lot of questions.
I've started using Mobil 1 in my '98 Regal GS. Am I using the best synthetic for my money
or is there something better. What do the terms PAO & hydocracked mean??
I see some of you prefer Amsoil..... why?? Want to learn more on this topic. Thanks in advance for any help.
If you would like to discuss this by e-mail, let me know.
VW has put out technical bulletins supporting the use of sythetics in their engines and Porche / Corvette, I believe/ now come with it from the factory.
If you like to keep your vehicles, like I do, I'd switch to the synthetics. Using the regular oil is good if you stick to the 3,000 mile change (religiously). My money's with the synthetic!
I've heard that the 2001 Civic calls for (manufacturer's standard) oil changes every 10,000 miles - anyone else hear this??
Also, I never heard of AMSOIL until I came to this topic. I've owned numerous vehicles and always change my own oil and was wondering why I had never heard of such a good product.
Regarding break down: reports are definitly out there that support Syn. oil as far as oil break down. The Syn. oils don't break down as conv. oil does. However, the break down point of conv. oil is high enough not to harm most engines. Conv. oils are perfectly fine for most engines if changed at 3k - 5k miles. I've owned vehicle with over 200,000 miles with conv. oil with not problems. I've just started using Syn. oil (Mobil 1) and I'll have to see what the results are. But 200,000 miles ain't bad. I don't think it'll get any better.
Like I said before,,,,,,I switched to Syn. oil to save a little time and trouble.....(longer intervals between changes).
John
I have to agree with you on the "testing" issue. To my knowledge, neither Amsoil and Redline subscribe to those "independent" recognized testing services as the more mainline synthetic and conventional oil manufacturers do ie Mobil One, Quaker State.
My informal take on why say Amsoil and Redline cost more per quart is the "economy of size" issue and the smaller guys overall have more cost, which of course jacks up the per unit cost.
The only reason why I think Amsoil costs more is because that it can last up to 25,000 miles or one year whichever comes first. The oil filters last for 12,500 miles or six months.
So if anyone has questions,sing out.
I do not understand this. How to change filter without changing oil? Does it mean to put the just drained oil back, or what?
Second, is it possible to perform the trick at quick lube, with the oil/filter you bring here? Or only at home?
Probably, you can explain this.
i ran mobi1 oil, synthetic atf in the transfer case, castrol 75w90 synthetic gear oil in front and rear differential, and the 4 speed manual transmission. also used valvoline semi-synthetic wheel bearing grease in the front hubs.
i now have a 1995 f350 4x4 and it has the castrol synthetic 75w90 lube in the front differential.
i will be changing my auto transmission fluid this spring to a synthetic if i can get away with it.
http://www2.briggsandstratton.com/MainSite.asp?CategoryID=37&lrID=1&ParentID=7&MSCSSID=&MB=&EPAGE=/main/RealBriggs/WebSite/NA/EN/support_maintenance/maintenance/oil_type.mb&l=0
Your host, Bruce
Al
The common practical answer is to: "Throw the baby out with the wash. We have objective data for conventional/synthetic oil, yet we still are not realistically being told how long to change use the filter. If you read between the lines for the more fastidious, a filter with synthetic oil needs to be changed about half the length of the oil. ie, if you go 15k between changes the filter can be changed @ 7.5k and 15k. So if 8 qts of synthetic oil is 4.42 a qt we are solving a 35.36 plus 3 buck filter 38.36 for the sins of a 3 buck filter, hence throwing the baby out with the wash.
In fact we should just change the 3 buck filter and add back the lost oil due to filter change. Synthetic can go 3 to 5 X's the interval of very high quality conventional oil. The filter is really the weak chain in the link. So the most economic is to change the filter in between normal change intervals.
go to "Filters - oil"
then "Ultraguard Gold".
http://www.acdelco.com/parts/1100_set.htm
http://www.pureoil.com/testing.htm
We already discussed this on a sister board today:
http://townhall-talk.edmunds.com/engaged/edmund.cgi?&f=0&c=Maintenance&t=851&q=*
Sorry for repeating.
My mothers Ford Festiva is very very dependable but she's driving it a lot in the florida'a hot weather. I think she is putting a lot of strain on that little 1.3 (65hp) engine , hot conditions, a/c on most of the time, mostly stop and go driving.
I think that Mobile 1 should be a lot better there than the conventional oil.
Someone told me that before changing over to M1 I should remove the sludge or deposits that may be
in the engine.
How and where can I get it done, and how much can it cost?
Thanks for advice.
i use mobil 1 and mobil 1 oil filter every 5k.
540 mile per week commute to work.
my 2 cents, for what its worth.
lee
I am just a computer programmer, of a scientific kind. Never was in the oil filter business, and know nothing about the multi-pass vs. single-pass issue.
But the common sense is the channels in filter are gradually clogged by the caught particles and sludge.
The more narrow channels will be completely clogged fast. The wider ones for time being will be only partially clogged - and will catch smaller particles. About the same can happen with curved channels vs. straight ones.
Al
It's a good question. Maybe the answer is : If you have some doubt maybe you need to look else where. I don't mean to sound like a know it all-I don't. Just trying to help.
Al
i am a computer programmer of the banking kind...
perhaps 5k mile oil changes are overkill in my case.... maybe i should take your advices and extend my intervals slowly..
i do all my own changes so i know what i have in my crankcase.
i can see how one would wonder if they are getting the "real stuff" if they are having their oil changed by someone.
later,,
Al
I use Mobil 1 in my 2k Maxima, and have since 1k miles... and it turns dark in about 1500 miles.
I think the only way to tell if your mechanic used Mobil 1 is to hand it to him and watch him put it in.
it depends alot on what type of oil pressure gauge
is used and where the pressure is taken from.as
for the noisey lifters here is my thinking,I have
been reading and commenting mainly on the syn oil
posts for the past year or so,I am a amsoil dealer
and user.The trend I have seen is when someone
describes his dino oil they will say,I use
valvoline 10w30,but when they talk about syn,they
only state mobil one or amsoil, it sounds like
mobil one and amsoil only have one oil whereas
both companies have many different weights.I
tried mobil one in a ford 351w in 1978 (10w30)
and had to remove it due to noisey lifters,at that
time they only had one weight oil.maybe the 440
guy should try a 20w50 oil.I think the smaller
engines probably have smaller clearences and do
not have hyd lifters.
I bought a quart of Quaker State full synthetic a few months back, and I put it in my freezer overnight. Then I improvised a test based on how fast an air bubble rose through the cold oil. I was not particularly impressed.
I chose Mobil1 0W-30 for my winter fill. BTW, Mobil publishes tech. specs. on their products on at Mobil1.com, and I haven't found that from any other manufacturer.
Later
OTOH, it DOES make sense to use consistent lubrication materials during the lifecycle of the engine and "Mobil 1" has to be one of the most readily available products.
Bruce
BOTTOM LINE: CHEAPER.
You use less product over the life of the vehicle, go to the quickie lube less (or if you do it yourself, less times with the oil dripping down your hand and arms), save the time of more "unnecessary" oil changes. And if what you are feeling is correct, (which it is not) why do you care about dirtier oil?... especially when you will change vehicles in a few yrs?
