Visitor Agreement.
chuckielaine - My friend also has a '02 Camry LE V6. I don't see he has any problem with his.
Thanks everyone!
Hope this helps!
http://www-odi.nhtsa.dot.gov/cars/problems/complain/complaintsear- ch.cfm
You can a list of TSBs for $10 from techinfo.toyota.com or free from the NHTS site but it is a terrible web site.
Another way is search as follows in GOOGLE and get the page from the ALLDATA.com site:
use the criteria: ALLDATA camry 2002 TSB V6 or 4 cyl
For 2002 CAMRY you see like 50 FIXES!!!! V6 is worse than 4 cyl.
Rather LEMONy !!!
If you search on Avalon it has 2 TSBs.
Ray
Reading these problem boards do make you paranoid though. A couple of questions.
1. Right rear end knock or thump. Am I imagining this or is a real noise others have experienced? I think I hear something on hard bumps from the right rear, but maybe I am just imagining it.
2. Clutch noise. This I definately hear and it seems to have just gotten worse. When the clutch is engaged or disengaged there is a metallic rattling sound. Anyone else heard this? I could swear this is a new sound, but then again I am paranoid.
as far as the clutch, mine dont' make any noise at all, the sales guy told me it has a hydraulic soft clutch. When i drive on highway and enagage in 5th gear, and accelerating hard around 45 to 55mph, my shift nob shakes or vibrate a little, but if i don't accelerating hard, or stepping on the clutch, it wont' shake, i brought it to the dealer, and the service manager said it is normal.
it is a little annoying cus sometime i rest my right hand the shift nob on highway, and it vibrates only in 5th gear.
i also have a 10 years old camry with 213,000 miles that has little vibration on shift nob on 3rd gear sometimes, but it doesn't bother me much as i dont' drive on 3rd gear for long time, and in a hot summer day, when i step on the clutch, it makes a little squeaking noise, but sound like it is from the join of the pedal/lever, i didnt' bother to put some wd40 on that piece of crap.
xbbuster: when the car is new, alignment is covered. I know this because my celica was delivered out of alignment and they corrected it for free. After 12K miles, they may consider it "normal wear" however.
ray: it seems that about 4 out of the 8 issues you listed are design elements that should have been apparent when you tested the car out? In fact, I would think rain would come into most cars if the window is open.
The engine is revving when it is stone cold, so it is normal for the engagement of 'drive' to be harder than when the car is warm...it is not a mechanical concern, if that is your fear.
Some people mistake pinging, or even the normal sound of the valvetrain, for knocking? Knocking is a really ugly little sound. If the engine is truly knocking, that is something that should be checked. It would be covered under warranty.
-Bob
Dealer found everything normal after test-driving it and he asked me to come over again to meet people from Toyota to discuss the issue. The gentleman from Toyota also felt that everything is functioning as designed.
Apart from this braking is not good, you have to push it hard to get the desired response. Does any of you experienced the same problem?. I specifically went for V6 to get that more speed but ended up being having this problem.
Most likely Toyota will split the cost with you for the repair. Your share will be around $150.00.
For acceleration, the Camry is much higher off the ground that made you felt slow moving.
Took it to toyota, and surprise, can't duplicate, sounds like it should, etc. I hunkered away defeated but it has since become even worse. I can duplicate the noise sitting still by leaving the car in neutral, and revving the engine to about 2000 rpm and pushing the clutch in and out. Sure the sound should change, since the clutch plate starts spinning when the clutch pedal is released, but the metalic rattling doesn't sound right. Going back to toyota this evening to demonstrate. So stay tuned. Anyone else with a 5speed having this problem. Do my described parking lot test and let me know. If I rev the engine higher, the noise gets louder.
I have a 2003 Camry SE. Every morning I have what appears to be moisture on my car windows. The problem is it is impossible to get off, It almost appears to have an oil to it. I've cleaned the windows inside and out with a good window cleaner. Any suggestions?
I have an '89 Camry (not too many miles though -- 111,000), and I've been having this one problem for a few years now. The car runs fine except in very humid conditions. It would usually start fine in the morning (although a few times it didn't), then I'd come to the first red light and the car would be idling normally, but when the light changes to green and I step on the gas, the engine dies. Usually, I can restart the car without too much difficulty, but the same thing would happen at the next light. I'd manage to limp this way to work (there is also some bucking) and after about an hour or so of "resting" in the parking lot the car starts fine and I have no more problems. We had very humid and stormy weather the last couple of weeks and I couldn't even start the car for five days until last night (yesterday being not as wet and humid as days before). Although it started, once I stepped on the gas it died again. I've taken the car to a few shops over the last few years, they would do some kind of tune-up (spark plugs, wires, etc), but the problem never really went away. Any ideas? Thanks.
This is based on your assertion that you only have this problem when it is stormy or humid.
1. Water pump.
2. Drive belt (pair)
3. Top seal
4. etc.
Should I go for it or just change the timing belt? Any suggestions? Many thanks!
Does your user manual really say 60K for timing belts. Honda was using 90K intervals for that model year. I find it hard to believe that Toyota would use lesser duration belts than Honda.
Thanks for your reply! I don't have too many experience on checking the drive belt, recently, when I start my car in morning (when car is cold), I heard some sound which is not very smooth from the drive belt area, when turning off the engine, look at the drive belt, I found there is a very minor thread there. But when using finger to push it, its tension seems to be OK. I'm not that sure if it needs to be adjusted or should be replaced, etc.
And also, when the car is started in the morning(car is cold), I noticed there is a smoke(not very heavy, but below average level, I think) from the exhausting pipe at the back, about 2 or 3 seconds later, the smoke is gone. The smoke is in light blue color, not sure if the top seal of the engine got a leaking problem there.
Anybody has similar experience will be appreciated to give comments here. Thanks!
It never cut off on me or started to smoke. On my way back to school from the airport, the car began to make a rattling noise and started to smoke from under the hood.
I pulled the car over and my brother noticed antifreeze pouring onto the ground. He lifted the hood after a few minutes and checked the oil and saw that it was okay.
However he did notice antifreeze spilling out from the "overflow".
After the car cooled I parked it at my sisters house which was about 5 minutes away from the expressway and let it sit over the weekend.
I took the car to a mechanic who could find nothing wrong with the car but changed the thermostat.
I took the car on the expressway after the repair had been made and the car began to overheat & antifreeze pouring onto the ground and the smell coming through the vents.
I drove the car back to the mechanic who swore he saw nothing wrong with the car and insisted on changing the "caps" that held the liquid down in the radiator.
He suggested that the bearings were worn.
I did not trust him so I had the car towed to GoodYear.
They are now saying the same thing. The diagnostic and leak tests are not indicating any problems and the engine is in great condition.
I suggested to them that the car is not overheating because they have not driven it to get the engine warmed.
What could be going wrong? Someone suggested the heating coil.
Please Help!
Please Help!
If fans don't work, could be bad thermosensor, fan switch or fan assy.
If fans work, hmmm, maybe clogged radiator.
good luck.
Shifts to all other gears seem to be fine. The steering wheel is locked when this happens and the brake is depressed.
Any ideas on what needs to be adjusted or fixed?
Yesterday the left rear tire ran flat while I was on the interstate. That was the final straw. Although I only have 12k miles on these tires, the car is at Big O Tire dealership today having Michelin MXV4 (v) energy tires installed on all four wheels.
Also, find another dealer to get a second opinion. Sounds like this dealer may be trying to just get deep into your wallet...
--18fan
