Write the dealership a letter and use words like "dangerous", "ineffective braking", "concern for my family's safety" and watch 'em jump. Be courteous and professional but let them know you want to be on record about this brake defect, "just for the record".
Other than that, I have absolutely no idea what you are talking about nor why you made that comment. :confuse: :confuse:
What I meant was, why can't the VW dealer fix the brakes? The offer of buy-back suggests that they aren't too optimistic. This is primarily a hydraulic/mechnical system---everything is touch-able and replaceable.
It's not like chasing electrons around the car. :P
The return offer is on ALL of their used cars.
Thank You.
http://www.tdiparts.com/catalog/
http://www.1stvwparts.com/
http://www.worldimpex.com/
http://www.germanautoparts.com/
My preference is TDIPARTS... they specialize in diesel parts but also carry lots of stuff which covers all VWs (Brakes, oil, bodyParts....etc)
Most often, SHIPPING is the thing that gets you when shopping online. I always select a place which is PHYSICALLY close to my home to reduce shipping costs.
https://www.1stvwparts.com/partscat.html
Joe
thanks.
When you turn the key, the lights are dim, it appear no strong current/voltage is going where it supposed to. In crank position, you hear a click, click, click while the dash lights go out. I replaced the starter with a Napa lifetime warranty brand, it ran fine for two weeks, and then acted up again. Replaced the battery and it did it again.
Where is the clutch interlock switch on these cars? When it acts up, a jump start always makes the car crank if not right away, it does in a minute or so, or pushing and releasing the clutch 7-8 times while holding the key in crank position makes the car fire up also.
One sign of not starting is faint flashers when the car is unlocked with the remote botton. If the light is strong, it is certain that the car will crank and start.
In one not starting day, the mechainc stopped at my house, and showed me that the ignition wire was hot, the battery was good, and thought my replaced starter was bad. I find this possible but very unlikley.
Joe
Find out more here: http://www.vw.com/myvw/yourcar/maintenance/findschedules/en/us/
Try getting the ignition control module tested at Autozone.
Though this seems less likely if the ignition was hot.
I believe if it was the clutch interlock switch, or neutral safety switch was the culprit you would not get any click from the starter. Because the starter is not suppose to turn at all to prevent the car from moving while cranking.
Usually these symptoms relate to a bad connection or bad battery.
Take the car or battery to Autozone and get a free battery test.
Free starter test and charging system as well.
Tough it seems that the alternator is probably fine.
This will also tell you what current and voltage the starter is getting.
Had one fellow who had a short in the blower motor switch. Even though the igniton key was out of the car the short made the blower run all night and drained the battery.
Not saying that is your problem but something else could be draining the battery.
Though that does not seem likely since the battery was checked by the mechanic first thing in the morning and found good.
Could the battery cable to the starter be corroded internally?
I have seen this happen.
This prevents strong voltage and current from getting to the starter.
And when a jump is done then the double current from the batteries can make the starter operate.
Next time, with having a code for the radio avaialable, disconnect the battery from the car. Or use a settings keeper. One terminal will do. Preferably the positive. Use a battery jump starter or another vehicle battery to try and start the car. Connecting the the unattached battery cable and the post of the attached cable or attached to a ground on the car.
If it starts right away then the battery in your car may have internal issues.
If it does not then the battery probably is not the culprit.
If settings keeper was not used, then reconnect your battery. and re-code the radio if necessary.
These are the things I would look at.
Pray this helps.
The O2 sensors are under warranty still, so they'll get replaced.
As for the CEL blinking- IT DOES on occasion. Which is a misfire? Correct?
I'll look for all of these and get back to you. Thanks so much for your time.
CEL "BLINKING" = pull over and shut off engine... continued driving will cause damage. (like Catalyst getting fried)
I only have my new 2009 Jetta for two months, and didn't pay too much attention to where I park my car and popped my trunk too close the the cabinet in my garage. guess what, the white paint of the cainet left a mark in my red jetta's trunk door. Can anybody tell me what I should do: take back to the dealer let them fix it or go buy a wax (don't know which???) and try to wax it off, or go to a car wash let them fixed it?
really appreciate your answers! :sick:
Once the car starts and turn it off, and start it again. It acts like nothing was wrong. it starts and runs great.
You can not turn the window down when it acts up. The power supply appears shot. the red battery cable looks new like the previous owner replaced it.
Joe
Joe
*)Has the proper Synthetic 505.00 oil been used at all times?
*)Has the TimingBelt been replaced at the proper intervals? (Including Watepump,pullies,idlers,tensioners and related compoents)
It should be pretty obvious what the reslult of using the wrong oil does to the engine.
Some people have purchased TDIs only to find out that a cheep "quickie" TimingBelt change had been done.... the waterpump and/or pullies which were NOT changed may not make it till the next TimingBelt change interval. The result may be SERIOUS damage to engine when the pistons crash into the valves.
http://www.psswplaw.com/CM/ClassActions/Volkswagen.asp
For some reason, your car doesn't seem to be on the list. Not sure why that is.
Thanks!!
Chris Ingle
wtknght1@aol.com
Your 2001 was NOTORIOUS for the Coolant Temparture Sensor (CTS) failing. If your CTS is not green in color- REPLACE IT.
It is about $30 and takes about 20 minuts to replace. (Depending on which engine you have) The 2.0L is the easiest and you will not even lose any coolant in the process.
BTW: A vag (computer) tester may not be able to diagnose a bad CTS because this is a DUAL sensor. 1/2 of the sensor feeds the Engine Computer and the other 1/2 of the sensor feeds the dashboard temp. needle. The VAG tool can only read the 1/2 feeding the computer.
Here is a diagram of CTS loccation (2.0L engine)
But if it broke at the latch in front, that could be tricky. All cars are different but I have seen the hood successfully opened by putting the car on a lift and then tripping the latch with a long screwdriver, from underneath.
What you need to do, if you can, is find another '99 Jetta and examine how best you can attack the problem. Many people/mechanics panic and end up messing up their cars in their desperation to get the hood open.
Anyway recently, my wife told me she had this problem with her car acting up! She told me she was driving down the street, minding her own business when her driver's window and the rear, passenger-side window start going down by themselves. The back window only goes down a few inches and stops, but the front, driver-side window starts down, stops, then continues down until completely open. At the same time this is happening, the door locks start operating randomly, locking and unlocking. This is happening regularly now, and we would like to get some explanation and some resolution. Needless-to-say, the dealership has been very nice and understanding, but they say they can't find these symptoms in their Mechanic's Handbook.
Now, I know this is a weird one. I want everyone to kinow that after hearing my wife's story, I considered checking her into the local psych hospital, but I thought I would put her story on this forum and see if we could get an explanation before I resort to such drastic measures.
Has anyone got an explanation, and more importantly, a solution?
Buzz71
On this car, are the window switches AND the door locks all in one "pod" in the door?
The answer is -- YES, the drivers door contains all those contoller-switches on the armrest. HOWEVER, the other doors do not contain switches like this. (To open a door, you just pull the handle... no need to "unlock" it.... REAR doors require 2 pulls to open.)
HINT: Read owners manual!
I don't have a clear diagram to post but maybe someone else can fish one up for you. Each lamp has two adjusters.
Why dont you just read the owners manual?
