Does anyone know who makes a 5W-20 product? I've used M1 in the past but they don't have a 5W-20 product. Any recommendations?
oil filter on my vehicles. Seems like it makes a lot of sense. Has any one out there had any experience with By-Pass oil filteration system?
If so, please let me know your thoughts and experiences.
Later
Not aware of any synthetic of that grade.
I would highly recommend it if you have the room. You can go for years without changing you oil along with an oil analysis
If you drop the pan and it looks clean, and you remove the valve cover and it also looks clean (no sludge), you might consider switching. If you do switch, you might want to do so very slowly; make your own blends and incrementally increase the amount of synthetic. Change very frequently if the oil turns black quickly.
(For me I have five vehicles, so pardon me if I opt for the increased oil change intervals)
Another way to look at it is: how much per mile does it cost you to lubricate? (again, using my own data, it is: Conventional $.01 VS Synthetic $.003677)
So "cheap insurance" as frequent oil changes are sometimes referred, COSTS 2.72 times per mile more than synthetic. Not to mention having to go change it 4.997 times more often. In a business sense that is NOT cheap insurance but 2.72 times higher operating costs.
Since he can't verify how well the vehicle was maintained for the first 100,000 miles, he should assume the worse and expect there might be a leak somewhere.
Incidently the oil analysis does analysize metal wear and shavings suspended in the oil, indicating potential and actual wear problems. It is good to finally see this technology available to consumers.
(1.) What synthetic oil to use - 5W30 ??
(2.) Should I drain out the oil that comes from the factory and use the Synthetic oil before driving off from the dealership ?
(3.) If not, should I wait until I break in the engine (1000 miles) before changing to the synthetic oil ?
(4.) Someone suggested that I completely flush out the existing oil before adding the synthetic oil. Is this a special procedure or just a normal oil change ?
Appreciate any feedback.
Then after that, use the weight that is specified for the Sienna (I believe it is 5-30W, RTFM for the proper specifications. AND just a normal oil change using synthetic instead)
would give the vehicle the best protection.
The best protection for the engine the mankind ever invented.
Most mechanics know little about syn. oil.
How many of us posters are auto mechanics?
If the mechanic is knowledgable about syn. oil
it would behoove him not to recommend it in the
long run because your motor would last longer,
this would not hold true for all mechanics but
some may think that way.
One more note-Do the expensive oil filters actually help that much if you change the oil and filter every 3-5k? If I'm going to pay double or tripple the price, will it be worth it? I live in San Diego, and do a 50/50 mix of highway/stop-go driving.
but by all means switch my man... don't keep the dinosaurs alive in your car!!!
One of the very good oil filters is the Purolator Pure One, and they only cost $6-7.
http://www.synerlec.com/faq.html
Accidently I've run into your discussion group. It's great, we can exchange our observations and experiences. I have two vehicles. One is Passat'99 1.8, the other Dakota'00 4.7. Both have roughly 20K miles. Passat had free maintenance @ every 5K, what an abuse with Kendal oil or what his name. Dodge I maintain myself. Regular Castrol 5W-30 every 3K. Does it make sense to switch to synthec. Passat has 100K warranty on the power train and already has been abused. Dodge has low rpm. high torque engine which never runs above 3000 rpm. I always thought that frequent oil change @ 3K is better than synthec. @ 10K. If you want to change synthec. @ every 3K. it's gonna cost a fortune (3 times the cost of regular oil). How much longer the engine is going to be in top shape if on regular oil it's pretty good even up to 150K. The other thing. Do we want to keep our cars and trucks for 10 years. Why nobody mentions Castrol, isn't it a good product? Please help me do a right choice. Has anybody noticed any improvement in gas economy after switching for synthec. Is it true you shouldn't go back to regular oil once you pure in synthec. Thank you all for attention.
Later
Let us consider very conservative 6 month / 6,000 mile synthetic oil change schedule, and Pep Boys prices:
5 quarts of Mobil-1 @$4.50, plus quality filter - Pure One, @$6, total about $30 every 6 month.
5 quarts of brand-name usual oil, @$1.30, plus stock filter @$3, total about $10 every 3 months.
So, it cost $20 more per year, for couple of hours of owner's time. And, as a bonus, better engine protection, especially in winter.
1. Will switching to 5w30 affect my motor since I've been using 10w30?
2. Is there a need to switch to 5w30 based on what I said above?
Another issue I'm concerned about is that I switched to Mobil 1 at 26k miles. I haven't had any leaks thus far, but I'm concerned that 5w30 may be thinner? What y'll think?
John
in south Texas.In answer to your question the
5w30 will not leak out,you will probably notice a
easier start in cold weather.
I heard that mobil one had a 0w30 oil out,has
anyone seen it?
Very often the Mobil-1 10w-30 is sold-out, or 5w-30, and sometimes both, but 0w-30 always is on the shelf. Probably, the demand is low with the New England climate.
By the way, I am not sure at all if the 0w-30 will be good for my 3800 General Motors engine. The 10w-30 is recommended by GM, except for cold winter.
The car is new, 4,500 miles, changed oil only once, at 2k. I am planing to replace the dyno oil by Mobil-1 after about 10k miles. 10w-30, not 0w-30. I am afraid the low viscosity oil could leak into chamber through rings, if the car will sit long enough at parking lot.
INKY
merc. wagon with a 302 with 235,000 miles,no
problem,also use it in a 94 lexus.Am not sure
what above poster means the oil could leak thru
rings into chamber when car sits,the oil is in sump and would have to somehow flo up to ring area.I have a friend in Chicago who has a
motorhome with a ford 460,it would overheat in
traffic,he switched to the 0w30 and never had the
problem again.
