Synthetic motor oil
johnroberts45
Member Posts: 1
in General
Upon delivery of my new Honda Oddesey I was
informed of the need to go 7,500 miles before an
oil change to let the break-in oil do it's job.
I usually change my oil every 3K since I do a lot
of short trip driving, rarely over 15 miles in
duration. I am considering Amesoil to preserve
engine and add better friction protection. What
has been your experience with synthetic oil? What
oil filter do you recommend? I have been using
Fram and Delco. Thanks for your input.
Fang
The benefits I've noticed after extensive testing are faster warmup from cold, and perhaps slightly better revs from the engine. I believe that all stories of better fuel mileage, greater engine life etc., are not well-founded.
What I've come to believe after lots of reading and my own experience is that synthetic is good for EXTREMES of heat, cold and racing, and if none of those things matter to you, regular engine oil will work just as well and give you just as long an engine life. But for frigid temperatures, burning desert, or the race track, synthetic has definite advantages over regular oil.
Also, you can extend your oil changes to 5,000 miles with synthetic if you wish.
I have decided to run Delco in my new Silverado. Also ran a PureOne from Purolater. The new upgraded filters from Fram are probably comparable. I forget what Fram calls their newest models.... think they have a band of gritty matl on the outside for wrench friction. Only avail in a few models.
Hopefully, non of the filters are having to do much in the normal 3,000 to 5,000 oil change interval.
Same is true switching between different brands of petroleum based oils too though. Different oils have higher or lower concentrations of detergents in them. Swithching often can result in leaks and burning of oil.
Use common sense. The reason people say that going to synthetic will cause leaks is because it creates larger leaks in older engines that are leaking to begin with. It just (because of polymer size) makes the leaks seem to appear as new leaks only because these slow caked on dino leaks become really heavy and are therefore considered "new" and "caused" by synth. The only way a synth oil will leak, is if it has a way out of the engine. Simple as that. If the gaskets are good, then synth wont leak out. I dont care how many miles an engine has on it.
I bought a 1982 Nissan 720 PU for a beater with 125K on it. It was leak free but the oil was black as night and the truck obviously was not maintained well. I went with Mobil 1 and voila! still no leaks after 175K! Tell me synth causes leaks again. Its entertaining. And if anything, the engine burned LESS oil than before. I asked the guy that sold it to me and he said Id have to put a quart in it per 1k miles. I went 3.5K per change and only put in an extra quart. The guy wasnt too bright. Obviously when you let an engine with over 100K go for 5K+ miles between changes it will start to burn thin, dirty, gas filled oil .
The tech that checked the car out said he had never seen a car with that high of mileage so well maintained. Zero valve train noise, clean engine, and near factory compression and leak down. I was beaming. I think the bottom line is.....no matter what you use......just change your oil every 3500 miles. Your engine will love you.
One helpful hint for those of you who have a car that uses 10/40 motor oil in the tranny, (Honda's and Acuras come to mind). Before I converted to syn oil I used ARCO's 10/40 graphite oil in our Honda/Acura trannies. It's amazing how much better the car shifted! Almost felt like brand new synchros!
I used PepBoys brand synthetic in my last car. It was Proline Gold, and it was very clear, Champagne color. I guess the additives change the color of the oil.
PS Headed to Montana, put M1 0W-30 in. Will report on experience in my Silverado....
I go by how much oil usage I have. If the engine stops using oil, then I feel the rings have seated. So if you have not noticed any oil usage, or oil usage has stopped, I think you can switch.
I do believe that most new car engines are pretty well broken in when you drive them off the lot. Engines are manufactured under tight tolerances and very clean conditions. Some cars come from the factory with Mobil 1.
Now waiting to take delivary of 2001 Acura CL Type "S", hope it lasts as long.
Dan
1. The study used taxi cabs with freshly rebuilt engines. Engine measurements were NOT done before the study was started, only after, so comparisons were not available and/or published. This would include changes in compression ratios, cylinder wear (size and finish), bearing wear, etc. etc.
2. Cabs are typically driven non-stop. The engines rarely cool-off. A typical consumer vehicle would go thru numerous cold-starts.
I'm not trying defend either synth or traditional oils, just pointing out that if a study is to be performed it requires rigorous attention to detail and that the data be published so that real conclusions can be made.
It is all cost/benefit.
PS. Am running 0W-30 M1 as I traveled to Yellowstone a couple of weeks ago. Great starts even as low as -29deg F. But I will go back to WalMart oil next change as most of the time it is just fine.
If your livelihood depended on 3k oil changes(26.67) and the assorted opportunities to up-sell would you advise a 15k oil change cycle (5.33) for the 80k that you would put on your van?
Actually your milege is almost perfect to use synthetic oil at up to 3-5x less change rate.
FACT: syn oil does NOT chemically break down within the engine envt. There are fleet trucks on the road that run synthetic oil for > 100,000 miles with ONE oil change with better engine protection. You just need to keep the oil clean and that's another story.
FACT: syn oil DOES provide better cold start protection (the best benefit IMHO).
FACT: syn oil keeps your engine internals clean.
etc., etc.
If you want further info I advise visiting the Amsoil web site (www.amsoil.com) or Mobil 1 site or find another OBJECTIVE technical source. If you all listen to your dealership, mechanic, ... you will be running to your dealership for an oil change every 3,000 miles. Hope this helps.
there is a consumption/environmental slant that even the environmental [non-permissible content removed] dont even talk about.
Using the #27 example of number of oil changes, my vehicle uses 8 qts, so x 26.67 I would use 213.36 quarts. Using synthetic 8 qts x 5.33 would be 42.64 qts. If you wish to ignore the fact that you are generating 5x more waste,... what can I say?
The empirical evidence, at least, suggests that for most drivers, and especially for those who plan to trade in their cars before they hit 100k mi. anyway, it doesn't make a difference what type of oil is used.
True, if you trade your car every 2 or 3 years then who gives a rip about engine wear and such; however, other benefits touted by the synthetic sellers is that you use less oil (environmental impact), have to endure fewer oil changes, and in the long run it should be cheaper.
Thanks again!
I realize what I am saying goes against organized religion though I have no bone to pick with organized religion. The 3k conventional oil/filter change is practically a foundation of religious faith. Yet in practicality, 3k oil changes are WAY extreme in the sense that you are doing it 2.5 X faster / sooner than you should even think of it (for example my manual lists 7500 miles). A rule of thumb, when going to synthetic is 2x to 3 x the service period of conventional oil. While I do a daily driver every 15k it has 68k and the oil changed 4 x., it has been trouble free and the dealer had the value covers off to measure for whether or not it needed valve adjusting. In that inspection, they said it was clean as a whistle, and to boot, needed no value adjusting. I plan to keep it past 150k. But like I have said, if you keep it till 80k why do you want to change oil so much with the conventional stuff? Especially if your problem terminates when you sell/trade/get rid of it?
Finally change to synthetic when you are comfortable with the initial break in period, for me it was 1k miles.
Wayne
It was the 'cause of water resistance. But do you think they going to screw up the public's mind trying to explain that?
Oil is water and carbon, hence the term HYDROCARBON.
also, by the way, my car manual say 7500 miles between oil change('99 mazda protege es). Dealer says 3500. What do I follow?
WHAT DO I KNOW
It takes about 2 or 3 minutes (at 56kbps) to use the "see all responses" choice to load the whole topic. Then you can either page through it, or use the Search button at the bottom of the topic to look for "Responses in Current Topic" containing whatever keyword you want to look for. (I searched for "synt" to allow for misspellings and abbreviations - 241 posts were returned.)
Meanwhile, the current version of that topic is alive and well here where there has also been discussion of synthetics.
Lots and lots of opinions!
Pat
We have two topic on motor oil running concurrently, This one on synthetic oil and the "slippery subject #2" that Pat gives the link for in her post #40. Would you all like to see these two topics combined OR separate topic for dino oil and synthetic. I think there are enough differences in peoples question re. synthetics oils only , so that topic has merit as a standalone; for me anyways.
let me know.
your new host, Bruce
They call 'em hydrocarbons because the molecular chains are made up of a carbon backbone with hydrogens attached.
Synthetics are no better than dyno when dealing with condensed moisture. The add pack is what buffers the acids formed due to combustion byproducts.
While I do run synthetics when it suits the application (low temps, race engines), I follow the same oil change schedule regardless of oil type(frequent when short cold trips, extended on long highway trips).
maybe i am just a lot poorer than most but i am looking to get the most out of my vehicle as i can so as to conserve the limited financial resources that i have for more fun things such as vacations and gifts for the kids etc.
after speaking with several chemical engineers as well as reading technical papers on the subject i have come to the conclusion that there is no comparison between the synthetic and hydrocarbon oils. the synthetic is definetly better for poor people.
my only problem was which synthetic was best. most synthetics are pao based some are diester based and one is polyol based. that one is red line. it has properties that the others don't. te polyol base is used by the military in very expensive aircraft jet engines. found testimonials to be incredible.people getting very long life from their engines and tranny.
try it you will like it!
i am not a dealer i have no axe to grind
i have tried amsoil and royal purple and found through personal experience that red line appears to be a little bit better so far in temp reduction. good luck on whatever you choose.
Plan to run my gas engine 150k to 200k before rebuild, just like the last several vehicles I have owned.
Can't figure out how full synthetic offers a better return for your money.
Dear Mr. xxxxx,
You can start using Mobil 1 in new vehicles at any time. In fact, Mobil 1 is the factory fill in Corvette LS1, LT-1 and LT-5 engines. And
Mobil and Porsche just announced a new partnership that will also have all Porsche cars manufactured at the Zuffenhausen plant lubricated with Mobil 1. One of the myths that persists about Mobil 1 is that new engines require a break-in period with conventional oil. Current engine
manufacturing technology does not require this break-in period. As the decisions by the engineers who design the Corvette and Porsche engines indicate, Mobil 1 can be used in an engine from the day you drive the car off the show room floor.
The “30” designation identifies that all three grades (0W-30, 5W-30 and 10W-30) will exhibit the same oil viscosity at normal engine operating
temperatures. The “W” designation identifies the low temperature viscosity. A smaller number indicates an ability to flow at lower
temperatures. In summary, Mobil 1 0W-30 will provide the correct viscosity protection at normal engine operating temperatures, and BETTER
protection at low temperature extremes for any vehicle that calls for a 5W-30 or 10W-30 engine oil.
If you have any additional questions, you may contact us at our E-mail address: lubes@ffx.mobil.com or by phone at 1-800-ASKMOBIL.
