Visitor Agreement.
My family has a 95 JGC and a 97 Wrangler, both
have had serious A/C problems. Anyone know if
Daimler Chrysler has given any info on this, or is
it just bad luck for us?
#1 of 2: Info (illini4) Wed 28 Jun '00 (12:38 PM)
I was told some time ago (by a friend who was a
Jeep-Eagle service manager at the time) that the
A/C evaporator vendor for Chrysler products failed
to completely wash an acid bath out of the
evaporators during the manufacturing process.
This left acid within the core, that eventually will eat its way through the bottom of the evaporator, and of course cause it to leak. My 94 Vision TSI was a victim of this condition. Chrysler will replace the defective evaporators at no cost up to 70,000 miles (and probably beyond if you pressure them).
I have a '93 Jeep Grand Cherokee. In general it's
been a very good vehicle, but I'm currently having
a problem even the dealership can't seem to figure
out.
I'm getting a noise (sounds similar to what you
hear when the power steering pump is low on
fluid... no, it's not). The air conditioning
compressor MUST be engaged (cycle on) and the RPMs
are around 1,100. Higher or lower, and the pitch
and volume of the sound are lower. I can even
feel
a vibration in the floor pan and tailpipe.
The dealer changed out the air conditioning
compressor and an idler pulley. That didn't fix
the problem, and they've thrown up their hands.
Any help is much appreciated.
Best wishes... William Stewart (San Diego)
May have beenlike that when new.
owners, it seems that this was a common problem in the 1976 model that is why we were wondering if maybe we could replace the fan motor with something that had more RPM's...............do any of you know if this has ever been done and what would you suggest?
Thanks again...........
is this dealer just trying to pull one on us? has anyone else had this problem? and should this be covered by warranty?
thanks.
e
Is there any truth in this statement?
Also, beside my A/C, my radio is switched "ON" all the time. Am I doing any harm to my vehicle?
I am living in Austin Texas with a temperature of 105 F in these few days.
Could somebody explain to me why the noise is present whether the AC clutch is engaged or not? I'm just wondering if the dealer could be wrong.
Bruce
(Did I just say the same thing twice...?)
Yesterday I probed around the top part of the engine (PS, etc...) with a screwdriver, listening on the end and couldn't find it. This weekend I'll try listening closely to the AC compressor, yep it's attached to the bottom of the engine.
Shon
Anybody know how to remove that clutch? Most that I've seen have a hex nut in the middle.
This doesn't. The plate is pressed on. In the middle is a 1" hollow shaft, with threads on the INSIDE! In the middle is a round, ring on a smaller shaft (about 1/4 inch). On one side of this ring is a square, retainer-like piece of metal. Doesn't appear to be part of the ring.
Ok, here it is: I have a 1995 Ford Escort LX (1.9L I believe). Everything was working fine until I paid it off 2 weeks ago (go figure!) and now I'm having a problem...not sure if it's A/C related or something else. I figured I would check here since many of you A/C specialists might have seen this before...
When driving the car the last few weeks, periodically the temperature gauge would "go hot" when the car would slow down for a stoplight, or at an intersection ...at first, it would just get close to redline, then go back down as I drove. I noticed that the air would also blow hot during these times, then as I continued on, the air would go cold again and everything would be back to normal (until the next time I slowed down).
I had a mechanic friend of mine check it out and he determined that the cooling fan wasn't coming on as it was supposed to. We traced the problem down to a relay under the hood in the fuse box that had a melted terminal. He said that this relay received a signal to open or close depending on engine temp and therefore kick the fan on and off.
We replaced the relay and everything seemed to work fine. He ran the car for a solid 45 minutes with the air on cold and the gauge never redlined and all seemed well. The fan was coming on, and everything appeared to work properly. It was at this point that he contacted me to let me know he fixed the problem and I could come get my car.
That next day, just for good measure, he went out and started the car again, and once again, it started to redline again. The fan was not coming on, and air would not blow cold at all. He told me that the car would run fine without the air, but cutting the A/C on made the temp gauge redline.
There are a couple of factors also involved here: 1) even when the car's temp gauge was indicating that it was overheating, he checked the radiator and the coolant was not even bubbling..no overheating! 2) he contacted a friend of his at a local Ford dealership here in Memphis and he was told by this fellow that Ford Escorts are famous for having temperature gauge problems... this tells me that it might be the gauge, not the A/C system, causing the problem.
I'm not a car expert by any means, but it seems logical to me that if the temperature gauge is not working correctly, it is sending an incorrect signal to the car's computer, therefore not sending the correct information to the relay, which in turn is not cutting the fan on and cooling the engine properly (ie: no cold air).
Another mechanic friend of mine mentioned that it might also be the "heating/cooling temperature sensor" on the radiator itself also not working properly (not reading the radiator temperature correctly, therefore sending the wrong temp to all the gauges and gizmos, and having the same problem occur).
Any thoughts on this from anyone out there would be TREMENDOUSLY appreciated!!! It's nice having friends that are mechanics, but being fairly young, they're not always the *most* knowledgable sources of information. I'll take age and experience any day over "good buddy mechanics".
Please respond/reply to my email address: southparkaddict@hotmail.com
...and thanks again in advance!!! I owe ya' a 12 pack!
What can I expect if I take this to a mechanic??
My car seems to run too cool, the temp gauge hardly moves at all unless the car idles for a while, i believe it is a bad coolant temp sensor.
hondaman20 - I believe in leaving a/c work for a mechanic. They have the equipment to check for leaks. Recharging the system requires evacuating the a/c system then adding the freon. I am not sure but think a mechanic needs special training and license to work on a/c systems.
I once had an 1983 ford ltd stationwagon which blew warm a/c. Had the mechanic recharge the system and WOW what a difference. After about 5 minutes I would be reaching for a winter coat because it was so cold. The mechanic charged me about $70 for this work, back in 1989.
I bet I didn't even really need a new compressor.
Make sure that the compressor is the problem. My 95 Contour had a similar problem, but it turned out to be the clutch assembly that was defective. The Ford dealer wanted to replace the entire system, so I went to an independent and so far the A/C system is ice cold. Good luck, this summer is way too hot to not have A/C. Later, Wes.
They were told to "flush" the system, oil the compressor to specs, and recharge. It has never really worked correctly since. The symptom is that sometimes it cools well/blows cold (I'm in Florida), and the next time it will only be cool, (55-60 degrees at the vent). I also put on an electric fan in addition to the factory mechanical fan.
I had it checked out yesterday and the guages read 40 Lbs on the low side and around 300 on the high side, which I was told indicates the freon level is ok, but the high side is higher than it should be. Had the freon pulled out, system vacumed, and new orfic tub (the old one had filings small accumulation of filings). Recharged and I have the same problem. This unit has rear air also.
The new compressor was a "new" AC Delco and dryer. Any thoughts on what might be causing such a problem..? I have about 4 months left on the compressor warranty, by I don't know if that is the problem. What kind of readings do you normally get w/a bad compressor..?
Thanks, John
sunfire 2.4L.. When at idle speed, disengaging my
airconditioner causes the RPMs to drop about 400,
thus causing my engine to stall. Note that when
engaging the a/c, nothing abnormal happens. The
engine idles at about 750~800 rpms, so a drop to
under 500 is quite enough to cause a nasty shudder
and a stall. What could be the cause of this?
Clutch? Compressor?
I know its the a/c and not the fan beacuse this only happens in cases where the a/c has been running..
Did you also happen to find the Durango topics in our SUV conference? You should be able to find lots of Durango owners hanging out over there.
You can use the Topic Search feature on the left side of this page for Durango and then pick a topic under SUVs with a recent date.
Pat
compressor/clutch (Denso C-171 unit) that has been
retrofitted for R-134 freon should make a tapping
sound almost like bad lifters when the clutch is
engaged? Replaced the dryer and also low pressure
hose. Checked pressures for freon level, all
within green area and filled compressor with PAG
oil designed for R-134 freon. Could it be that the
C-171 compressor was designed for R-12 and since
R-134 requires higher pressures that this makes the
compressor work harder. If this is the case, will
the compressor fail early? Thanks for any assist
I don't know who makes the A/C compressors on new Honda/Acura products (May be Denso?) but my old 1997 Acura 2.5TL had the Denso unit which never gave me problems. My Impala has the V-5 Delphi/Harrison compressor.
1. Do all A/C systems lose their cooling ability over time, or does reduced cooling always indicate a leak?
2. Is it R-12 or 134a? How can I find out?
3. Firestone offers an a/c performance check where they inspect the system and do leak and performance tests. Is this a BS service or is it something that should be done periodically? Would it be better to take it to a shop that specializes in a/c systems?
Thanks for the help!
My daughter was 4 months old when we bought the car. She had never been sick. I emphasize never. Starting two days after purchasing the car she has had constant colds. We have spent about $300 on allergy medicines. Big suprise...the type of allergies that she has...major cause is mold. I am going to get Chrysler to buy back the car.
I would love to hear from anyone else that has had a similar problem. Any help would be greatly appreciated.
Pat
