They dealer put new tires on it. The ones that were on it looked ok..but they though perhaps there was something wrong with them. So new tires..re alignment again and it doesnt pull anymore.
I find it 'favors' the left..but its not a pull like it was.
Compared to other cars I've had it seems to follow the road more. Now, this is if i hold the steering wheel very loose. With normal driving it seems ok. I'm just senstitve now to it from looking for the pull.
I found it will drift on the same section of road everytime. my other cars didnt do this.
strange car. but smooth!
Their coolant has been red for most of a decade now.
If you live in an area where the temperature drops below freezing, make sure you use the right type of fluids:
Engine oil: 5W-30 instead of 10W-30
Coolant: put 60-70% ethylene-glycol anti-freeze
Washer: use anti-freeze washer fluid
Keep some de-icer in your car just in case you need it.
Good luck!
Tony
The new (and expensive) synthetic ATF's have freezing points @ -78 F.; some even don't freeze period!
Hope that helps you.
Tony
http://www.pennzoil.com/penn/products/car_truck/pdfs/gearoil/atf.- pdf
Drive safely and keep warm!
Tony
Hoping to purchase one soon!
Thanks.........J
It's an excellent car. I've had it for 2 years now and I'm very pleased with its performance and reliability. In my opinion, it's better than the 2002-2003 model. The 2001 is the last Camry model made in Japan. Camries are now made in the USA for the local market and there seems to be a difference!
Go for it!
Tony
This is my first "solo" car purchase and I've never bought used before so I'm a little nervous! People are telling me the 4 cyl is just as good as the V6, but I travel a lot and like the extra power over a 4 cyl.
I'll know by the weekend!
J
Looking for ideas as to what may be causing it. I hate to spend $500 for this cleaning again to last a couple months. If the engine was worn, wouldn't the low pressure occur at low idle speeds but not highway speeds? Anyone heard of using transmission fluid in with your oil to clean your engine? Will the sludge keep reoccuring? Is there a full proof way to remove it?
I've read about other Toyota oil sludge problems and the Special Policy Adjustment, but unfortunately, it cuts off at 1997 and does not apply to my 1994 Camry.
And how do you know the engine is sludged? Are you guessing, or have you actually seen the sludge (it will be visible through the oil fill hole)?
This sounds a lot more like an oil light malfunctioning - have you had it checked?
so there is still a very small percentage of camry came to US by boat
The 2x2 mark is a cover that will pop off to allow access to a threaded hole. Into this threaded hole, you can screw a heavy-duty eye-bolt that can then be used to drag your Camry out of the snow, ditch, or whatever. This Heavy-duty eye-bolt is conveniently located in the trunk, in the spare tire compartment, next to the jack crank.
I hope you never have to use it.
Also notice two tow-hooks located along the underside of the back bumper, almost directly under each rear brake light.
Later.
I have not seen the sludge myself, since I'm not exactly sure what to look for. Would I see it when doing oil changes or near the filter?
I'm coming to the conclusion that it is a sluge problem again, since the light does not come on immediately when I start my car. It usually takes 10-15 miles before the light comes on.
On one recent long distance travel, the light came on and stayed on for 100 miles. I thought maybe it was just like light malfunctioning, until I heard my engine making a racketing noise. I think this was the rods in my engine hitting metal on metal. After sitting for 20 minutes and turning my car back on, the light was off and I completed my ride.
I don't think it is the oil light, but I am going to replace the sending unit anyway, to at least eliminate that possibility.
Thanks for you help!
If the light only comes on after everything has heated up, that bodes ill too: rod knock maybe, if it is clanking, or something like it.
I am so curious to hear what this mystery screen is inside the oil pan - never heard of such a thing.
The "mystery" screen... I'm not a car expert, I have not see the screen myself, nor do I know where it's located. It was my guess that this screen is near the oil pump, which is sucking in oil from the oil pan. The point was that I have had the screen cleaned to remove oil sludge build up.
my bet is no longer on malfunctioning light with these stories of "clanking".
WEll, i finally inspected the car and noticed quite a few scratches (some or kind of like scrapes, such that no paint is gone) on the car and some major scratches in the grooves of the car handles. Of course, i didn't make any of these scratches, but do you think that the dealer will do anything especially since it has been a week and i already signed the contract? should i ask for a new paint job or somthine? or am i screwed for not checking when i bought it. thanks
You already signed an 'inspection sheet' when you received your car from the dealer. All scrathces/dents should have been mentioned on it. So, technically you're stuck with it, but since the dealer told you to inform him about scratches (I guess he knew about them)I would take it back to him ASAP. It doesn't need a 'paint job' -- just a few touch-ups.
Talk to the same guy who told you about finding the scratches and don't ask him if they can do it or not; just show him the scratches and ask him when you can pick up the car after it's done.
If you're not satisfied with the dealer you can mention that in the questionnaire that Toytoa will mail you soon -- dealers get very sensitive about this evaluation because it affects their status.
Good luck!
Tony
Took it in for several service bulletin modifications but the problem is now hidden. Instead of bucking, I'm getting a slight delay as if a gust of wind hit me.
Anyone else experiencing this problem? Hard not to notice while maintaining a steady speed between 40 -50mph.
Also since the modifications, I'm getting a clunk when I engage the transmission in the morning.
What a dog.
You may email privately to cmore77@attbi.com
Taking it in for service this Thursday -- but was wondering if anyone out there might be able to tell me what it could be?
Anybody know how to do this? Is there a wire I can cut or something?
My problem (I'm not going to go into a long story here) is that so many trivial things cause the CEL to come on that it's nothing but an irritation, and I still want to MAKE IT STOP! Can anybody tell me how?
"bad CV joint - you will need to replace the half axle most likely."
ANY IDEA HOW MUCH THIS MIGHT COST AT A TOYOTA DEALER/SERVICE SHOP? THANKS
My friend says you can buy a device to clear the lights, but I doubt that would be cost-effective.
