Righ Axle seal leaking and new plugs with valve adjustment on 2011 Honda Accord SE CVT 99K miles
Just went to the dealer for an oil change. The dealer then said I need new spark plugs with a valve adjustment for $439 and a right axle seal replacement for $284.01. Then there is a transmission leak and they estimated $125.00.
I don't see any fluid anywhere and I don't know if these are fair prices or not. I am in unfamiliar territory. I have never had any of these issues with a Honda. Any guidance would be sincerely appreciated.
The "axle seal" leak would be expected to be a transmission fluid leak. Is there more to the story? Are there two leaks? Or were they referring to a CV (constant velocity joint) boot? Is the $125 of that actually a transmission service?
The car only has 99K miles on it and I want to keep it another 5 to 7 years if possible. It really is a great car. What would you do? Thanks again for your insights they are appreciated.
I wouldn't call that a "common problem" just one of those things that can eventually cause trouble.
Tires lasted 20,000 miles maybe and about the same for drum brakes.
I recently looked into an engine that had blown a head gasket after around 250,000. I felt no ridge in the cylinder walls at all.
So, Cardoc what do you attribute this too? Much better oil? Hotter operating temps?
