Visitor Agreement.
Zaino doesn't "haze" to a really "white" look like most other waxes. That makes some people think that they haven't applied enough. Don't let the illusion fool you. I have a white car, and the hardest part about using Zaino is that it is very hard to tell where I have been, the haze is that minor.
It's easy to apply, but just make sure that you let it dry thoroughly before wiping it off (no buffing required). Also, try to avoid getting it on any textured plastic (just like you would with any other wax).
If it's a matter of time, do the "soup to nuts" treatment a section at a time; just be sure that you use the Z7 Wash Concentrate and wash the ENTIRE vehicle at least once and, if possible, each time you go to do a section, especially if it's over a period of time that's more than a couple or three days. The wash has polish and UV protectant in it and will provide some level of protection in those areas you haven't yet gotten to with clay, PolishLok, and your Zaino polish(es) of choice.
I also have a "on the one hand and on the other" for you. You MIGHT save yourself some money by finding out from Sal Zaino if there is a Distributor or Dealer near you. While I don't know how many of us there are and each is free to set their own prices, it's my limited experience that most of us charge the same price as directly from Zaino. You might find that you can get it quicker and find a source that, unlike Zaino, will accept credit cards, if that's important to you. You may find that it's quicker and cheaper, at least insofar as the shipping, to do it that way. Sal's email address is sal@zainobros.com. That's not much effort that could pay off.
If you find that you have to order directly from Zaino, I would stack as much on the order to spread that shipping charge over as many products as possible. My first retail purchase was for one of each of the products, except for Z3, the Polish for regular or non-clearcoat, and two each of the Z2 and Z6, but then we're talking two mini-vans and that's what I thought would carry me through at least a year and, I hoped, possibly three. Well, I became so enthusiastic that I started using my products on others' cars to show off the stuff; now it's a sideline. I now even use Z3 on my wiper arms, one of the sets of wheels, and parts of the engine that are not clearcoated and plan to use 3 on my siding and window frames since I live right on a busy street and these areas get dirty quickly.
Enjoy! It is well worth it!!
Heat, cold, washing and exposure to solvent-based cleaners and run-of-the-mill treatments damage the finish of your vinyl upholstery and vinyl trim. Some vinyl manufacturing methods use formaldehyde as the base. Introducing solvent- or formaldehyde-based treatments can accelerate vinyl deterioration by changing the original chemical balance. I reccomend zymöl Vinyl Protectant, a solvent-free, formaldehyde-free, oil-based feeding product that releases solvents and restores moisture, too!
Hope this helps! Michael
bnormann
Maintenance & Repair Message Board
You should wash your car with a strong detergent (Dawn) to remove the crud and old wax, then polish it with Swirl Remover, then follow the Swirl Remover with a fine grit polish like Meguier's Show Car Polish. The finer grit will not remove the swirls as well, but will provide a better shine in the end. A good orbital buffer is an absolute must for this kind of work, it is hard work.
After all this, your car should be blindingly shiny and ready for the wax or polymer protectant of your choice. If you do not have swirls, but want the best shine, skip the Swirl Remover and go right to the Show Car Polish.
All that having been said, not many people treat their cars to this kind of rejuvenation process. It can be very rewarding though. If your paint is is pretty good shape, but dull and swirly, it can make it look nearly new again.
It sounds like alot more work than I want, so I'll return the swirl remover, especially since the car is new. But please tell me if I messed up--a friend said you aren't supposed to wax until the car is 3 months old. Did I do any permanent damage? (Of course it rained the day after I waxed it, so no one could tell.)
In San Diego they charge about $90 to come out. They say that they charge by the size of the job, but the last time I used them, the guy took out about 12 minor door dings for the base price.
I have successfully used Turtle Wax Bug & Tar Remover (available at Wal-Mart) to remove tree sap, bugs, and tar...however, you will have to re-wax afterwards, as you probably would with any product you choose to do this job. Good Luck...
Vern
3M makes a product specifically labeled to remove tree sap...also available at Wal-Mart in the automotive section...
Vern
I'm just so reluctant to try it again. Please let me hear your comments on how to find a shop that will be capable of doing the job (I'm in Philadelphia, PA). I actually asked a local Nissan dealer and they said it will probably cost me over $300. I mean can I really trust Nissan dealers? I understand it's just difficult to match a faded color, especially with plastic and metal. But I'm sure quite a few of you here may have the same problem. Please let me know how you did it. Another body shop (quite far from my place) quoted me $400. Does it seem reasonable?
Many thanks in advance
Kaus
I have found that for this Meguiar's professional products "Swirl Remover" followed by "Show Car Polish" applied with a good orbital buffer just can't be beat. But keep in mind, you are removing the uppermost paint or clearcoat by doing this, and it's an all day job in itself. These are abrasive products, they are not waxes or polymers. Once the polishing is done, you should apply the wax or polymer of your choice.
BTW: In San Diego I use a high end shop called Amatos. But their minimum job is about $1000. However, everything is dismantled, not masked. They do many coats of perfect matched paint. At least 24 hours between coats. At least 7 days for the smalest job. This is were you'll see all the show cars, Rolls, etc. I won't go anywhere else.
to remove wax residue from plastic surface.
Thanks a lot
Now, I understand Canadian winters can be hard on a car, but is it reasonable to have $600 worth of work only last 3-4 months? The body shop says that they don't guarantee any rust work, and that no body shop would. They say this type of work could last a few months or a few years, and there is nothing I or they can do about it.
Even though they say there is no guarantee, is there anything I can do? Specifically, if there are any Canadian readers out there, what is an appropriate course of action? I'm not a vindictive person, but I think it's reasonable to expect a $600 repair to last longer than 3-4 months.
Jeff J
Wax Remover NORT
http://www.mobileworks.com/
I had a accident on the rear hatch, and left it over a year to rust, and after applying a standard RUST TREATMENT (many brands available) to the metal just before priming and painting .....even this area held up perfectly! Bottom line is the metal was not prepared right by the body shop before painting. Look at all the old rust bucket antiques restored after being severly rusted, the body work is holding up. Only a few months of life is absolutely rediculous.....and I would tell them that. Obviously this company doesn't care about quality or you as a customer.
The key is proper prep of the bare metal to kill all existing rust (most treatments convert exsting rust to black rust which is stable). Paint only sticks on clean metal free of rust. Cleansed metal should be painted the same day, metal begins to rust almost immediatley.
Ford does't know.
Do you have the same problem , and how do you get it off? thanks superduty01
Good Luck.
A few more inquires confirmed my suspicions that it was metallic residue coming from the brake lining material. I confronted the etch that tried to sell me the rail dust story and he didn't want to comment on this problem. After much hard work with a clay bar treatment I got it cleaned up. The Explorer was traded on a 2001 F150 in Oct. I had faith that Ford would resolve the problem over a period of six years so I opted for white colored vehicle. Shame on me - after just four months the problems is back. I am very disappointed in Ford for not taking care of this problem. I haven't heard of any other manufacturers having this trouble. It certainly takes some of the pride of ownership out of driving this vehicle. I understand that Raybestos has a Kevlar based material with no metallic and wonder if changing brake linings would solve the problem.
Our new Saab will be ready for pickup next Tues. and I have had a call from the dealer asking if I want a paint sealant? ("Only $299....protects against salt, bugs, etc.")
What's the story now? Should do it or not?
If you go for the low cost paint job, they will probably mask the trim and windows, do a quick rough-up of the top layer of existing paint, shoot a couple of coats of low-cost paint, as quick as possible, and send you on your way. If you are trying to cover a dark paint with a light colored paint, they may not put an adequet number of coats on to truely hide the original color, and the insides of the door jams and interior of the car, trunk, engine compartment, etc. probably won't get painted.
