Diesel is not an environmental problem but an environmental solution.
As far as emissions the TDI produces less of three of five of the main emissions produced by gas or diesel engines. Carbon Dioxide (CO2), Carbon Monoxide (CO), Nitrogen Oxides (NOx)Hydrocarbons, and Particulates. TDI produces less Co2, less Hydrocarbons, less Co, about the same NOx, and more particulates. The TDI and other diesels are considered green in Europe because they produce less CO2 than gasoline engines and CO2 is the major contributor to global warming. And the diesel uses 30% less fuel.
Still think it is an environmental problem?
TDI is emissions certified in all 50 states. TDI can use biodiesel which is a renewable fuel. When using 100 biodiesel the emissions of TDI are cleaner in all five of the major emissions compared to a gasoline engine.
An environmentalist would be doing a service to the environment to drive a TDI.
Remember that driving at 65 lowers the mileage 15%.
The Gov.EPA calculates highway at 55.
I keep my tires inflated at 38 lbs.
I have a 2002 1.8T with an auto/triptonic.
Here's different TSB on the radio.
TSB Number: 9102-01
Date: JAN 02
Topic: Premium VI Radio - Controls Do Not Respond
That's all I can get from alldata.com, unless someone else here is a member.
Let me ask a quick question:
Why don't we see more gasoline-engined tractor trailers these days?
Your car must ride like a tank.
Why would you ever do that?
What is the recommended pressure for your year? Why do you not do that?
What is this, an F150?
What the heck are you doing?
The dealership admits this is a common problem, but I've heard of no recalls or anything of the like. No warranty either.
Has anyone had any experience with this? Do I need to start saving up for the other three regulators? What's the best way to let VW know of "my" little problem?
I'm wondering if that wouldn't be the way to go with all the talk of people having radio problems with the Monsoon package?
Greg, you've got two vehicles. Maybe one of each radios?
Just exactly what are the differences between the standard radio and the Monsoon system? I know they both have eight speakers. Is it just the amp. and better speakers, or is the 'head' different?
Thanks in advance.
Right now the 2002 Jetta 1.8T\automatic is in my garage cold at 40lbs. per sq. inch per tire.
Higher pressures are prefered for things like autocross. You get a very quick response from the front end especially.
No, my car doesn't ride like a tank.
I guess you have to try it for yourself and see.
I feel the contact patch is roughly the same as if my tires were at the recommended 32-41(max load range).Yes I do change the tire pressure depending upon the weather.In winter I'll keep it at 32-38 for traction then go to a higher pressure in the summer 38-41/45(rears).My theory is I'd rather save gasoline than my tread/tires.
The Michelins are surprisingly sticky so I don't seem to get any skittering around tank/truck handling.
The reason why you inflate the tires to max pressure at the autocross, isn't for the contact patch (it reduces it), it's more for the sidewalls. Having the higher pressure reduces the deflection in the sidewalls, giving you that faster response tackling the cones.
I.
Sorry to hear of your trouble. This is rather rare, but it does happen. The bushings for the rear axle beam are pretty beefy, but it's possible that they were not fully aligned from the facory, or the car has seen unusual stress to the rear end (towing,excessive loads in trunk, ......).
In answer to your questions of do I have the parts, tools, or instructions; No. These would be a dealer specific item. I wish I could be
of more help to you.
As far as other recommendations, please reply with your street address, and I will get one of our catalogs sent to you at no charge.
II.
hello, the axle beam bushings are not hard to replace, the old ones can be pressed out or knocked out with an air chisel, the new ones can be pressed into place with a homemade tool fashioned out of a long bolt or stud several large washers and the rest can be improvised, however I have never seen rear beam bushings go bad even on a car with 300,000 miles but environmental conditions or worn suspension could deteriorate them.
For half load, the tire pressure for all tires should be 26 psi.
Full load, you're correct, with the front tires getting less pressure than the rears. I could only guess when you load up the car full of passengers and/or other stuff, the front rear weight distributor will favor the rear wheels instead of the front.
I wanna know if anyone has ever gone through this. If so, how does it work? Help would be greatly appreciated, thanks.
Her Kia had 4 oil leaks in a year that started a couple of weeks after she bought it.
It was best that Michelle took her attorney because they saw that she meant business. She had all of her records, phone conversations, receipts and was well versed on the lemon law in our state (VA). Because it was an oil leak they did buy her car back for what she had paid for (She now has a 2000 Camry- she bought it used and loves it!) but they never admitted that they "product" had a defect or was "bad."
Read the lemon laws for your state. It may not include rattles but something that mechanically keeps the car from running/makes it unsafe/etc. Also many states have a certain mileage and year that the car can not be over, some states its 9 months, others 12 and/or 15,000 miles. Again, each state varies. Also many state lemon laws read that the company must have made a certain number of attempts to repair it.
I hope all works out for you on this... I was considering a Jetta in a year but after reading every one's problems... maybe I'll keep my Honda Civic.
Best of luck,
Carrie
Do I bother taking it to the dealership (1+ hour drive) or should I just deal with it?
Take what you will from that and decide if you wanna further investigate the noise.
Hey, guys, check and see if someone left something in the door pocket...maybe that's the source of your rattles, too
All new Jettas come with ABS!
http://www2.state.id.us/itd/dmv/DriverServices/chapter6.pdf
Sounds like hydroplaning doesn't occur until 55 mph.
You can tell if you have ABS or not by looking at your dashboard when you first start the car. A light should come on that says "ABS" surrounded by a cricle...IIRC, it is orange in colour.
I'm having trouble visualizing the accident. You were headed in one direction, about to make a turn which way? I'm just trying to see how you would slide across the center median...sounds like something went really wrong!
Perhaps you encountered understeer? But that *shouldn't* happen at 25 mph unless you were trying to make a hairpin curve.
