timing belt replacement?
I have sent my Golf III Diesel (100,000 km) for routine check and fluid change at a local WV authorised garage. They give me back the vehicle saying that everything was in order. They just
changed the motor oil and tightened the timing belt (aged of only 20,000 km only).
After 20 kilometers on a highway, I heard a freak sound and the car stopped. First diagnosis: the motor went out of phase; however, 5 days later and with the engine completely open, the
same WV garage still can not tell me the cause of the breakdown. According to them, everything is still in order (belt, pulleys, and so on), except that the car went out of phase (alone?). I am afraid that they are not honest to me and trying to hide something. I have also heard that this is a common problem with the golf III series. Does anyone have an opinion or a suggestion for me ? Can I found some published article about this
problem ?
Thanks in advance.
and he said if i dont get then done very soon i may as well start shopping for a new car,im not exactly attached to this little 4 banger but its been very reliable, im 21 ,broke, and a new daddy, 400 seems alot for normal maintnance any help thanks Brett
I asked to see the old belt, just for grins, and I was totally amazed. I thought being 12,000 miles overdue, the belt would be worn and ready to snap. BUT, it looked brand new. No cracks, even when we bent it back and forth. The mechanic was even shocked.
I guess Honda had good reason to change the recommended replacement interval from 60K to 90K.
I should have asked for the old belt back, but it wouldn't surprise me if there was no visible wear. I understand that timing belts don't crack like drive belts; they just break.
