The manufacturer's are catching on to longer interval oil changes, especially when the warranty work is on THEIR nickel. When it is on yours, of course change oil after each time you drive!!???
Corvette up to 15k
MB320 15k
My 99 Altima's schedule is 3750. Going to switch to synth too at 30K, at the next change...
Too bad the 1997 Consumer Reports test was so disappointing, and apparently clawed!
Which is why I get outraged when I hear someone here "recommend" that you "only change your oil every 15,000 miles, just use synthetic".
If you make that recommendation, are you going to pay for damage to my engine? I think not!
http://www.engineoilinfo.com/voxtop.htm
The comprehensive one will cost you very big bucks.
Also check out this link:
http://www.noria.com/boards/lab.cfm
agt cooper,
are you really all that outraged? LOL
http://www.amsoil.com/products/tso.html
They also kind of stay behind the recommendations:
http://www.amsoil.com/warranty.htm
Tjough, personally, I would prefer to have such recommendations and warranty from a big company, like Mobil.
the reasons that we don't see the results and or
test done by the major companies is that amsoil
and mobil 1 beats all the others.you could do your
own study,take a oil sample before changing to
synthetic,take one of the new syn for a base
comparison,change to the syn and take oil samples
every 5k miles.the reports will tell you what is
in the oil and how the oil is holding up.I have
used the amsoil in gas and diesel engines and
have done this and gone 25000 miles on 1 oil
change,the only thing I do different from most
syn users is I use the amsoil air filter and I
use a 2nd by-pass oil filter which filters to a
finer degree than the stock filters and lets the
engine hold from 1 to 2 quarts more oil,this
really helps on engines that only hold 4 quarts.
I wonder what your Amsoil oil looks like after 5, 10, 15, 20 thousand miles of use. I mean the color, smell etc judging by its appearance on the dipstick. The reason I'm asking is that it looks quite dark already (mobil 1) just after 4000 highway miles in one of my cars.
LOL
Also - what if I take my car every 5k to a quickie oil change place, and one time they make a mistake and don't use Mobil One, and use regular oil? Does switching like that do damage?
I want to make sure I take good care of the engine, since, being a Honda, I have to keep it revved to go anywhere
RedLine sells its line of the synth ATF's for $7.00 a bottle plus shipping.
http://www.myoilshop.com/AutoPrds.html
When changing the oil in your car, your manual calls for an oil that meets or exceeds a certain spec. It'll say must meet or exceed SG or SJ. each letter further into the alphabet is a newer tougher spec. A manufacturer could not void your warranty based on oil used as long as it meets the required spec. So when going to a synthetic, your drain intervals are increased because the oil is less likely to break down from heat. Your filter is removing the contaminants and that is why Amsoil recommends a 12,000 mile filter change interval. Synthetic is very durable when it comes to heat. I have a friend who is a distributor for amsoil and he has a big block Suburban with 90,000 miles on 1 oil change. He changed filters every 10 and sends out oil samples. The oil still has not broke down or degraded from when it was new. He tows very large boats and construction equipment almost daily. That's proff enough for me.
My biggest reason for changing to amsoil would be that I lease my vehicle and if I change the oil every 25,000 miles, I only have to change it once before turning it in and I have no fear of any oil related maladies.
Enjoy
I would like to hear about the real life experiences with the dealerships and manufacturers.
I consider what you have said to be sound reasoning for using Synthetic oil. While it solves a host of concerns and situations, a lot of folks are still dealing with "old oil propaganda".
#674
Like I have said in prior posts, Corvette has up to 15k recommended oil changes.
MB 320 service providers ADAMATELY will not change oil before the recommended interval of 15k. They even go so far as to say, if you want it changed before that interval, you must pay for it!!!
My TLC (Toyota Landcruiser) service provider (dealer) has told me that if I had an engine "malady" with 15k Mobil One oil changes he would honor the warranty. Obviously, if I ran the thing without oil that would not be covered!!!???)
You have to remember that people will sue over (ANYTHING) ie, spilled coffee in the lap and win, even though logically, even grandmother's know that hot liquids can burn you.
More to a real life example that may not have been mentioned, is the concept of excess oil consumption. Each manufacturer has its definition of that. So, say it is 1qt in 1000-1500. Say you walk around "suit happy" and structural with you nose in the air, i.e. don't check your oil. Hey, it doesnt take a rocket scientist to see that for lack of checking your dipstick, you will be 15 qts low at the required interval. But before you are 15 qts low you would have experienced meltdown or catastrophic failure of a perfectly good engine. Now the fun begins!???
Best comprimise is what I do and nikecar stated in #676, which is to wait 30-60 min and then let it drain COMPLETELY ( might be 10-30 mins).
Question, how many of you have magnitized your drain plug and/or placed a magnet by you drain plug?
And about letting the oil drain out. After its drained out, I also blow down the oil cap hole. Doesn't do much really, but I can hear some oil come out the drain. the more out, the merrier!
I think the quikest change I've done was 30 minutes total, because it was cold outside. Normally i spend a nice hour taking my time. no quickie lube place could match the TLC the cars deserve.
Later
Basically, the longer the engine has set, the slower the oil will drain because of cooling, and some of the contaminants might be settling out of the oil.
Regardless, I think we all can agree that changing the oil, regardless of temp, is better than not changing it
(which to me is a good reason to use synthetic. A whole lot less oil product generated gunk is present with synthetic)
-Chris
-Chris
"Corvettes, Porches, Vipers, and all AMG models from Mercedes-Benz come with Mobil 1 as the factory fill...
Just a note on changing oil I sometimes change the oil the next morning after it has sat for about 10 hrs. Drain and take the oil filter off...Wait awhile then take a new cheap oil like 10w30 pour that in quickly then let that drain out in the hope that it will carry some of the garbage out before I put synthetic in. Of course you don't have wait so long and it may work better with the engine warm to get the contaminants out.
http://www.caranddriver.com/xp/Caranddriver/columns/2000/November/200011_columns_bedard.xml
Regardless, I think you guys know what I meant
you are dead right. solids in suspension will drain. solids that aren't, won't.
-Chris
The only synthetic that my dealer offers is Castrol, which is not really a synthetic. Would it be worth it to switch to this oil? I don't think so, but am open to suggestions.
I figure that if I use Mobil 1 and a good filter (OEM or better) each oil change would cost around $30, plus my labor and time. Also would have to dispose of the used oil.
Also, I have a 91 Accord with 150,000 miles that has had a regular diet of Castrol 10w30. Still runs perfect and uses no oil.
So, with my circumstances, can anyone help me justify switching to Mobil 1? I do not want to buy the oil and carry it to the dealer. If I buy the oil, I'd just as soon change it myself.
While i do not necessarily recommend this; some folks have found it safe enough to just change the filter at this interval (14,000-15,000) and top up the lost oil due to consumption and oil filter change, and they are good to go to 25,000 miles. In any case, you can do as prior posts have indicated and do a 10 buck or less oil analysis (sort of like a "urine" sample) send it in and get the REAL 411 on the oil's condition. Most that have done it have indicated much useable life left.
Later
