2003 Jettas have coil problems.
type H, type J, type AB negative, it does not matter. 2003 Jettas have coils problems Just go to your dealer and see - 02 AND 03 1.8T's waiting for parts.
with all due respect, of course
check out the stats for J coils on Vortex and here on Edmunds. the reason they have less complaints is because their are less J coils out there - they are fairly new. but rest assured - they are crap too those poor J people might have to wait 14k miles like I did for them to fail. not cool on VW's part.
i want to feel 100% secure that the coils are not going to be a problem - not sure that is possible
You are correct that it is under warantee. But most folks have reported that VW is having troubles supplying enough ignitors for all of the failed ones.... Thus your 'waranteed' car may sit at the dealer for weeks waiting for parts to arrive..... then there is to possibility that one of the other 3 ignitors may fail at any time.(repeating the entire scenario)
Also, a majority of the coils seem to have failed after a cold start. Mine did, and a bunch of people I know had the same thing happen. It can fail at 80mph, yes. The engine will lose power and I think it doesn't go over like 30mph or something like that. Very scary stuff. I got a phone number at home to NHTSA to make a formal complaint, I just haven't called them yet.
Also, my coil (the #3 one) went at 24K miles.
Also, I forgot to mention that the new 24V VR6 has bad coils too, I think. I know at least one person who has had trouble with their VR6 coils going. And I know for sure the W8 coils in the Passat are bad too.
I am just waiting for another coil to go in my car (only the one thus far). I already told the dealer it will sit there until all the other 3 coils are replaced, or they can keep the damn thing.
They also tried to tell me that VW is looking at VW area gas to see if our gas is bad. I was like, how does that explain the WHOLE COUNTRY having coil problems??
Anyway - they have J's in stock - $35 a pop. Once my real estate transaction are all finished, I am getting the Miata. Sure, no trunk room or FWD, but they start and run a bit better I think!
I have heard J coils going as well. Can't blame you for trading the car, Justin.
(Quattro, Avant, TT)thus, the short-supply of parts is also shared with the Audi coil failures.
The 1.8t uses a coil-on-plug design. This means there are no spark-plug wires. Each coil actually 'plugs' into a sparkplug.
BTW... the 1.8t has been known to produce over 350 Horsepower with the appropriate tuning.
http://www.hofsport.com/
Anyway....I wish you GLBS. Isn't this fun???
the only comfort is that a rental car can break down too. doesn't help much though. it is not so bad if you are in an urban area where there is a local VW shop. it stinks for people that live in the boonies where the local folk have never seen a Toyota, let alone a VW. then you have to get towed, stay in motel with roaches and smelly people, and wait for parts to come in. rent a car? yeah right - not in these places. maybe get a ride on a tractor to the nearest bus station. it can be a total nightmare. not to mention, the safety aspect that you pointed out about driving 70 and within less than a second, driving 20mph.
scary stuff.
I've used a computer for a long time, and now only really getting into it. Remember, I'm the "old" guy, it was too intimidating. I'm amazed at how much information is available. How is this mass of info in putted? Somebody has to put it in, maybe not.
Sorry, this is for Jetta problems. Thanks for the tip on the J coils. It does make me feel more comfortable, though.
I don't think this stubborness is unique to VW, however. Think about Ford, from the exploding Pinto to the rolling-over Explorer, and how hard it was to convince them to fix problems in their cars.
I have to say that while it was frustrating to have the window regulators fail so often, in my Jettas, the corporate Customer Service liaisons have been satisfactory. So my experience has been more positive, but I do agree that it would have been good for VW to send all Jetta owners a letter, which would have said: The next time you come in for service, ask for the free coils and window regulators.
And if any VW reps are reading these boards as they design the next generation Jetta, here is my suggestion: Engineer a better front air dam. Most of the Jettas I see have the same damage mine do. The plastic air dam has pried itself loose and bent out of shape; this encourages the plastic grill inserts to fall out.
I would either streamline that plastic air dam into a shape that wasn't so vulnerable to low clearance, -OR- attach a tougher air dam with a sturdier fastener. I don't see this problem with Passats or Golfs, so I assume the problem is solvable.
It of course would be hard to do a recall on the coils since they could not get the better coils quickly. VW dealers would be overwhelmed even by people that had good coils that but could not tell by themselves. I wonder if the coil vendor will even take back a coil unless it actually failed.
I would also tend to think that there has to be a Service Bulletin on this subject for sure.
BTW, it seems as if mostly 02 and 03 Jetta 1.8t's with the 180hp motor are having the coil issues...
I believe this is because clutchs are considered as a part that is worn out, like brake pads. However, in this case, the clutch could be just a part of a bigger transmission problem. I guess I have to pay for the clutch anyway, but I wonder if you guys can give me suggestions.
By the way, the replacement of clutch costs me $1,500 and the fly wheel can be additional $300(ouch!).
Being careful must be part of the equation ...
Meade
I read the post about bacteria forming in the vents. Could this be it? How can I solve it?
Any ideas/comments are welcome.
Thx
Check out the article in the NYT.
I'll have trouble ever buying a VW/Audi ever again.
I am sure everyone (by now anyway) knows the laundry list of possible problems with the 1999.5-present Jetta/Golf platform.
* Prematurely wearing rear brakes, cheap materials the culprit
* Coils (just added) on the 1.8T engines
* Power window regulators (which they FINALLY did something about, 3 years after it happend!)
* Peeling of interior trim (the latest, happening to a handful of people from VWVortex)
* Rattles galore (some examples do rattle, some do not)
This is totally rediculous for a car company to have these quality and workmanship problems in the 21st century. I was lucky that everything got worked out in my car, but I am only one example of many, many more people out there that VW is not being fair to. Total crap.
As far as that odor goes, when I had mine the dealer told me it was from the catlytic converter. Better get it checked out, it might be going bad. Mine smelled really bad as well on startup.
It costed me polishing the roters.
1: When the car is shut off for more than 30 minutes or so and I open the drivers side door there is a 3 second buzz/whir from the back end, fuel pump, exhaust do-dad? I have no idea
2: When I shut the engine off, even if it has only been running for a few seconds, ie it's cold, there is a whirring sound like a fan from the front of the engine (no, it's not the cooling fan in the radiator)
3: my fuel guage only reads 3/4 after I fill it up.
I'm a long way from the dealer so I don't want to go back until it's time for the spring oil change, any of you genius's out there have a suggestion? I checked through the boards and couldn't find any similar problems..Thanks!!
The AC system, because of the condensor, there's moisture. So eventually there will be mold/bacteria. YOu can avoid this by suffering a bit, by nearing the end of the trip (in the summer), turn off the AC compressor and run the ventilation on high for a few minutes to dry out the system.
2. Don't know, haven't heard this yet on mine.
3. I have had similar issues, but not at 3/4 tank. When I fill my tank up completely, the needle will go close to the full line, but not quite get there. Not sure why this is, but I have determined that I have about 1.8 gallons left in the tank when my gas light goes on.
It is made by the major aftermarket AC systems people, cannot remember the name but based in Brooklyn NY.
Trust helps
The engine fan is normal as well. I have heard it run after I turn the car off many times, when the engine wasn't that hot.
