A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Tires
Thanks alot, Paul
At least check out another tire store.
-Chris
Need to replace OEM General XP2000GT's on my Old's Silhoutte. First van owned and not sure what to replace with. The Generals were okay, but I am sure there might be better out there. Do like the Goodyear LS's on my newer Intrigue and see alot about X-Ones.
Unfortunately, my Michelin experience has only been with tiny Civic's - not quite applicable here.
Thanks for the Help
How long can I expect them to last?
How do they compare the the RE-71's?
I will be using them as a daily drive in my GS-R
in Florida. They need to be good in the rain too.
If i were you Marcy42, I would wait a bit and see if the dealers force Firestone to make adjustments for their wonderful tires. In the interim I would carefully look at the tires and inspect for any cracks and check the air pressure. Low air pressure=hot tires=potential tread seperation.
Check www.tirerack.com for recommendations on tires-this is an important decision that could affect your longevity.
However, I agree with Joe166 and Butch11 on the current problem. With the existing evidence, I feel confident in a car equipped with Firestone tires if the pressure is maintained correctly, they are checked for flaws every few weeks, they are not overloaded nor are they driven too fast. Of course, these criteria should be followed with any tires.
Hope the PR types at firestone/Bridgestone do the right thing. Just heard a news report that the death count is now at 45 and growing.
Bet the scummy trial lawyers are shaking with anticipation.
Firestone denied for 7 years in the 70s there was anything wrong with their tire while fighting lawsuits with the government. In 1978 they were forced to recall 7.5 tires. During the investigation, Firestone's illegal political slush fund was discovered and it's chief financial officer was indicted and served prison time. reference: http://www.fac.org/publicat/headline/08.HTM
I personally would not buy Firestone tires or continue to drive on them if I owned a car with them...they still don't seem to have learned their lesson.
According to the BFG info for the All-Terrain T/A, the 265/75R16D tire has the same max. load at 60 psi as the 245/75R16E tire has at 80 psi. Since the 265 has a "D" ply rating, shouldn't it actually have a lower max. load? How can 60 psi carry the same load as 80 psi? Isn't a "D"-ply tire actually "weaker" than an "E"-ply tire?
Thanks for any light you can shed on these questions.
noticed that they sell a brand "Kirkland" tire
which has a 80K mileage rating and costs about 2/3
as much as the Michelin X tire. The clerk said thet they were made by Uniroyal. Anybody out there
know any more about these Kirkland tires? Are they
good, bad or indifferent?
Have you seen this elsewhere?
Only had one set of Dunlops-they were junk-had to replace them because one of the belts was twisted-made the wheel bounce. Got nothing out of Dunlop. A friend had a belt seperation with a Dunlop-same story. Suggestion-check out www.tirerack.com for recommendations-look at the ratings by users for specific tires-they are right on in my opinion.
I have Michelin X-One's and really like them.
I'll be carrying a slide-in camper, so I definitely don't want to lose any carrying capacity. Since the 245's have the extra ply, are they "stronger"? Will the lower pressure on the 265's translate into a softer ride? How about the mileage trade-off for the 265's (larger contact patch means lower mpg, but larger diameter means higher mpg at the same rpm)? Finally, since I would have to re-program the engine computer and probably also have to buy new wheels, would the 265's actually be worth it?
Rbrenton88, I'd have to see the tires to make an accurate assesment, but bulges are ususally related to broken or separated sidewall plies. If this is due to an impact, with your low profile tires, there will almost certainly be some damage to the rim at the same position. If you see no scuffing on the edge of the rim, it is probably a defect. If the bumps are actually undulations (inward bumps), they're most likely okay to drive on. I bet this is what you have, since I can't imagine an ASE certified mechanic at the dealership would allow a customer to drive on defective tires. This is more common among cheap tire companies such as General who use a segmented mold process which overlaps the sidewall at the bonding point. This is the strongest point of the tire (according to them). If the sidewall has separated (also common with Generals), a bubble will develop between the sidewall plies. You can check for this by fully deflating the tire. If it is a s/w separation, the bubble will remain in the absence of pressure.
No one will help you. Mazda isn't responsible for consumable items (brakes, tires, clutch, etc.), no matter how quickly they go bad. Dunlop won't help you, either, since you didn't buy the tires from them--your car just happened to come along wearing their product. If this were to happen to tires you had purchased from a retailer or discounter, you would be covered, but OE tires are covered by no warranties.
Honestly, no matter what the cause of the anomaly, it is less than wise to drive on tires which are suspected of being defective. My usual, heavily biased (for a reason) advice: buy Michelins. Get a pair (or better still, a set) of Michelins in the proper size and speed rating, and you will have no worries. Also, your vehicle will drive better than you ever imagined it could. Remember, you get what you pay for. There is a reason their tires cost 50% more than most of the competitions'. Also, they are unmatched in quality on this planet. If someone tries to sell you a more expensive tire than the Michelin, you are being taken for a ride. There is not a tire made which rivals the performance or luxury of their high end tires; and there are absolutely none better.
Chris
As long as your truck has a gear ratio of 3.73 or higher, you'll experience no reduced acceleration or other evil things by going from a 245 to a 265. If you have 4.11s you're golden. The 265/75R16 is about an inch taller than the 245/75R16. The size is 20mm wider, but individual tires vary in contact patch with. Going from a Steeltex to an All-Terrain TA KO (excellent choice, by the way) will probably be slightly more than 20mm.
Load ranges are not consistent from size to size. Two factors determine load capacity: construction and size. The tighter a tire can hold its air, the better. The more air it can hold, the better. Two tires of the same rating but different sizes will have different numerical ratings. Next time you're at a tire store, compare sidewall ratings of an LT235/75R15 LRC to an LT265/75R16 LRC and you'll see what I mean (sorry, I forget the exact numbers).
Theoretically, a LRD tire carries an 8-ply rating. A LRE tire carries a 10 ply rating. Do any D tires have 8 plies? No. Do any E tires have 10 plies? No. Most truck tires, whether C, D, or E, are constructed of six plies (4 tread, 2 sidewall). Only Michelins have an extra steel belt in the tread on D and E tires, making them true 7 ply tires. The BFG ATs have an extra sidewall ply, making them true 7 ply tires (or you could even say 8, since they wrap around completely), but still carrying only two steel belts. There are actually cheap E tires (Firestone, General) of 6 true plies which are rated higer than the D Michelins with 7 plies. Which do you think are stonger? The truth is, the ratings are b/s. Check out the construction on the sidewall markings. A 3/4 ton truck which calls for E range 245s can easily get away with 265/75R16s LRD, and whether it's a Ford, Chevy or Dodge, they will fit on the stock rims as narrow as 6.5 inches.
Gas mileage and ride comfort will be affected by tire pressure. The higher the load range, the more latitude. D tires go up to 65, but E tires go up to 80psi.
Hope that helps.
Chris
For those interested, here's the direct link to Maintenance & Repair Topic 1579, Firestone Tire Recall: Are mine a problem?
Drive safely everyone.
Pocahontas
Town Hall Roving Host
Pat
Then finally, the Toyota Zone Man gave us his Michelin MXv4 Energy tires to replace the Potenza RE92 Bridgestones. That fixed it all. this was after 5 different Tire work visits. Enough Said?
Whenever tracing a leak, you must follow a systematic process.
1) Remove the inflation caps and spray in and around the valve stems.
2) Though an unlikely cause in your case, inspect the tread for injuries (either the object still piercing the tread, or a cut left from debris which punctured the casing). Spray any areas which you suspect may be the cause.
3) Spray around the bead surface of the inner rim and the outer rim. It may be necessary to dismount the wheel and lay it flat on the floor. It may take a few minutes for fine bubbles to develop in the case of an improper bead-rim seal. PAY PARTICULAR ATTENTION TO THE AREA NEAR THE WHEEL WEIGHTS. The clip often interferes with the perfect match of the two contours, especially with Michelins, which fit tighter than most. Use of improper weights will often cause leakage here (your vehicle requires MC weights).
4) If nothing is detected, the rim itself may be leaking at the bond/weld points--very rare.
The best way to find a leak is to fully submerge a wheel in a dunker (if you have something large enough).
The problem: Alloy wheels often corrode at the bead surface, causing a white, powdery residue to accumulate, which will not allow the smooth bead of the tire to seal properly with common installing lubricant.
The solution: Usually a light brushing will remove the corrosion and allow a good seal. The best way to deal with this is to have the wheels reconditioned $$$. The most common solution (if brushing doesn't work) is to paint the bead surface of the rim with a tire sealant (similar to windshield sealant) prior to installing the tire. This takes a little time, but WILL SEAL THE BEAD 100% OF THE TIME if done properly. However, when the next set of tires are installed, it will have to be removed and redone (not a big deal unless it's neglected) or you will encounter the same problems.
Find the leak yourself, first. Then get help.
Chris
Is it because of the tread design, the tire doesn't handle reasonably well in both dry and wet conditions?
(Anyway, on my Civic HX CVT coupe my next set of tires will either be Bridgestone RE92 or Pirelli P6000 Sport Veloces.)
Happy Motoring. ;-)
Pocahontas,
