I just called the mobil1 hotline to ask the question. I asked "Do your synthetic oils have a shelf life?" The answer was "No, not of any appreciable significance. You are fine to use a 10 year old bottle that has been stored in moderate conditions like an unheated garage. The only fear you might have is if you buy a new car after you have stored oil and the car may require a higher rated oil than you have in stock (SL vs. SJ for instance)."
http://www.rotella.com/answerresult.php3?rowid=48
and these folks, whoever they are, seem to concur.
http://lubricants.s5.com/shelf.htm
I think Click and Clack here give the best advice... old oil gets used in lawnmowers.
http://cartalk.cars.com/Columns/Archive/1995/September/11.html
TB
It did work very well in my 1987 LeSabre at 10K change intervals 8^)
TB
Besides, the GM 3.8L V6 has an external bypass as well, an doesn't rely on the bypass in the filter.
BTW, Wal*Mart was pretty good about taking back that last gallon jug of the stuff this morning and three loose quarts of 10W40 Valvoline Maxlife.
I got two 5 quart jugs of Castrol GTX 5W30 and a 20# bag of dog food for my exchange and a couple of bux 8^)
I was briefly tempted to return the Rotella T to my Advance Auto Parts that charges nearly DOUBLE for the oil and get a case+ of the Castrol.
TB
Has anyone seen these available at the old price recently? If not, I guess this is the new market price.
Just changed over to it on my 91 Accord with 132K miles. Figured the high load of cleaners would not hurt and was not all that more in $ than plain old dino.
I usually change oil at 3K intervals, but drive fast in a hot climate.
To transition from Mobil 1, I put in Mobil Drive Clean Plus, which is a synthetic blend "based on Mobil 1 technology." I figured it would at least mix well with the residual Mobil 1 in my crankcase. I was impressed by its diesel "CF" rating (these ratings have not changed, check out the API website). The CF rating means it can handle a lot of dirt.
I have been changing oil at 3,300 miles (so that every third oil change matches the 10,000 "official" service interval for the VW).
I will probably use up the rest of my 5-30 Mobil Drive Clean Plus on my next oil change, then change to Walmart's house brand ("Supertech") 10-30 semisynthetic blend, which is supposedly a Quaker State oil. It will be less painful to add the two quarts of oil during the oil change cycle. I am hoping tha conventional oil, now that the oils are "hydrocracked," will be sufficient in this car, which revs high. Since I live in a mild climate I will run 10-30 instead of 5-30 for better viscoscity protection.
Any thoughts? (If you want to run the Mobil Drive Clean Plus, Walmart is the cheapest place to buy it, and one of the few places that carries it.)
Most blends are only about 10% group III, so it might be cheaper to use one quart of ST synthetic with 3 quarts of ST dino.
Your dealer, oddly enough, may not use the Audi branded oil for oil changes; my VW dealer uses Castrol, not VW 15-40, because Castrol is much cheaper. I don't think the "regular" oil you use is that important in the long run (although this board is about nothing but differences in oils!), but for top-off and warranty purposes I think it is worth a trip to the parts counter.
Apparently Mobil 1 is the "only" company still using PAO. (I am sure Chevron forgot to mention Amsoil, Redline, etc, which may use PAO).
But the faq is interesting. Scroll down the page to the article "PAO - Down but not Out".
http://www.chevron.com/prodserv/baseoils/articles.shtml
Thing is, the car comes with free maintenance for 1st 4 years. Believe it or not, they're recommending oil changes at 10k intervals. I almost don't want to waste the syn oil at 5k if that's the case. Maybe I'll just bring my own oil to the dealer.
I don't think it will hurt to blend in Mobil 1-5-30. Both oils are PAO (not PAO and Group III hydrocracked). So they have ideal compatibility.
Used to use Castrol GTX, then to Castrol Syntec 10W30 for the last two oil changes. Decided recently to go full synthetic. I typically changed oil and filter(Pureone) at 5000 to 7000 mile intervals, depending on chance to do oil change. I drive 100 plus miles per day, 99% highway.
After reading some of the 5000 plus posts in this forum, I am planning to extend the change interval to 10,000 miles, due to better lubrication properties of full synthetic. Now when I wring the VQ to 6 grand, I don't feel so guilty about doing it. This motor was made to redline.
I have a 2001 VW Beetle GL 5 speed with the 2.0 liter engine. In mostly high speed (70 to 80 mph) highway driving, the engine was consuming 1 quart per 1500 to 2000 miles when I was using Mobil 1 5W-30. The 5 speed revs higher than the automatic because of different gearing. As an aside, this car would benefit from a taller 5th gear or the 6 speed gearbox VW is making.
My local Autozone used to carry Texaco Havoline Synthetic 5W-40 (see http://www.havoline.com/products/na/motoroil_smo_tech.html and scroll down to see 5W-40). With this oil, my oil consumption has decreased to one quart per 5000 miles. I picked up some more of this oil at a Texaco near Seguin, TX on a cross country drive.
My local Autozone here in Miami, FL now carries Mobil 1 0W-40 European car formula. The synthetic havoline was $3.29 versus close to $5 and up for Mobil 1.
I have also seen Lubro-moly 5w-40 listed at http://www.germanautoparts.com/ (click on Chemicals and Lubricants). It is expensive.
For perspective, I had a 1995 VW Cabrio 5 speed with the 2.0 engine. That car consumed 1 quart of oil for the entire 100,000 miles I owned it. I have kept in touch with the new owner, and it is still running strong.
I am selling my Beetle; see my ad if you are interested at http://classifieds.autos.yahoo.com/class/detail.html?srid=&ci- d=automobiles-1053002275-9152213
William
The car is basically my station car, maybe 20 miles a week on the average. A rough weekend would consist of 30-40 miles for that week. On an odd occasion, I may decide to take it for a long drive, which would mean 120 miles all around, but this is on an occasion only. All other trips are done on the minivan.
Given the info above, how often should I change since I am now using Mobile 1?
Krzys
Forgive my laziness for not doing a search!
these comments are strictly based upon my ten years of using synthetics and converting about 4 engines to synthetic along the way. (no science involved here but I do have reams of oil analysis print outs) Over 100,000 miles, quite honestly I would stay with what has worked until then and not bother.
I am thinking of running the 10-30 through my VW Golf. On 3,300 mile intervals. What do you think?
Oil consumption on the VW has gone down to 1/2 quart per 1,000 miles since I switched from Mobil 1 to Mobil Drive Clean semi-synthetic in 5-30 weight; previously 1 quart per thousand with Mobil 1 (because Mobil 1 5-30 is on the low end of the viscosity scale?). Any comments?
Anyone else notice this at their local store?
SL for $9.95.
What is different between Super Syn vs Tri Syn in terms of technically speaking????
Help
"If I'm not mistaken don't you run M1 to about 15k intervals? What type of filters do you use and have you ever had oil analysis done? If so how often? I just started using M1 in an older Lexus and I'm thinking of trying it on a year old Sequoia. Would like to go the max on intervals."
No you are not mistaken. I do run M1 to app 15k intervals. The filters I use are normally OEM. OEM for me means: the Toyota, AC Delco PF44, and just recently the VW (TDI filters) (any of the three named brands). I am also considering the Super Tech brand, (Wal Mart for 1.97 ea 24/7 price) for the specific one for my Z06 Corvette is made by Champion Labs. I also will go to the Super Tech brand for my TLC's Toyota Landcruisers (PF53 equivalent) when my OEM stash runs out in a couple of years.
For me oil analysis is just as important for conventional oil as well as synthetic. What is at issue 99/100% of the time is the perceived as well as real, extra cost. I do spot oil analysis. I would recommend that oil analysis be done if there is ANY doubt. For me, I have no doubt, but I do like to ocassionally confirm that things are going well or even if it will help me spot a less than perfect trend.
I think you will have no problems on both the older Lexus and the one year old Sequoia in switching to M1. While I have not familiarized myself with the above vehicle's technical data,if it is like most manufacturer's, then 15k oil intervals (synthetic M1) will almost be a no brainer. In the case of the older Lexus, the only real issue is that since you have been using conventional oil for most of it's life, you may or may not have a engine sludge issue. I do not say this to alarm you, for the chances are that you do NOT have sludge. The bottom line is that there will be some detergent action if you do have it, so do not be alarmed if the M1 oil gets dirty a tad sooner than normal.
I have also recently added a 2003 VW TDI (diesel) to the mix and in terms of interchange ability, sad to say, M1 does not fill the bill, except for an emergency. I am using a Mobil synthetic product called Delvac1 5w-40 for the diesel. Curiously the Delvac1 is backwards compatible with the Mobil 1 (SJ rating, not the new SL rating). So in a pinch I can use Delvac1 and or Mobil One interchangeably on the gassers. However, since the gassers call for 0,5,10w-30, I will only use the Delvac1 for the gassers in a pinch and vice versa. Incidently, since VW is rumored to be more maintenance prone, I will keep the VW recommended 10k oil change interval under the 4 yr 50k warranty period. After that I will go to the 15k or one year period.
As a transition away from Mobil 1 5-30, I figured I would first go to Mobil Drive Clean Semi Synthetic 5-30.
Curiously enough, I have only used a half quart of oil in 2,000 miles, whereas with the Mobil 1 I was using about 1 quart every 1,000 miles.
I'll monitor and let you know about the oil consumption on this non-turbo. I have enough Drive Clean for one more oil change, then it's on to Chevron Supreme 10-30 from Costco (.99 a quart!).
