins for those who want to save money on tires (that's why they own BFG and Uniroyal); they aim at those who value safety, comfort, and treat their vehicles like a member of the family. Some complain that they won't buy Michelins because they wouldn't "make good" on a set of "defective" tires they had in the past. In the five years I spent working full time in a tire shop, every "defective" Michelin I saw was destroyed by something the customer did (or didn't do). You have a better chance of being struck by lightning than getting a bad Michelin.
Guess I know someone who was struck several times then, as this past winter he had several Michelin Pilot Alpins that were out of round. They came from the TireRack that way.
I also noticed that your one-liner tire mfg opinions didn't say anything about Japanese brands, is that because where you worked didn't sell them? There are quite a number of Japanese performance tires that are priced below Michelin's top level offerings (mxx3, pilot sport) and give great performance.
Colin, I knew I was setting myself up with that last post. It's unlikely that your friend received a set of defective michelins. Depending on the type of rim he purchased, The Tire Rack probably didn't match mount the tires, and ended up with an out of round wheel package. They're a fast food tire store, what would you expect? No, I never sold Japanese tires. Though I have heard the opinions of my customers who have owned them (when I dismounted them), and they aren't anything special. A lot of people like Yokohama tires, often the same people who buy Michelins. A lot of people like Bridgestone tires, as well. But what does that matter? Who has the luxury of driving a tire for its full life, then doing it again with the tires of every major manufacturer on every type of vehicle sold in the US? No one--but everyone. Who gets to talk to these people? Guys like me (who care to). From what I have observed in wear patterns and what my customers have told me, I would place Yokohamas in the same category as Firestone. Decent, not too expensive, but I wouldn't choose them for my vehicle. I hardly ever saw Toyo tires (except for on kids' souped up import cars in parking lots). I think their appeal is more cosmetic than anything.
I've been driving for 25+ years and the MVX4 Energy tires are the best all round tires so far. The former tire store guy (bblaha) sounds like he has a good perspective. Thanks for the great input. Do you think the X-One is better that the MVX4 Energy? I'm willing to try it next time around. I was under the impression that it was a step down from the MVX4.
Here's my contribution: For my money and personal safety I wouldn't put any tire other than an HR rated tire on a car. At today's highway speeds and driving distances the small cost difference is not worth the risk of a blow-out.
Had MVX4 energy tires on my honda and at the suggestion of the tire dealer replaced them with X-One's. What a difference. Vastly better wet and snow handling, quieter cornering-the energy tires squalled like a stuck pig-have a 90 degree turn I take at speed and the energy tires really squalled and not a peep out of the X-One's. More importantly the X-One's are quieter. Somebody said they have a lower speed rating and were concerned. I regularly drive I 70 across MO and run at 85-95 non stop all the way across-check tires at gas station after over 3 hours-they were not hot and have had no problems.
They perform much better in wet-no hydroplaning at 75 in a down pour and no problems on twisty US 20 across No IL. in the same down pour. Able to run at 70 mph on full cover snow up I 37-rest of traffic at no more than 50. Would not take energy tires now if they were free-not a bad tire but the X-One is much better and more expensive.
Several friends and relatives now run X-One's and all are happy with them. Oh I sell medical software systems-no connection to tires other than betting my life on them.
Have you considered creating your own topic? You could title it "MXV4s will kill you, X-Ones will make you a vehicular hero." Then you could continue spreading your word, telling all the Mercedes, BMW, Audi, VW and Honda owners to scrap their O.E. H- and V-rated MXV4s in favor of the lower rated X-Ones which will offer increased treadlife (in a few cases) but throw off all other aspects of performance which have been designed into those specific platforms requiring a tire with circumfrentially wrapped nylon bands (to resist centrifugal forces found at the speeds these vehicles are created to obtain) around the steel belts. Once that works out for you, you can call the engineers at Michelin and tell them of your discovery: how their tire designated with lower rating actually outperforms their premium model. They might even offer you a job on the spot. Unless you spend this much time in a medical software system forum, I'd say you belong in the tire field. This could be a new career for you. You might even win the Nobel Prize. Otherwise, quit telling people it's okay to downgrade from H- or V- to T-rated tires. There are a lot of high performance vehicles which are shipped from the factory with MXV4s. For some reason, your 4-banger Honda fits into the bottom of this group. The tires were overrated for your vehicle, and in your case, it was a wise move to go to a tire which is more matched to the speed capability of your car. However, this would not be a wise move for the scores of other vehicles which are born with the same rubber--such as the Jetta 1.8 Turbo and the BMW 3-series. I have grown very annoyed with your nonchalant dispension of ill direction. You represent a very small minority: your car came with overkill tires, and you couldn't appreciate them. You tried to drive them like a touring tire (for a touring tire distance, if I reacall), and they didn't live up to your misguided expectations. Now stop polluting the minds of those who drive vehicles which SHOULD and DO have Michelin MXV4 Plus tires. Your opinion is not applicable to any situation other than driving a 4-cylinder (not V6) Honda Accord nearly double the recommended life of the OE tires. Once again, I will say: the X-Ones are outstanding tires. However, they are not created for the same purpose as the MXV4 (cruising at very high speeds), and in most cases, are not a suitable replacement for an application requiring that type of tire. I have owned both models on different vehicles, and would buy either of them again without a second thought.
to tireguy et al: I need to replace "all season" tires on my Avalon. They came with Dunlop sp 4000 with a H rating. They have decent handling for me, but are noisy on coarse payment. Would Michelin X-one be quieter without sacrificing handling, or is the fact that they are T rated be a concern. I do not drive over 75 miles per hour. Or should I stick with H rating or above and would Goodrich TAVR4 be as quiet and/or a reasonable alternative. Thank you
I have a 2000 Suburban 2500 (3/4 ton) truck. The sticker on the door indicating proper tire inflation calls for 50 psi in the front tires, and 80 psi in the rear tires. The max psi specified on the tires is 80 psi.
It just seems to me that 80 psi is a lot, and that the 30 psi differential between the front and rear tires is also a lot. Anyone care to comment or share insights on this?
In the pickups silverado topic people talked alot about tire pressure. The 80 psi was more for when your hauling or towing. I think they all recomeded 45psi all the way around for a very smooth ride. But when towing and hauling the pumped it up to the 80 psi.
Tireguy, I see you've taken a Marine Corps commission. Have you finished OCS(PLC?)and off to TBS? May be tough keeping up with the tire information running the hills of Quantico. I'm a retired Marine and want to say thanks for the information you've provided here and good luck in the Corps. Semper Fi! ---Andy
As you know, your Camry requires 205/65R15 H-rated tires, and the X-One is a T-rated tire. The best tire for your vehicle would be the ubiquitously discussed (here) MXV4 Plus. However, this is one of those rare cases where the speed rating can be downgraded. I've talked to several Toyota mechanics who have assured me that it is okay to downgrade to a T-rated tire on the late model Camrys if it is more suitable to the driver's needs. The question arose when I changed a Camry's worn-out T-rated tires, which had been installed at the dealership (for what reason I do not know) when the car was brand new. The car had 30K miles on the odometer with T-rated tires on the wheels and a designation of H on the placard. It was strange enough to prompt further investigation. With a screen name like Saranac, I'm guessing you're form upstate NY, and will benefit greatly from the X-One's excellent snow traction (due to wicked sipage). The MXV4 is also an good all-season tire, but it's not quite as good as the X-One in the slop. Personally, I wouldn't downgrade the speed rating due to the fact that it will certainly have an adverse effect on handling. The BFG Touring T/A HR4 is an excellent tire for about half the cost of the Michelin MXV4. It won't be as smooth or quiet as either Michelin, but will probably perform the same (in every aspect) as the Dunlop. The BFG Touring T/A VR4 is a higher speed rating than you need (V), and usually costs $10-20 more than the HR4. --Chris
Ryan is right. Don't keep the tires at the recommended pressures. Keeping the tires at 55 and 80 will wear the rear tires out if you don't load the truck up more than 75% of the time you drive it. Most GM pickup owners keep them all at 45-55psi. The Suburban is a bit heavier in the rear (compared to an empty pickup), so you might want to keep the rear closer to 60psi. The load capacity increases as the pressure increases, all the way up to the max. However, if the load capacity is much greater than the actual load on the tires, the center of the tread will wear prematurely (and you'll get a harsh ride). When you tow something, it would be wise to raise the pressure to the max. The maximum load rating on the tire's sidewall is figured at 80psi. Unloaded, you can take the tires all the way down to 35 psi (but I wouldn't), to give you a soft, carlike ride--gas mileage will suffer. By raising the pressure above 50psi, it will ride more like a truck, but your gas mileage will probably improve. --Chris
I finished OCS last summer (PLC program). I'm leaving for Quantico on Saturday (000708). Believe me, I'd much rather be here writing to strangers from an air-conditioned apartment than humping a pack through the sweltering swamps of Quantico. TBS is my last dosage of grunt life before I settle into the aviation side of the house. I was enlisted as a Marine (MOS: CH-53E Super Stallion crew chief) before college, so life in the corps is nothing new to me. But the sooner I turn in my 782 gear the better. Hey, but for that O-1E pay, I don't mind sleeping in a muddy foxhole every now and again. --Chris
Tireguy, ah summer in the swamp! You'll be reacclimated to "duece" gear soon enough and you may even get to do your land nav while the trees and foliage are in full bloom. Hint: Get a Garmin GPS to stow in the pack! I spent the majority of my time with the wing as well and was never too eager to draw the 782 gear for the field. BTW, O1-E over 4 probably.......
'Congrads on joining the Marine Corps (again)! We'll miss your great advice, but I'm sure you will do well.
BTW, how would you rate Dunlop SP9000's (compared to the MXV4 Energy Plus series)? And what's better for my '98 Accord Coupe EX V6: the Dunlop SP9000's or the X-Ones?
Once again, Good luck in the Corps, We all wish you the best.
Thanks guys. Geez, you still haven't bought new tires for your Accord? Forget the Dunlops and MXV4s. If I had your vehicle, I'd go with the Pilot XGT V4s. They'll handle better, wick water away quicker, and turn a few heads in the process (well, while it's parked, I mean). If you drive your Accord V6 well below its design parameters, take exit ramps at less than the marked speed, and don't mind diluting all the performance enhancements with which your V6 model was endowed, downgrading 2 speed ratings (from V to T) might be an option. Though I would--and often do here--STONGLY recommend against this. This tire is not, in any way, designed with your vehicle in mind. XGT V4 XGT V4 XGT V4...
Can you use the Bridgestone RE-730 ? It's a really good tire at a great price. The only downside may be ride quality, as it is a Performance tire with stiffer sidewalls.
Thanks again for your instructions on how to 'tune' your tire pressure - after a couple thousand miles I just about have it right. One thing I noticed is that my OEM Bridgestones are wearing out (5-4/32 left, F-R, ) and it will be time for new shoes this fall. Since I can only find Bridgestone 205/60HR16's and no one else seems to make that size, I want to find a tire with the same diameter but a better manufacturer (preferably Michelin) while still getting a performance tire.
I have a 1999 Solara SE V6 with 205/60HR16 and the closest Mich. sizes I can come up with are 225/55 or 245/50's and the Pilot XGT H4's are available in both. How do I determine (or maybe there is a book somewhere) if these sizes will fit on my car without rubbing the fenders and/or fit on my OEM rims (16x6, I think)? How do you recommend I proceed? Thanks!!
I saw that, but it's a 'grand touring' tire. But, I want something more performance oriented (although, it has to be all season and have at least a decent tread life).
I must disagree with the critique of these inexpensive touring tires. I found them to be excellent all-around, dry and wet traction and cornering, hydroplane resistance, etc. They are not exceptionally quiet, but not bad.
I have a 1996 BMW 328i sedan. I'm looking to replace my tires and I don't want to replace them with the Michelins that came from the mgfr. I live in St. Louis and I am not pleased with the way they handle in rain or snow. I'm looking for a good all-weather tire.
Any recommendations? A friend recommended I look at purchasing a Dunlop tire. Thoughts?
I live in Wichita and we have similar weather. Your original equipment Michelins were not meant to be all season tires.
If you can budget it I would recommend summer performance tires on your stock rims and second set of rims for winter tires. Mount these from late November to early March, give or take.
If you persist with the all-season compromise, I'd try the Pirelli P7000 supersport or the Bridgestone Potenza RE940.
a few posts back sorry bout the heading it should have been accountants not accounts
Ryan
I appreciate would appreciate your opinion.
Electrical problems, bah. That's complete BS.
-Colin
good luck.
-Chris
-Colin
-Colin
Thanks in advance,
Kurt
Ryan
---Andy
BTW, the first time I flew in an airplane, I jumped out
Cheers,
TB
--Chris
--Chris
--Chris
Once again,
pblevine
XGT V4
XGT V4
XGT V4...
Bruce
I did a quick search at Tirerack.com; the Michelin Energy MXV4 should be available in your size. The "H" rated tire is $95.
Ryan
Thanks for your post.
-Colin
-Colin
-Colin
High Performance Tires
Your host, Bruce
