Visitor Agreement.
I have a 99 Altima GXE and when I did my first oil change, the books didn't have 99s, only 98. Since they are the exact same car, I figured it would be ok (felt too smart to ask someone). The 98's filter is larger than the 99's. Luckily, i was doing it at my mom's house so i took her car to replace it. Also my dad did the same on his Frontier truck. He got the previous year's which was wrong size.
I had looked at the Mobil1 site, but didn't peek in at the e-store.
Thanks again,
Jim M.
My truck has 27K miles and has been changed every 3000 miles with Quaker State 4x4 Synthetic Blend. I don't live in cold area, so temp. won't be to big of a factor. I leaning toward Castrol (conv. oil) 10w30 like my VW Passat runs (from factory).
Any problems switching to conv. oil from 4% syn. blend.....or should I go for the gusto and get the Mobile 1!
What about switching brands.....any problems there?
no problems between switching between conv/syn blend/syn.
if i were u though, i'd try and stick to one brand once i'm decided.
armtdm is right - castrol syntec is just a highly refined petroleum based oil. castrol originally use to buy base additives from mobil but stopped.
so our mobil gets pissed off and takes castrol to court.
Someone on another forum said that the October issue of High Performance Mopar has an article where 9hp and 3tq was gained on a Dakota R/T simply by switching to synthetics.
Also, think Mobil 1 will cause more motor noise or possibly clear up what's there?
Another question (I may have asked earlier)....what you guys think of the this rumor about Syn. oils causing leaks, or finding leaks?
John
This generally is the state of old engines that have not had their oil regularly changed. When synthetic is added, the detergents in the synth oil scrub away the gummed up dino oil, revealing the worn seal. Leaks can occur.
Also, even if there aren't any leaks, you can still have a problem. The gum that is scrubbed away can still block passages elsewhere in the engine, causing serious engine damage.
If you do switch to synth, and it probably can be done on any age vehicle if done carefully, its probably best to change slowly, using "blends" of increasing synthetic composition. And change the filter and oil frequently (some people recomend as often as every 2k - 3k miles?) until you are running full synthetic and there are no leaks and the oil remains clean.
My personal experience with conv. oil has been great:
1. Just traded Honda with 170k miles. I used Hav. 10w30 every 3k to 4k miles. The car ran great at trade in.
2. My company car is serviced every 5k miles with Hav. 10w30 as was my last one. I drive these company cars (crown vict) VERY hard and well sell them with about 130 - 140k miles. They're usually bought by another company who then uses them another 100k miles. Goes to show you ----- if a motor is serviced properly, it will last.
John
some suggestions:
1. first, are you sure it is burning oil and not leaking somewhere. If it's burning oil badly, you will have blue smoke out the tailpipe. If it's jut leaking somewhere, you can find the oily spot on the engine (valve covers or front or rear engine seals maybe) and get that fixed to stop the problem.
2. If it is in fact burning oil, it's probably worn piston rings or leaky valve seals, which as a poor college student, you wouldn't want to spend a lot of money on fixing.
3. As a poor college student, don't waste your money on synthetic oil this late in the game. Instead, I would suggest you maybe switch to Valvoline Maxlife oil, which is made for higher mileage engines like yours - it supposedly helps reduce oil consumption. You might also try switching to a higher weight oil, which can also help reduce consumption, i.e. if you are now using 10W30 oil, try going up to 10W40.
good luck
Sudden oil usage usaully points to other then worn parts. Wear occurs over time, not suddenly.
Please. summarize the newsletters!
would you please present any evidence that Amsoil is superior to Redline, Mobil 1 or vice versa.
Do you have any independent lab comparison of those oils?
You BELIEVE that Amsoil and Mobil 1 is oil of choice.
19Delta BELIEVES that RedLine is the one.
Until somebody obtains some legitimate comparison results all we can do is just speculate.
BTW it's not imposible to find RedLine or RoyalPurple.
They provide a list of distributors on their sites. RoyalPurple also sells oil in its online store.
http://www.synerlec.com/index.html
http://www.redlineoil.com/
For my cars, Amsoil only and if it were not
available it would be Mobil 1. All others are
wannabees.
Post #176
After 9 years of synthetics I swear
by them, well, swear by Mobil 1 and Amsoil only,
all others are imitations!
Post #202
I use Amsoil but in speaking to the lead
chemist at Amsoil one day he confirmed that if he
did not use Amsoil ( or probably work for them) he
would use Mobil 1. These are really the only two,
the others (new to the field) are wannabees just
jumping on the synthetic wagon as it rolls on.
Post #255
I prefer Amsoil
and have used it for nine years. Swear by it,
however, Mobil 1 is great and it is the only one I
would recommend besides Amsoil. All others are new to the field and wannabees.
Post #370
There are only two major reputable synthetics, Mobil 1 and Amsoil.
As good as any other wannabee and imitation, if I follow you correctly?
Why don't we wait to see what the newsletter recommended for synthetics other then RedLine. Real interesting if it was the only one!
Wannabees, I admit personal prejudice. Came into the market to get on the trend, not innovators or leaders. Like you say, nothing authoritative on this subject, all testimonials! By the way, Use Water Wetter from RedLine, just think their oil is too expensive.
thanks for the advice. I followed it. I bought the valvoline 10w40 maxlife for engines over 75k, and changed my oil using the valvoline. I was using 10w30 conventional quaker state, I'll let ya know what happens if the engine is still burning oil or not.
Sincerely,
Michael
BTW, I have Redline in my Forc Explorer now, purely based on my neighborhood's auto store's recommendation. The store said things similar to the claims by Amsoil supporters in this forum, something like 15 to 20K miles between oil changes and it was the only synthetic they carried.
I am going to start trying one method recommended here: changing the oil filter more often say every 4k to 5K miles and then adding another quart of new synthetic oil.
After reading all the posts I see no clear cut winner among Amsoil, Redline, and Mobil 1. I see equal numbers of people claiming good results with all three.
So, I am going to try Mobil 1 for the first time. As is the case with peoples' experiences with Wal-mart and Target stores, I found it at K-mart, on sale for $3.50 a quart, regularly something like $4.70. This was too good to pass up so I bought two cases. Also bought a Mobil 1 filter while I was there.
John
I started to use it because Consumer Reports, which (asininely) advised against the use of any synthetic, stated that this one was less viscous than the others. Where dino 10W30 gives easy starts down to 10°F, I would guess that Valvoline SynPower 10W30 gives easy starts down to about 0°F. The lower viscosity would allow the engine to rev up faster, improving acceleration. I have no evidence of the type we would all like.
Anyway, I've already put the Mobil 1 syn. 10w30 in the Chevy.....I'll probably have it in through most of the winter.
Will the Syn. form of the 10w30 help with my cold weather question?
What you think...
John
John
An exellent product.
The problem is that you don't have to make an extensive research and run millions of miles in order to evaluate the car waxes.
Oils are not that obvious.
Thank you for giving us your "just good clean information that people have had some experience."
Unfortunately your experience doesn't provide too much of information in it.
http://www.synthlubes.com/information.html
I've never seen any comparisons made by Mobil-1, Redline, or RP. Do you know of any tests conducted by the others?
Amsoil is also the only company that will tell you to extend your drain intervals, and provide a warranty against engine damage from their oil. I'm sure someone will say, "yeah, but they can easily get out of paying on the warranty by proving something else was the problem". To this I respond - then show me someone who has made a claim against Amsoil.
I am not an Amsoil dealer, but I do believe that they are the only company out there that does try to show test data to prove their superiority.
The manufacturers can claim anything they want.
And the page that you provide the link to looks,well, not convincing at all.
At least RedLine doesn't try a cheap trick like that.
Regarding the Amsoil warranty I'm joining you on "show me someone who has made a claim against Amsoil".
Again, at least Amsoil makes the effort for someone to disprove them. No one has tried. This should be proof enough. Every oil additive company on the market has been challenged in their claims, so it's not like anyone is gun-shy about taking a case to court.
Amsoil's claims are only "cheap tricks" if someone can disprove them. At least that's how I see it.
http://www.BestSyntheticOil.com/amsoil/bigoil.shtml
Try these "Red Line not so good?" article.
http://www.BestSyntheticOil.com/amsoil/red_line.shtml
And of course "Industry Standard Testing Proves Amsoil Best"
http://www.BestSyntheticOil.com/amsoil/index.shtml
I don't know about the rest of you, but when I get ready to change my oil I go then and buy the oil and filter. Ordering the oil or traveling 1,2,or 3 hours is not possible.
If it were not for the above, I would probably try the stuff---it sounds pretty good.
Thanks....John
JOhn
I too would try Amsoil if it were not so damned hard to get. Forget that. Since I plan to still change at Acura recommended points...I'll stay with Mobil 1!!!
