A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Tires
Yes they had numb steering response and feel, but they should do for a while.
heng :::: Thank you!
This morning, after posting my question here, I saked it my auto mechanic (at local Firestone). He told me basically the same: the Eagle LS tires are not great, but decent, and it is better to change them after 25-30k miles.
Anyone have any information on this new tire? I sure would like something goodlooking for my 2K Burb to replace the Deathstones.
You can see at this tease page:
http://www.michelin.com/us/eng/tire/auto/suv/index.html
1. I've haven't seen much discussion about the Rainforce MX4's on this list. What is the tireguy's and other's opinion about how these compare to the X-one and other Michelin all-season tires.
2. I've had difficulty finding the MX4's and X-one's in stock at the local Sear's and Tires Plus (even at tirerack.com). Sear's recommends the Michelin Weatherwise Sport. Are these a clone of the Rainforce? The difference in price per tire is almost $20!
Thanks for your reply
in them. Label on driver door says 50 psi in front, 80 psi in rear. Tires say 80 psi cold
air max. I inflated tires to mfr ratings on
label, and my truck runs extremely firm (hard,
bumpy...} Any thoughts on this? I want to get as
much life out of tires as possible. They are
the new low rolling resistance tires.
thanks for any input.
Regards
Andy
If price is not an issue, why is tread wear your 2nd priority? You can have 2 sets of tires that meet all your other criteria and do 40K miles each. Or 3 sets that do 30K each.
Thanks for your response. I agree with you. I was just posting as I have had second thoughts mainly due to the Bridgestone/Firestone situation. I have always held Bridgestone in high regard.
I think I'll order the Dueller HL from tirerack.
I appreciate your opinion.
I've heard that a lower profile tire will generally have a lower tread wear rating. Technically speaking, why is that?
The 215/60 is .4" wider and .5" taller than OEM.
The 215/65 is .4" wider and 1.3" taller than OEM.
The 225/55 is .8" wider and .06" shorter than OEM.
Also, it was determined that it may be necessary to do some body mods to fit the 225/55's and I don't want to take that chance. The 16x6 wheel size also concerned the local dealer, because that tire would push its limits just a little to far...
Those Toyo's sound interesting, I'll check them out.
I will be putting X-One's on my Honda Accord soon and plan on going up one size (from 195/65x15 to 205/65x15).
Now I see that the Turanza, at least, in T, H and V, have been redesigned with the long-wearing tread on the outside and the good wet-traction tread on the inside, where it will compensate for low tread depth when the tire is well-worn. This is actually a great idea.
However, the seriousness of the dual-tread scam as practiced for so long will not suddenly be forgotten by me, so I will be avoiding Bridgestones anyway.
I do not understand, though, the meaning of "inner" and "outer" in the context. Is the tread "outer" in the radial direction, i.e. on the surface, or in lateral, i.e. on the tire "shoulder"?
I have Firestone Affinity tires on my 98 Chevy Malibu. The working surface consist of 5 "rings" or "bands", separated by the "circumferential flow-through tread grooves". See picture:
http://www.bridgestone-usa.com/products/FsaffiLH.htm
The tires are rated for 80k mile. But with 36k miles on odometer, the central ring and both shoulders are already asking for replacement. Worn out almost to the wear bars. Though, the two other rings are as good as new.
The shoulders have two sets of groves: three thin and shallow ones between every pair of wide and deep. The deep groves are still OK, but the shallow ones are practically disappear. After this the tires started to squeal even on slow turns, 15mph or so.
My auto mechanic (at the local Firestone service) examined the tires and recommend not to replace them yet. He think they are still OK. Most probably he is right: this is his speciality, and even against his direct interest (I would buy the new tires from him).
But the tires are definitely worse than used to be. Do not like my wife to drive with the tires through the wet winter, or snow.
I used to inflate the tires to the GM specs, 29psi front, 26psi rear. Recently added 3psi (32/29psi), on recommendation by the mechanic, to decrease the squealing. It helped, but the cornering traction still is worse than used to be.
Your description of your Firestone Affinity tires indicates two things:
First, they were underinflated. (Never underestimate the "cleverness" of a company such as General Motors in trying to give its customers a good ride, meaning soft ride.)
Second, the development of squealing on turns indicates ply separation or a change in tread compound with partial wear, or both; so the tires are now unsafe.
Since it is so difficult to obtain evidence on the performance of worn tires, I can only echo the posts of many others on this site — stick with Michelin and Yokohama, and maybe Pirelli for lower initial cost. To my knowledge these companies have never perpetrated the dual-tread-compound scam, and none of their tires suffer internal ply separation.
It's time to replace the OE Michelin MXV4s on my '97 Volvo 850 sedan. Tirerack.com rates the Pirelli P6000 Sport Veloce higher than the MXV4 (I'm not sure if they're comparing to the older
MXV4 or the newer MXV4 Plus), but they don't say a lot about how either tire handles in wet conditions. Their user survey says the Pirellis are better there also, but it also looks to me like the user survey has WAY more "Michelin-miles" than "Pirelli-miles", so the sample-size isn't apples-to-apples.
Since I live in the Seattle area, I'm looking for tires that will work on wet roads (I'm not talking about Texas-gully-washer wet, just three-straight-days-of-constant-rain wet) as well as providing good "sport-touring" handling on dry roads.
Any comments would be appreciated.
I think, though, that the tire shoulders wore up not due to underinflation but because of my driving style. Underinflation cannot explain the substantial wear in the very central "ring" of the tires. And my other car, the 98 Ford Taurus Wagon, also had ate up a bit prematurely the shoulders of its tires, the Yuokogama brand.
I am usually entering turns at higher speed. 5 to 10 mph higher than most people around. Without any good reason - just do not like braking, love speed and enjoy the centrifugal force. Additionally, I am adding gas after passing 1/2 to 2/3 of the turn.
The next time I probably would buy performance tires, not the touring ones.
But the Firehawk SH30 tires are performance, not touring. Probably would have a shorter life. Firestone gives them 50k warranty, but who knows how much they will deteriorate before full balding.
I am also pretty sure that Michelin would have a competitive tire, but cannot be sure that it is the XGT type mentioned so many times on this site.
As for "accepting" the Generals, I was not given a choice at any time re: the make of the replacements. I assumed that I would get fair replacement tires, and that's what I'm trying to figure out now. Perhaps we don't have a right to a particular brand tire, but we certainly have a right to a comparable brand tire.
Now, does anyone without an attitude have thoughts re: Ameri*way tires vs Firestones?
I wasn't really responding to your post, though, but to the suggestion that you should go back to the dealer and tell him that you wanted Michelins or some other brand than the General. There was considerable leeway in replacing Firestones, and that was widely publicized in recent weeks. I remember reading that they would reimburse you for almost any tire that you chose to replace your Firestones with. But once you go to the dealer, tell them to replace the tires without making any specific brand request and have them on your car and have used them, I think that it IS unreasonable to expect the dealer to take them back and then have on his shelves "used" tires.
Expecting your car dealer to offer multiple choices is unreasonable. Thinking they should replace the replacement tires (even for a second) is totally absurd.
Thanks for keeping it honest....{B^)
Your host, Bruce.
seem to be having a bit of trouble finding that
size and a tire store told me that P225/60R16 is
an
acceptable substitute. I have no experience with
tire size replacement. Is he right?
p225/60r16 = 26.63" diameter
Close enough.
Speedometer may be ever so slightly off. (the actual speed will be slightly less than than the displayed speed)
drive and enjoy.
I have had Toyo Proxes on previous BMW's and they were very good tires....although I am a fairly conservative driver....if you are more on the aggressive side....would go with the Michelin's as recommended....have the XGTH4s on my wife's car and they are great...otherwise, would jus wear out the Toyos.
Vern
I have a '97 Chevy Silverado pick-up equipped with Uniroyal Tiger Paw AWP, P235-75-R15.
I have had the truck a little over 3 years now with just over 36K miles on it. Tires are riding good and tread still looks good. I figure they will be do for replacement next year. My thought is to go ahead and buy three more of the same type and use the full size spare for the 4th tire. In light of all the information that has been provided in the media lately on tires due to the Firestone incident, I read somewhere that a normal tire will start to break down after three years. I also know from past experience (my father) that when he went to replace a tire that was seven years old on a car he barely drove, the tire nearly fell apart when the mechanic took it off the rim due to dry rot. Can anyone provide an opinion on using a brand new four year old spare for the 4th tire, or has anyone out there done it and what were your results? Thanks for any and all opinions!
Barry
I have no idea whether they will go squishy, which indicates internal ply separation, so common to Goodyear and Dunlop (and others). So keep us posted.
If it of real importance to you to save a little money I would have whichever tire place you have change the other 3 tires inspect the spare carefully; if they say its ok it probably is.
Personally, I wouldn't be bothering with that idea. I'd be selecting whatever set (of 4) best fits my needs within my budget.
