And since the breed seems to be dying off, something else needs to happen.
How the test was set up.
The scope ready to go out on the road.
The failure is in the wiring harness. The yellow trace ramping up when the green trace drops shows that the current is flowing through the wire to where ever it is going to ground. The second capture between five and seven seconds shows the solenoid #3 being turned on when it is down to around .5v just like the blue and red traces drop to .5v when they are turned on. But right after the cursor you can see the votive go all the way to 0v. That means there is another ground connection being made before the computer.
The harness is down there, and it was a difficult to disconnect and pull out of the engine compartment as it is to try and see it.
The Harness removed from the rear of the engine.
Here is the failure which was only pin pointed by stripping the harness.
Now all I have to do is repair it, tape it back up and reinstall it. The best part is now that I posted this, someone can google Taurus and bucks and they will eventually find this post. What do you suppose the odds of this "exact same failure" being what is wrong with someone else's car might be? What's really bad about that is there will be no shortage of pressure to get someone to just try and use a silver bullet answer from information like this instead of guiding the technician into practicing the solid routine that resulted in the right answer, the first time. Meanwhile there will be plenty of blame for them if they give in and blindly just pull the harness out and not find anything too. Of course there would be the smug "I knew that is what it was" (when they really didn't) if by the most unlikely chance of events that they in fact confirm an abraided harness. What needs to happen first is for the outside pressure to avoid following a solid diagnostic routine has to stop. Techs have to be encouraged to be patient and disciplined and take the time to work through each and every problem. There is no other way to really develop the skills that are required. Of course they also have to be paid to do so. Anything else forces them into shooting from the hip and its time that the fingers be pointed in the right direction as to who is causing that to happen.
Don't blame your mechanic, blame the auto engineer.
The codes set at idle, but does that mean that it is lean at idle only, or is it having fuel trim issues at other engine loads? If idle only, then a vacuum leak becomes more likely. But of it is lean at all engine loads then there are other possibilities in play such as fuel quality or delivery issues. The car could still have a vacuum leak, it just might not be the only problem. You have to prove as much as you can before any repairs are attempted.
The other question was what about the catalyst efficiency codes? The first question that you need the answer to is when does the catalyst monitor run, and under what conditions?
Are there any TSB's or software updates for this vehicle?
What is the fuel pressure?
Are the O2 sensors responding correctly?
Are there any exhaust leaks, especially before the downstream catalyst and O2 sensors?
Are there misfires logged in history?
Depending on what is found in the initial investigation, then the next course of action can be determined.
Almost hate to wonder how long it will be before someone comes along and messes it up in order to turn higher profits.
There's always pros and cons but the current R&R system has bogged down under it's own (inefficient) weight.
It should be eye opening that the average age of their techs is 52. The abuses that have gone on in the shadows for the last few decades has just about wiped a generation of people from the ranks who could have been great techs.
http://www.autonews.com/article/20160307/RETAIL07/303079989/1147
When the career becomes one they would want their own kids to have, you will see most of the rest of the problems solve themselves.
Same applies to getting a flat with your lovely ran flat tires and no spare!
What do hybrid owners do? Doc, are you fully trained to work on all hybrids?
Playing with my new VOM today. Tried out a nifty new way to test for a gummed up throttle plate. If you get a value higher than .5V from the voltage input line, you probably have a dirty throttle body.
Another has three sensors, as the throttle opens one goes up from .5v to 4v, one goes from 3.5v and goes down to .5v, and the third goes from 1.5v to 3.7v.
I can think of at least six more variations offhand, but you learn to not trust your memory and make part of the routine to pull service information and make sure how a system on any given car works.
A non-continuous monitor one that takes two fails in succession to generate a trouble code and a check engine light. A monitor is a test or series of tests that evaluate systems such as catalyst efficiency, evaporative emissions, etc.
Here is the Mode $6 data right after 80,000 miles when the emissions warranty would have expired on my Ford Escape 2.5l
Now compare that data to what was captured at 150K miles.
Mode $06 can be used to see not only if a monitor that has run passed or failed, but by what margin did it actually pass of fail. In some cases it can allow for someone to zero in on exactly what part of a test resulted in a trouble code being generated. It also allows for a way to verify if a given repair has solved a specific problem completely or not.
"No one likes taking a car in for service, and as J.D. Power's latest study shows, we loathe the process more today than we did a year ago."
J.D. Power: Acura, MINI ace dealer service survey, Fiat Chrysler brings up the rear (thecarconnection.com)
In short, you as the technician lose career potential on the personal side, you lose on the professional side, someone else gains indefinitely for having done something one time and the consumer is left to wonder why
"no-one" can fix their car when it is really broken.
You get a new gas cap and a nice bill and drive off none the wiser.
http://forums.edmunds.com/discussion/40136/dodge/neon/camshaft-sensors-cheaper-by-the-dozen#latest
http://forums.edmunds.com/discussion/11316/buick/enclave/buick-enclave-no-start-problems#latest
Before the net, we'd do the same thing, but we'd have to ask around, hit the library, borrow someone's Chiltons or skim back issues of Popular Mechanics.
I belong to a guild but they are no longer guardians of secret information and it's not a path to financial success.
Those sure wouldn't work today!
BTW. It would be great if there was an auto technicians/mechanics guild, but we don't have any such thing.
I don't know about a tech union - techs up in Canada seem to have to jump through more hoops to get certified to work on cars (at least in some provinces/territories?) but all that bureaucracy may just wind up limiting consumer's options. Don't really hear all that much about the California system. Seems like that's aimed more at chasing down auto shop fraud than getting techs trained to work in the industry. And I bet that's the outfit that told AutoZone and the rest that they couldn't hook up scanners to people's cars for free.
Just a broken system.
Why not?
Guess you'll believe it when your self-driving car runs down to pick up a 3D printer built pizza at the former parts store down the street.
That reminds me - saw something unusual today. A genuine auto mechanic machine shop. How many more years do you give indies like that place? Ten? Five?
Oh, by "20 years ago" I meant the OBD-II system. It's an antiquated interface.
