Don't switch to the sinthetics until after the
first scheduled oil change.
All those few luxury/sports car coming with the
synthetics from the factory are build to the
different specs with different tolerances and assembly line procedures.
I happen to be using Mobil 1 in my '97 Mazda 626 V6, just to see if I notice any difference. So far, none.
I change both oil and filter at 4000 mile intervals. When I get close to that mileage, I can actually detect the engine getting a little noisier, which is the same behavior I experienced prior to the Mobil 1. My gas mileage has not improved, nor has it worsened.
I'm really not sure why I'm performing this experiment, since I've never had engine failure related to a lubricated part. Just seemed like something to do.....I would guess I'm simply throwing money away at this point....
Unfortunately, in reality, it is not so.
Probably, you have your own house, and/or somebody is at home most of time. Not so with us.
Both my wife and I are working. And we are renting an apartment, one of about 85 in the building.
We ordered several times different merchandise by Internet. Every time we did not know exactly when it would be delivered. When returning home from work, we see a sheet of paper affixed to the outer door of our building, informing that UPS was here and will be tomorrow from 12 to 5pm or 2 to 7pm. The same with FedEX. It does not matter if we order an expensive item or something costing 5 dollars. Only US Mail let a package at our door.
I am lucky to have a very flexible schedule at work and can take day off, or take my work to home, while waiting for delivery. I would do it for major purchase, like computer, or for something we cannot easily buy something locally - like a professional book.
But I would not take day off waiting for Amsoil delivery, provided I can buy Mobil 1 in Pep Boys. They are next door from our local supermarket, 5 minutes to buy.
Have it shipped to work. I had this same problem a few years back where it was not convenient to leave a package sitting all day on the door step. I just started having everything delivered to my office.
The most unforgettable item I had shipped to work was a complete lift kit for a Jeep. Four leaf springs, shocks, etc. The looks on co-workers faces was priceless!
The great thing about shipping to work is, if you're like me, you're always there! lol.
Never thought about this.
You pick it up at the mailroom yourself without wasting anybody's time.
They have an online store too.
http://www.synerlec.com/index.html
Of course if you get it shipped at home and they leave the slip, you can call the number and have it held at your area's distribution center, then you pick it up at your leisure. i've done that with packages family members send.
http://www.oil-tech.com/amscmpr.htm
Consumer Reports taxi test in 1996:
http://www.xs11.com/stories/croil96.htm
http://www.oil-tech.com/index.htm
Same old thing.
Regarding the CR test. It's not really a test.
Thanks anyway.
If the package gets damaged during transit no mail room will accept it without making the delivery driver aware of the problem (which is carrier's liability).
Biased test indeed!
the consumer reports test is more in depth and they also test the brands mentioend above ...bust as far as i'm concerned, i DO have to take cold start-ups and extreme temperature considerations into account since i live in canada.
thats why i prefer giving the benefit of doubt to synthetics rather than conv dino oil
This article is about test by some Australian magazine, not American. Personally, I would not be surprised if other brands are popular with the antipodes :-).
BTW, even the brands are identical, the tests probably does not matter much. As I had read somewhere, some corporations are marketing different oils in different regions. I.e. the brand is the same, thank you, but the composition, additives, and/or the manufacturing process are not. As the result, the European oil of the same name can be different then the (North) American.
I think however that these different weights are included in the tests to confuse everybody. And when a non-synthetic oil is included in the same test, more confusion is generated which is after all, the point of the whole test procedure.
I think the CR article was more about oil change intervals. Sniffy, this is what they said about cold-weather starting: "One distinction: According to the laboratory tests, Mobil 1 and Pennzoil Performax synthetics flow exceptionally easily at low temperatures - a condition our taxi tests didn't simulate effectively. They also had the highest viscosity under high-temperature, high-stress conditions, when a thick oil protects the engine. Thus, these oils may be a good choice for hard driving in extreme temperatures."
'95 VW Jetta, 185K miles (sold it)
'89 Mazda MPV, 155K miles (sold it)
'91 Plymouth Acclaim, 87K miles (sold it)
'93 Ford Ranger, 127K miles (current)
'95 Dodge Stratus, 89K miles (current)
'97 Dodge Caravan, 65K miles (current)
I never used oil additives or synthetic oil. In fact I used any oil or oil filter that was on sale at the time! Two things I always did; let the engine warm up before driving off, and changed the oil and filter every 3000-4000 miles. never ever had engine problems. You should have seen the camshaft and the lifters when the mechanic took off the valve cover off the Jetta to replace the timing belt at 130K. The top part was very clean. I get my oil at 59cents after rebate, and never pay more than $2 for oil filter ( Fram or Penski)
DAvide
I do 15k oil and oem filter changes on TLC's. The most telling is at the 60k valve check and or adjust interval. According to the dealer's technical guru for TLC's, it was clean as a whistle and totally within spec's and did not need adjustment.
It is absolutely true that 3-4k conventional oil changes will fill the bill, and especially if you trade the car before 100k. The reason I use synthetic is to change the oil 3-4 times less and also to run a superior wider range of temp lubricant. Ultimately I use less product, it costs less and I dont have to go to the oil change facility or get under the hood as much.
Also, what is TLC?
Thanks for all the great debating.
John
Toyota Landcruiser and on this one app 15k a yr.
The other way to ask this question is what evidence that convinces you that conventional oil is the best?
It is you'alls money, but I have to tell you, the word waste comes to mind. Why do we waste it? You may have hit the nail on the head TOO much "dis" information
about $9.00 for my truck. Guess which one I use??
Make sure you buy the Hasitings brand not the (Hasitings Casite brand). The Casite is their lower level filer.
www.hastingsfilters.com
use the above link to find an autoparts store near you that carries "hastings"
The funny thing is that I couldn't cross reference the new "masterpiece" from Fram to any existent filter. Their website doesn't provide
any help either. The price is around $10.
http://www.framx2.com/
This appears to be a good site for comparison of synthetics. What I found interesting is that it is obviously sponsored by a Redline dealer yet for the 10W30 especially, the Amsoil has the better numbers and in all others weights is very close to Redline. Price of Redline is about $1.50-$3/quart more though
I bought a case of Redline for $6.29/qt.(Eurasian)
The Amsoil on-line store charges $5.70/qt.
Where did you get the $1.50-$3/qt. difference?
ro22tol
I don't think the oil comparison was sponsored by Redline. That article is all over the internet. It's been out a couple of years so for true comparisons, check with each brand for updated info. Very informative.
Here's an informative post on an Audi forum about oil.
http://www.audiworld.com/forum/m/a4/msgs/336510.phtml
I hope that he meant that Amsoil was higher performing for the additional prioce!
I just do not know what to think now?
