What should I do with my old, undrivable car so I may recapture some money?
I have a pretty 2000 Subaru outback LTD with 156,000 miles on it. had to replace original motor with a used motor with 114,000 miles. during the process of removing the original motor and replacing it with the new/used motor, something is out of sync with the transmission where the car jerks and slams into gear. the car shop can't seem to fix it. they said I needed new axles to fix the problem. so I replaced the axles to the tune of $800 more dollars, and the problem is still there. now they don't want to even talk to me even tho there's a one year warranty on parts and labor! Does anyone know the reason why during the performance of this work, there may have been something that affected the shifting and what it could possibly be? If it can't be fixed, does anyone know what I should do with the car to best recoup some of my losses? At this stage, I have $5,000.00 into a repair of a car that can't be driven. If I call a salvage company, will they pay me for the car or will I have to pay them to pick it up? what about selling it on craigslist to someone who wants to tinker or sell it off as parts? any advice would be appreciated! thanks
Best Answer
xwesx
Member Posts: 17,876
I pulled the engine out of my '96 Outback twice, and the first time I didn't get the engine/tranny aligned properly. In my case, I couldn't get the transmission to engage at all. After pulling it apart, I found that the torque converter was not seated correctly. After several attempts to realign it, I finally removed the converter from the flex plate, installed it in to the transmission, then aligned and attached the flex plate and engine to it separately. It was a PITA to get the nuts on the flex plate bolts for the converter, but ultimately much easier than the other method.
If your car's isue was not a problem before, then I suspect that something is either not aligned properly or not connected properly (electrical connections). Are you getting any dash lights? I know that these guys like to say that problems like this must have been pre-existing, but, in my experience, when something doesn't work right after repairs that did work right beforehand, the issue is causality, not coincidence.2018 Subaru Crosstrek, 2014 Audi Q7 TDI, 2013 Subaru Forester, 2013 Ford F250 Lariat D, 1976 Ford F250, 1969 Chevrolet C20, 1969 Ford Econoline 1005
Answers
You should have some recourse if the warranty was in writing ...
