2015 Dodge Charger Lease Questions
24
    carpediem24carpediem24 Member Posts: 29
    Thank you Kyfdx. I don't think I would worry too much about the pull ahead programs. Would you happen to have the numbers for MF and RV for Ally and/or US Bank?
    MichaellMichaell Moderator Posts: 241,775
    No only Chrysler Capital numbers.
    2015 Subaru Outback 3.6R / 2014 MINI Countryman S ALL4
    matt201 said:
    Hi - I'm looking for residual value and money factor for 2015 Dodge Charger SE and SXT -- 15k/36 months -- New Jersey. Thanks!
    SE - standard MF (.00180) and 50%
    SXT AWD - .00017 and 56%
    SXT RWD - .00020 and 55%
    matt201matt201 Member Posts: 2
    Just bought a SXT AWD today. Michaell's numbers were right on point. I had used them on LeaseGuide.com's calculator with the price/incentives I wanted the car to get to and it was perfect! Thank you!!!
    Excellent - congratulations!
    azshortyazshorty Member Posts: 27
    Could someone give me the MF and RV for an SRT 12k miles for 24/36mo? Thanks.
    SRT 392 - standard MF (.00180 or so) and 66% / 59%
    itzzsanjayitzzsanjay Member Posts: 60
    Could I please have the RV and MF for a charger R/T 15k/36mo in Florida?
    kyfdxkyfdx Moderator Posts: 238,082
    .00021 MF and 57^% residual
    jprt2015jprt2015 Member Posts: 42
    Could I please have the RV and MF for 2015 Dodger Charger Scat Pack 12k/36 and 12k/48yr in Maryland?
    Standard money factor and 65% residual for 36mo, 12K/yr.
    61% residual for 42mo, 12K/yr... 42 months is the longest term that Chrysler Capital quotes.
    Standard money factor should be in the .00160-.00180 range..
    Thank you. And this assumes 0 down as well? I am still trying to learn how to calculate the factor in. I was quoted 41k.
    Yes, $0 down.
    Plenty of lease calculators available on the web.
    rjess55rjess55 Member Posts: 7
    Can I please get mf and rv for 2015 charger rt with plus group and Navi/back up for southern california 36months 10k or 12k
    36/12 - .00021 and 59%. Add 1% for 10K
    whel10whel10 Member Posts: 18
    What is the MF and RV on a 2014 new Charger RWD on a 36mo/10k lease and a 24mo/10k also
    48mo/10k in Illinois ? Thanks
    Which trim level?
    Sorry about that ... SXT
    whel10 said:
    What is the MF and RV on a 2014 new Charger SXT RWD on a 36mo/10k lease and a 24mo/10k also 48mo/10k in Illinois ? Thanks
    24/10 - .00021 and 65%
    36/10 - .00020 and 58%
    Chrysler does not support 48 month lease terms.
    What is the MF and RV on a 2014 Charger RT/Plus RWD 36mo/10k and 24mo/10k ?
    2014: .00013 MF and 55% residual
    .00039 MF and 63% residual
    kc2285kc2285 Member Posts: 16
    I was hoping to get the MF and Residual Value for an SXT AWD in New Jersey for 10K/36 months.
    2015? .00017 MF and 59% residual
    2000blk2000blk Member Posts: 6
    Looking for the 2015 R/T and Scat pack numbers 36/15
    R/T - .00021 and 57%
    Scat Pack - Standard MF (.00160 or so) and 63%
    aguayoaguayo Member Posts: 6
    Hi Moderator
    The MF you state for this model is .00021 in FL. Just as a general question, how come the MF varies greatly from state to state? For example, you stated that the standard MF rate in Maryland varies between .0016-.0018. That extra 0 after the decimal makes a huge difference in the calculators. Is it a type or not?
    Thanks for all your help!
    Hi Moderator
    The supported lease numbers have the extra 0 in them. The standard MF is much higher, and usually applies to models that are limited in production or have a high demand on them.
    Not a typo.
    Hi Moderator
    Not a typo.
    And.. to answer your question, specifically.... the numbers don't vary from state to state. The same exact model has the same numbers.
    With the caveat that there may be some regional specials that we don't have access to..
    spidpooyspidpooy Member Posts: 182
    edited May 2015
    May I have RV and MF of this month for following models , 36 , 39 and 42 months 10k miles
    SXT AWD 2015
    RT AWD 2015
    Scat pack AWD 2015
    Any lease cash ?
    SXT AWD 2015
    RT AWD 2015
    Scat pack AWD 2015
    Any lease cash ?
    SXT AWD 2015 - .00017 and 60% / 49% for 36/39 months
    RT AWD 2015 - no AWD version of RT
    Scat pack AWD 2015 - no AWD version of Scat Pack
    No lease cash.
    42 month program not viable.
    Question for you ... are you really undecided about which vehicle you want?
    Andrew PriceAndrew Price Member Posts: 34
    edited May 2015
    Can I get the MF and RV for Arizona
    2015 RT 36/15 39/15
    2015 Scat 36/15 39/15
    2015 RT 36/15 39/15
    RT - .00010 and 58% / 54%
    Scat - standard MF (.00160-.00180) and 60% / 59%
    Thank you. To be honest sort of. You may have already realized that. Just want to explore a few other options that i might afford. Thanks again for all your helps and great information.
    eddies831eddies831 Member Posts: 2
    Hey guys, looking at either the Dodge Charger SXT AWD or the Subaru Outback 3.6r both for 36/12k and I live in New Jersey. which do you think I would get a better lease deal since they both have a good residual value. The Charger is great, but the wife and I go camping a lot as well...hence the Outback.
    Thanks for any advice and MF / RES %
    eddies831 said:
    Hey guys, looking at either the Dodge Charger SXT AWD or the Subaru Outback 3.6r both for 36/12k and I live in New Jersey. which do you think I would get a better lease deal since they both have a good residual value. The Charger is great, but the wife and I go camping a lot as well...hence the Outback. Thanks for any advice and MF / RES %
    You can not get a good deal on Outback 3.6R. It seems that it is very popular and your negotiation power is less. MF and RV is available in outback thread.
    Charger SXT AWD - .00017 and 59% for 36/12
    As noted above, these are very different vehicles. And I agree that you might be able to negotiate a better discount from sticker on the Charger than the Outback (I know, since I bought an Outback 3.6R a couple of months ago).
    Thanks a lot for the feed guys! I sat in the Charger in the NY Auto show and wanted to drive away in it and was great. The Outback was a distant plan "B"
    Thanks!!!
    Whats the acquisition fee on 2015 RT? any disposal fee?
    $595 acquisition fee. No information on disposal fee.
    carmenia83carmenia83 Member Posts: 2
    edited May 2015
    I was told $349 disposition at the dealership a couple days ago.
    EDIT: That was for an AWD SXT though.
    bodaman27bodaman27 Member Posts: 1
    Hello, would you please provide RV and MF for 2015 charger srt392 in ny. 36/12 and 48/12... dealers have been quoting 48 mo leases lately as the best value. Thank you.
    edited June 2015
    Any change with the new month MF and RV?
    2015 RT 36/15
    2015 Scat 36/15
    Lease Cash?
    We have Chrysler Capital numbers and they only go out as far as 42 months.
    36/12 residual = 57%
    42/12 residual = 53%
    2015 RT 36/15
    2015 Scat 36/15
    Lease Cash?
    RT: .00010 MF and 58% residual
    Scat: Standard MF and 60% residual
    We don't have the lease cash information
    Curious on the MF and residual for a 36 month/10,000 mile lease on: 2015 Charger R/T and 2015 Charger SXT AWD.
    RT - .00010 and 61%
    SXT AWD - .00017 and 60%
    neversatisfiedneversatisfied Member Posts: 63
    Can you lease a Charger Hellcat yet?
    Yep - standard MF (.00160 or so) and 55% for 36/15
    andre1andre1 Member Posts: 85
    What are the money factor and residuals for a 2015 Dodge Charger SRT 392 for 36/10 and 24/10? Thanks!
