A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Q45 Troubles
can purchase a shop manual for the car.
Greg
Are they really as troublesome as this town hall makes them out to be?
I realize we are in the honeymoon stage of our relationship. Heh, heh!
Questions: any way to repair the small split on the left side of drivers seat? Thanks to the message board, I'll be picking up some Hide Food to maintain the rest. I've ordered an owner's manual (from Local dealer, $26. but in the meantime am clueless as to how to operate the CD changer in the trunk. It's a Sony CDX 71 w a remote: RM X43
I've tried various combinations of tuner on/off and, yes, I did load the magazine. The in dash cassette player appears to be rolling tape but no sound. I've tried different tapes
Finally, for now, any & all cup holder suggestions are welcomed
1181 members and about 16,000 post on this model repairs/maintenance etc.
So from what I'm reading on the site, I need to find out 1)is it active suspension, 2) have the chain guides been replaced, 3)Fuel injectors, 4) Torque Convertor Turbine Sensor, 5) Power steering hase return and 6) can the A/C be converted from R12 to R134A (and how much will it cost).
Have I left anything out? Should I be looking at an Accord? I love the car but can't afford to be hit with $6,000 worth of repairs during my 1st year of ownership.
HELP!
Make sure you change your fuel filter at least every 15-20k miles it will save you a lot of pumps. Eventually you will need to clean out the fuel tank and lines and injector rails as the dirt in gasoline from old fuel tanks will clog up the system or at least narrow the inside of lines.
Generally the Q engine internals are bullet proof if the oil is changed and the chain guides are replaced.
Sometimes you get lucky and all the wear items get replaced but not likely since the worst period maybe from 100k to 150k.
Generally you would be better off in looking at 94 Q models they are at least $800-$1,000 per year less expensive to maintain and can be purchased around $12,000.
You pay up front with interest or you pay annually with repairs.
I have an old Benz with 215,000 miles and it runs and looks like new. But neither I nor the previous owner has been stingy with maintenance. We replace things BEFORE they are ready to break, in other words. This is the kind of older luxury car you want to buy.
So a big folder of maintenance work is a good sign...a car with no history is, in fact, kind of scary.
I took it to the dealer and of course it didn't do it when they had it...... The hose is fine now. Is there some kind of temp. sensor in the transmission that could have gone bad? The car shifts fine except for these rare occasions. They don't know what to tell me..... Help????
Have you read all the posts in here and the Q45 topic over in Sedans conference? If not, you need to spend some time doing research here and Yahoo. You'll know alot more about your car afterwards.
(Personally, I don't know what I'm talking about just been there done that and they fixed it)
Good luck
Thank you,
pdjohannes
p.s. Jr shiftright can you shed any light??
You could go to the delear for a diagnosis and an estimate and then take it from there...maybe going online or calling around your area for alternatives. It would be good to know exactly what is going wrong first, though. The less info you have, the less anyone can tell you in return, right?
So it might be worth the $100 or so to get a good diagnosis. But I'd insist that the dealer report to you IN DETAIL. Not just "yep, it's broke!"
http://clubs.yahoo.com/clubs/infinitiownersclub
There is a person with the screen name "texasoil", who has extensive experience with the active suspensions.
In parking gear, the idling rpm speed is around 500 rmp, also there is a
hissing sound . When shift to drive the rpm dropped and the engine dies. Any similar experience and any idea what might be happening here?
Christine
Much of our work [15-25%%] on older Q is correcting problems caused by shade tree mechanics who don't have a clue as to how the complex system work! Some of these people use cheapo non factory rebuilt parts and try to make things work with tape and bailing wire. You don't want to know how many cars get towed in with the trunk full of engine/transmission parts from some generic shop which got in over its head - begging us to bail them out.
T3 Automotive LTD .. SE largest independent repairer of Lexus and Infiniti.
Interesting article on the lack of advertised power in the new Q:
http://www.detnews.com/2001/autos/0107/26/a01-254941.htm
So... here's my situation: I've had the car two months, and now the brakes fade to (literally) nothing. Right from the get-go. You can't even pump them to "hard" with the engine off and parked. No leaks, plenty of fluid. It FEELS like the break booster failed, but I would think that there would still be brakes, just no power assist. The "brake shoes" indicator is on on the dash, has been since I bought it. The AS block does have a small leak (is there a rebuild kit I should know about? $1-2k seems like quite an investment for that feature... maybe not). Is there a work-around for that? What's the best self-test to diagnose this situation, prior to turning it over to an Infiniti mechanic?
Then, about two weeks ago, a sudden ticking has shown up that appears to be coming from the left (from the rear) cylinder bank. It clatters like hell as the revs increase, then quiets down a bit at 3k PM. It's intermittent at idle and slightly above (will completely disappear about 60% of the time at idle). It also sometimes disappears after driving a bit... once it's completely warm. But cold, it sounds bad... I bought this car to take clients out to lunch, etc... it's roomy and sexy, and very nice leather, sound system, etc... It even has a "wood dash and center pod" kit installed... so it really has the look and feel of a great Euro sedan. I want to keep it (though it has nearly 150k on it, it's been very well maintained). But I don't want to sink my life savings into it.
Any ideas are welcome. I'm a pretty good mechanic, but I'm not confident I want to wrestle with all I see under that hood.
Also, if you're a local mechanic, please feel free to contact me if you feel you can do the fixes. I'll gladly pay to have a "personal mechanic". Thanks!
I assume you read Q45MAN's post # 126. You need to take this to heart. It is the absolute truth regarding the Q45. The last thing you want is some local yokel shadetree hack working on your car. It is wayyy too complex for anyone that does not have Infiniti experience. BTW, I don't run into too many Infiniti techs hanging out on the web looking to be some guy's "personal mechanic".
Finally, you need to spend some quality time at the Infiniti Owners Club on Yahoo. There is not a better place on the web for Q45 owners - - and I belong to 3 online Infiniti clubs and/or groups.
During the next 4 years I ended up driving another 120,000 miles [vs the previous 7 years 100k].
The drive shaft, the differential [whine not failure], the rear subframe [vibration], transmission mounts, engine mounts, plenum hoses,engine chain guides, the sun roof, the ac system, the radiator, the alternator, thousands of dollars in suspension parts and bushings, fuel pumps, tires, brakes, speedometer, HVAC controller, etc.
The first 100k ended up costing [ME $6,800] around around 7 cents per mile [if you add the extended warranty and warranty cost 23 cents per mile $23,100].
The second 120,000 miles cost ME $21,870 or 18.3 cents per mile.....almost $5500 per year average [$455 per month]was spent AT the Independent Facility I am now associated with [T3 Automotive LTD].
Please understand that money was not a consideration and the goal of making the car like new or later 'better than new' via upgraded factory parts was used - every vibration was corrected and rigorous standards were maintained [to the point of obsession with detail].
As a result of evaluating the failed parts and systems [every part replaced in the past 4 years was studied in detail and the root cause determined.] Wierd --thats the problem of being an engineer by trade.
By the 1992-93 model almost all of the weak systems - parts were redesigned and the car was very reliable much of this carried over to the 1994 redesign [grill] but thousands of parts were changed to update the car again by 1995 most of these bugs were worked out.
The more luxurious the car the more complicated system contained therein, but these are only designed to last a finite period....usually 100,000 miles or 7 years.
Unless you have access to junk yard parts [wrecks which have not set outside too long and are a trained technican familiar with the model avoid the early model [90-91] unless spending $4-$5k per year doesn't scare you ....many decent deals are available for $4-$5-$6k purchase price.
Engine replacement runs $6,000 for used, trans replace is $3,000 rebuilt, driveshaft $1000 new, diff is $3000 new $1000 used, AC rebuild $2500, knock sensors $1000, plenum hoses $1000.
