adc100...2.0L Pro No way to get the filter from the top.
Oil seepage from the valve cover seals has slowed to a crawl from leaving drops on the garage floor previously. Thought I would try this oil before changing the gaskets, back cover is a dog to get at.
Seems to run a little quieter than with the Castrol I used to use, with a Moly boost for boundary lubrication. I'll still use the Moly, but will cut it back a smidge. Lots of power, passed some cars on highway this weekend at 160 kph no problem! (although this 24 valve 4 cam car always did breath nicely!)
Surprisingly, fuel mileage has rebounded upwards back to younger engine days (about 35mpg at speeds of 110km/hour., engine rpm about 2500.)
Seems to me to be worth the extra money so far.
I've read from bobistheoilguy that SL oils are not as good as SJ, due to cutbacks on antifriction additives, for the new oils to meet some emision standards, or to help extend catalytic converter life. Correct me if I'm wrong.
Cheers, Rocky5656
I like the fact that Maxlife has an anitwear package built in. Valvoline emailed me the spec sheet on this stuff today. The numbers are pretty impressive.
kinley "Report Your Local Gas Prices Here" Mar 29, 2001 10:24am
Enjoy the series,
Bretfraz in Atlanta (really!)
That is incorrect. I have never stated that the SL oils are less in the antiwear/friction additives. The last time antiwear additives were reduced was from the move from SH to SJ.
The main difference in SJ to SL is the base stock quality improvements which makes in my opinion the SL a better quality lube.
Where you might have gotten confused is where the new proposed GF-4 oils (next step up on the api scale), is planning on reducing the antiwear additives by 50% in comparision to the current SL version. This new GF-4 proposed has now been put on hold as they are having problems in making it backward compatible with the older oils and contrevsory is that manufactures are considering makeing their own specialize formulations as they are doing with their current transmissions.
On my forums, I have all these articles posted so you may read them.
bob
Let me again tout his forum as a place where you can post very narrow topics on lubrication that would (rightly) be locked down on Edmunds. Good work Bob, your new venue is a huge improvement on the old one and you supply just the right amount of knowledgable moderating.
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Yours, Rocky5656
Did I read that post right? The GF-4 is supposed to have LESS anitwear properties? OK, I'll bite. Why would anyone want to develop a new grade of oil that's inferior to what's already available? Makes about as much sense as a left handed, metric cresent wrench!
bretfraz, I can never enjoy Los Bravos beating the Mets. And besides, nobody is "from" Atlanta, people just live there!
I doubt if we will have a choice. Normally, when oil is developed to a new standard, that's the only way it's available. Right now the standard rating is GF-3 or SL, and that's the only rating oil is available in. You can no longer buy SJ rated oil (unless you happen to find some that's been sitting around for a while), which considering the SL's, that's a good thing. If/when the GF-4 is developed, what are the chances GF-3/SL will still be available?
What I'd like to know is who the he11 buys oil in the interest of prolonging the life of their cataletic converters? Hello, Mcfly, is anybody in there? Oil is the life blood of the engine, not the exhaust system! To he11 with the converters. If this is what the GF-4 is all about, I'll be the loudest supporter to keep the GF-3's available.
Let's put it another way, if a manufacturer warrants an engine for 3 yrs/36,000 miles, andwarrants cat converters for 8 yrs/80,000 miles, which are they on the hook longer for?
SL oil is better for the engine than SJ, but SJ was worse than SH.
Which is the manufacturer's position EXACTLY !
RE: 4175
If you answer the question, perhaps it will be clearer?
Save $10/car on the smaller brick and it adds up to some real money selling close to a million cars/year.
Just another theory to ponder.
Of course, these decisions are being made by the same folks who said, "just lower the tire pressure" instead of redesigning the suspension in the Explorer" for example
TB
tboner seems to have hit the nail on the head. The vehicle manufacturers don't want the converters to last longer; they simply want the converters to last the same amount of time but at a lower cost.
My last catalytic converter replacement would have been a $1,400 repair had I not known about the 80,000 mile warranty.
I'm just a mechanic that sees the junk that GM, Ford, and Chrysler allows people to buy as dependable transportation. The best lubricant in the world won't prevent these engines from launching "way" before they should.
Was reading on the "Car Connection" how 1 columnist was lamenting how Toyota/Lexus is now selling more cars than Ford/Lincoln in North America. Well golly what do you expect when the last Ford you owned had everything wrong with it from sudden fuel injector failure, to the radio turning on and off when it felt like it, to the rear wiper going berserk after a car wash. to all the exhaust manifold studs breaking off by themselves, no rear heater fan at times, leaky rads, etc all before 80,000 miles.
I will get to GM/Chrysler another time.
My personal view on that issue is that they should set up a separate standard for the time being, and not make the oils backwards compatible, or wait until the issue is thoroughly tested.
One reason they listed was that they didn't want 2 different kinds of oil -- but wait they already have that, it's called high mileage oil.
I used STP recently as part of an oil change on my 40K Pathfinder. It sure is mechanically quieter. I did it only to increase the antiwear character of the engine lube.
Q-Are the manufacturers putting "For High Miles" on the front of the label to discourage new car owners from using it even though its better for the motor (bad for cat)?
Has anyone tested the new mobil 1 supersyn?
What synthetic oil, sj, sl...should I look for that would have a good additive package (zinc and moly...)?
Sorry for so many questions. I have been following this thread for some time now but get lost sometimes.
I presume the "for high miles" designation to be an attempt to justify elevated pricing.
There are a number of people who post here that seem to think Mobil 1 is something special. I'll bet one of them will address your question on that product.
You questioned about which product has a good, or perhaps the best, additive package. That is tough! Adding STP or other products indicates that the manufacturers are not pleasing us with the additive packages, eh? I personally would say that Redline Oil has as good a package as exists at this time, but the cost of the oil is quite high. SL is the best oil available at present (petroleum base) and that is partly due to the homogeneity afforded by hydrocracking. The non-chemists in this thread will tell you that the homogeneity produced by synthesis is better, and they ignore that the end product is the same. See? There are no answers. That is why we share opinions and take up positions...etc. >:o]
I tend to believe the PAO based stock is better than the hydrocracked but if there isnt a good antiwear package then its all just trash.
I think I will look into the STP.
Even if they only make 0 wt oils, we can just add some 90 wt here, some sticky goo there, some cleany goo over there and a slug of ol'sweller ...finish off with a couple of hits off the cactus squeezins for r'selves,,,modify the recipe just a tad towards better and like grandma says
"y'all come get her, she's done!!!"
As much as we all keep up with things on these posts here we will start learning anything fast enough, motors can only take so much and we all know not to buy anything new until it has had a couple years to be road tested by other folks right?
Damn straight, malachy72!
