Visitor Agreement.
My ABS after heavy usage last winter, start to lock up and my dry braking distance increase at 35K.
* I bleed the brake system, and found metal shavings & dirty brake fluid. (Based on the advise of a mechanical engineer & he recommends bleeding brake system every 36K. This a normal practice in Europe on ABS brake system.)
*Found PCV valve clog & so I took the throttle body apart.
=> Found oil gum up & all over the intake system fwd to air filter housing.
It wasn't fun, but I cleaned it with a toothbrush & throttle cleaner.
Anybody know why this happens?
I have been using Mobil 1 since 5000K, and had a $10 Fram oil filter leak.(bad gasket) My auto tranny & differential fluid are also Mobil 1. My engine RMP 5000 to 5500 w/ auto tranny on acceleration.
Oil change every 5000 to 7000K. No sludge problems.
I am using K&N oil filter now. b/c I could apply safety wire to secure filter from spinning loose. This was a problem in the past.
The right front turn signal doens't work; the bulb is good and the fuses are good, but the indicator on my dash just blinks really fast. The rear indicator works.
Is there a relay somewhere in the wiring?
Try it - bulbs should run you no more than $5. Make sure you get the exact same type as a replacement as the DRL lights are different.
Deke
I fear there is a relay some where in the wiring that may be difficult to find.
Deke
I'll look into replacing it.
Anyone know what this service bulletin addresses and if the "enhancement" works? Any chance it resolves some of the hesitancy reported by some owners? Thanks.
Deke
My 96'camry le v6 was wonderful except some noise from the front wheels when i made a turn. So i had a mechanic to repair the cv axles,after that,the ABS indicator will come on while driving,(but the vehicle self-check is ok,the indicator will turn on then turn off).the mechanic told me that was just a sensor promble.I had the toyota dealer check it ,the dealer told me that :
the right front wheel speed sensor bolt is broken off in spindle,and wheel speed sensor will not fit in spindle hole.The dealer attempted to remove broken wheel speed sensor bolt from spondle ,bolt seized in spindle,he also found the speed sensor will not fit in hole ,while appears that spindle had been replaced at on time with part from recking yard,,possibly the part is incorrect for this year vehicle .I remembered that the mechanic did told me that he cann't remove the old bearing and went to another repair shop had it done and changed a new one .I think the mechanic did something wrong,and the dealer asked a huge bill (about $1000)to replace the whole stuff.what shall I do? can i ask the mechanic pay the bill ? at least ,a part of it,or let him repair the camry again(i dare not)? and can I drive the vehicle safely?
And ,last enening ,I had the vehicle oid changed,the guys who changed the oil had checked the signal / tail /brake /third brake /head lights,all are ok.But,i found the front side marker lights does not work,what wrong is that?
WAITING ONLINE-----
THX SO MUCH IN ADVANCE!!
I am the proud owner of an '04 V6 SE.
Unfortunately, my chair squeaks. Whenever I go over bumps, or brake or gas too hard, I can hear it. Part of the squeak is the leather rubbing up against the plastic base, but some of the sound I'm pretty sure if coming from inside the seat.
I have leather seats(not the sport leather), and the heated seats option as well. Is the chair itself broken? Or is this a design flaw?
My second question is on the VSC. I didn't add this as an option and was wondering if this is just code for the computer chip and can it be added now and if so...how much are they going to overcharge me.
I just returned from my Toyota dealer a few minutes ago. They are going to replace my transmission with a new one. Not sure whether to be happy or not. The car is only three weeks old. I feel like I am getting ripped. I bought a "NEW" car, now they are screwing around with the transmission. Not a real good feeling. I have pitched a fit, but will probably not get anywhere.
Ron
I understand your situation. This problem sounds like what was happening in the 03 Accords. If I were in your situation I would speak to the GM of the dealership and have them swap cars, they can easily re-sell that vehicle as a demo or use it as a service car/loaner, which I am sure is done all over. For a vehicle, especially Toyota's to have a defective tranny in less than three weeks is rare, mostly Honda had issues in the past. I would definitely recommend you making calls, follow-up's and be on their backs. No vehicle is perfect, but a major component as a tranny should last the life of the vehicle if maintained.
a 1-3 second hesitation, then the transmission "clunks"
into gear.
secondly, when driving downhill, if I remove foot
from accelerator, transmission downshifts with a
hard jerk, then whines and vibrates.
Dealer in Hollywood admits problems, states that the
torque converter is at fault, and that Toyota has
NO solution.
Please help.
The padding on the interior of the trunk lid is held in place with small black plastic rivets. They can be easily removed with a phillips screw driver (twist the inner circle while holding the outside edge). Remove one on each side. In it's place, screw in a 5/16" eye bolt, about 1-3 inches in length. The hole is the perfect size to grab the bolt threads, no additional nuts needed. Use an eye BOLT, not screw eye.
Not sure just how much force the bolts can withstand, but certainly enough to hold the lid down. Too bad Toyota didn't incorporate something initially.
thanks for the advice. will consider. lemon law
requires that I pay for the use of the vehicle to date.
that would mean a 6000 thousand dollar shortfall for me. is there a technical solution that you or anyone else may know of?
thanks for your responses.
nick
Does any know how to change the shift console bulb for a 2001 toyota camry CE?
Thanks in advance
dpchai
My 2001 Camry is hard to puch the gas pedal sometime, it looks like the cable stuck somewhere.
Any suggestions?
Thanks in advance
dpchai
Just spray some wd40 in it to see if it clears it up, which I liked the idea of, but as soon as he ran to get some, the shop supervisor came out and said that it was a bad idea, it might mess something up badly--so bring it in on another day when we can take it apart and look at it.
The thing that really bothers me is that the car was recalled for a drivers side air bag problem, so they replaced it (no noise prior to the replacement--and the techs taking the steering wheel apart). Now the car is way out of warranty, and I am tempted to just spray the wd40 myself. Any thoughts if it will mess anything up in there?
Anyone else experienced this?
Does anyone has similar problem?
Done job mate. Worked like a dream.
Thanks for confirming and your help.
a problem for my new 2004 Toyota camry limited edition LE model. I had this car for about two months, and had only driven 600 miles so far. I noticed that there were quite a lot of water leaking from the bottom of car after I drive for a while. I did not turn the AC or defrost on. What could be the problem ? If someone could give me some guides, I would appreciate it very much.
Thanks a lot.
Jay
Can someone tell me how could I change the bulbs myself since the shop wants to charge me $150.00 to get them replaced.
I've taken the battery cables for airbags but don't know where to take off the panels to get to the bulbs. Any comments will be much appreciated.
occasionally has some kind of jerking feeling when
I step on it. I just wonder anyone has similar
problem? Thanks for reply
Easy fix, there is a drain hose attached to condensor that (believe it or not) sometimes bugs climb into and block it. As a result, excess condensed water drained into (in my case) the passenger footwell. A quick shot with compressed air freed the hose and about a gallon of water came pouring out..
You are still under warranty..bring it in and they should sort it out in short order..
BTW, usually on Mazda 3 board - wife just bought one. Great car also.
I've opened two (2) fuse/relay boxes next to the battery. Neither seems to identify the radio fuse.
Thanks very much!
Is there another fuse box inside the cabin (kick panel etc?)
05:30 this morning off to the garage.
Searched again to no avail... looked on the passenger side - zip. Went back to the driver side, looked closer at the kick plate - zip.
Stared at the dash... Opened the courtesy drawer right above the parking brake... its filled with coins. Shined flashlight at the drawer... SAW RED and BLUE FUSES behind the drawer. BINGO
Fuses were hidden too well... gotta hand it to Toyota, neatly hidden and back of drawer had diagram.
Changed fuse, didn't have to sing on the way to work.
Thanks again.
Either way, my confidence in Toyota reputation of quality is eroding rapidly.
