Visitor Agreement.
Ray
David
You might want to try to take it to another dealership to see what they say. 4000 RPM is not "normal" at 80 mph, mine hovers below 3000 RPM. Then again, how many speeds are there for automatic transmission? It certainly sounds like its stuck in 4th or something.
I think that the door locking and alarm system program is somehow corrupted since the small red light near the drivers door lock no longer flashes when the alarm system is armed.
Anyone know how to clear out and erase the locking and security system program?
Fred ">
-Very firm 1-2 shift under light to moderate acceleration
-Shift points are over 3000 rpms
-final upshift from 3-4 only happens if I get over 40 mph, then back off the accelerator slightly. Any gas pedal pressure seems to cause a downshift back to 3rd.
I brought it to a transmission shop and they said there weren't any transmission codes stored and although they did observe the harsh 1-2 shift, they didn't notice any other issues . They gave it back to me and said their only suggestion was to tear it down and rebuild it (although they acknowledged the symptoms they saw didn't warrant it).
If this was a non-computer car I'd swear the issue was that the transmission "kick-down" linkage needed to be adjusted (showing my age again).
Any ideas?
thanks,
2 weeks ago I tried to start my car and it lugged/stalled and the check engine light came on. I then tried to start it again and it ran fine. I took the car to the VW dealership 200 miles away from home and they said that my spark plugs were bad so they replaced them and did my 80k service. Everything was fine. Drove home and happy. Two weeks later new problems came about! The other day I tried to start my car and it wouldn't start. All the lights came on but nothing. Had someone try to jump my battery but that wasn't the problem. Then my boyfriend started to put the car into gear ( its an automatic) neutral and park and he tapped on the gas a few times. He repeated this several times and finally my car started. I drove it home and everything was fine. The next day after running some errands my car did it again but this time i could not get it to start. I had my car towed to a VW dealership and they have had it for 2 days. Of course now my car starts and they dont see a problem. Im really worried because they told me to pick up my car. They did nothing since they couldn't find a problem. There is a problem!!!! What do I do. I am really scared that my car is going to break down again! Please help with any advice. Thank you. :sick:
I own a 97 Jetta Trek. It was a very nice car that I kept in very good condition. It is fully loaded and has a 5 speed manual transmission.
I was recently rear ended. Aside from the body damage, I now have transmission problems. I DID NOT have these problems before hand. It is now clicking when in gear and decelerating. I brought it by the delearship and they verified the problem.
Here's where it gets tricky. The insurance company is refusing to pay for the transmission. In addition, VW is claiming that it is not their problem either. But here's some aditional info. I had a new transmission put into the car in 2001 due to similar problems. I have 92,000 miles on the car and it already needs its second transmission!!! I think i've put around 40,000 miles on it since it was replaced.
How do you guys think I should handle this problem???
Should I press VW to replace the transmission?
Should I press the insurance company?
Am I completely screwed?
ALL opinions / advice is REALLY appreciated.
It may be worthwile to swap out the fuel-pump relay anyway...just to eliminate that as the problem.
Also, your description does not indicate if the starter moter is cranking or not. If not, I would suspect that the neutral safety switch is the problem. (The switch that makes sure that starter will only work when in Park or Neutral)
Also, the brake-pedal switch is KNOWN to be troublesome on the 2001s. (In fact my daughters 2001 had the switch replaced under warantee last month) The symptoms for the brake-pedal switch is usually the brake-lights staying on when parked thus draining the battery.
When my car did not want to start there was no sound when you turned the key. No click or tick. Just nothing. Thats the strange thing.
:confuse:
the same thing happened with my car about 6 months ago - 1999 volkswagon jetta. i had it looked at 3 times and nothing could be found to be wrong with it. i am still very nervous driving, but haven't had a problem again.
any ideas?? suggestions??
What is the "Idle Speed Stablizer" ?
How can I test or check to see if the "Idle Speed Stablizer" is My Problem? :confuse:
Thank you for your help
I was also told to check for vacuum leaks. What do you think?
Also, since after you had a mechanic muck with the mechanical setting... the computer put the idle back where it belongs.. I would venture a guess that your "idle-speed stablizer" is DEFINATLY not at fault. (Did it not correctly readjust?)
You MUST undo what that mechanic did. It is very bad to muck with the baseline settings in an effort to fix a problem. As you discovered, it will only make things worse.
First thing to to -- undo what that mechanic did.
Second thing to to -- CHECK FOR SPARKPLUG MISFIRING AT IDLE
Third --LOOK FOR VACUUM LEAKS.
Also -- CLEAN THE THROTTLEBODY
Finally, If the problem still persists -- Look for somone with a VagCom
The only way to diagnose your problem is by communicating with the on-board computers.
Here is one way to find somone that may be willing to help: http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
Go to this webpage and click on "Checking the petrol engine management system" From there, just step thru the screens and read the yellow ballons that pop up.
As an aside, my daughter is stopping by the house today with here VW golf. She has a CEL (CheckEngineLight) illuminated. I have my VagCom ready to hook up to her car to diagnose it.
However, since there are currently 3 VWs in our family and I have used VagCom on all 3 cars for various reasons, that cost should be "amortized" based on several things.
1) It costs at least $50 just to have a dealership plug his computer into your car. (even if they do not fix anything)
2) I have already diagnosed and corrected several issues with 2 of the VWs in the family.
3) The VagCom tool can also read codes from virtually any car with OBDII.
4) I can "reporgram" the cars to behave exactlty as the owners wish (beep when lock, automatically lock when driving, turn on DRL....etc)
5) I can reprogram the key-fobs when I replace batterys (dealers charge $$ for this service)
I figure my VagCom will more than pay for itself within 2 years. Given that I have been working on cars since I was old enough to hold a wrench, I see my VagCom as another tool in my toolbox. No longer do I have to "guess" why the CEL is on or why the engine stumbles at idle when one of my daughters asks me to look at her car.
With todays cars, just replacing the battery can cause the radio to go into "safe mode" and the onboard computer may need to be "reset" to keep the xmission from shifting poorly. Without a means to communicate with the onboard electronics, a trip to the dealership would be required.
Sorry to be less than helpful.....
The 2001s are part of a 7year / 70,000 mile extended warantee on the MAF sensor.
In fact, I just diagnosed my daughters 2001 Golf using laptop computer with VAG-COM installed. If you do not have access to VAG-COM, many autoparts stores will "pull the codes" from your car free of charge.
How much does it cost for these things? Is it worth fixing? I just paid it off and would like to keep it for another year or so. Any advice?
If you plan to sell it, just tell the buyer the remote does not work and they will have to do things the old-fashioned way. I doubt the selling price will be $350 less just for not having the remote lock/unlock feature.
I've had a problem with the front plastic grilles on my 2002 Jetta disappearing. Not the upper grille with the VW badge, but the black plastic ones below it. There are two smaller ones towards the corners and a longer one in the middle.
The driver's side grille had popped out twice previously. But just recently I noticed all three were missing. I think it's too strong a coincidence all three fell out at once. But based on the fact I had lost the driver's side grille twice before, I suppose it's not out of the question. My car is garaged, and the only significant length of time it is parked outside is at my office, which is monitored by security cameras.
I just wondered if anyone else had experienced a persistent problem with losing these things, as I am getting tired of replacing them! Thanks!
The others have popped loose but not lost on two occasions. After I stopped pulling the front end over the curbs when I parked, the problem seems to have rectified itself. Seems the grills like to come loose when you reverse and the shroud rubs the curb and gets a little distorted.
