Visitor Agreement.
When that happens, the leakage current is not high enough to blow the fuse but the battery can usually be completely drained in a few minutes.
Go into the fuse box in the engine compartment and pull the fuse to the fan and leave it out overnight. If the battery is not drained overnight then the fault is definitely in the fan circuit.
If the battery is still drained then the fault is in other circuits. Sequentially pull all fuses until you find one that saves the battery. That will be the faulty circuit. You can look around the part and its wiring. Most likely the problem is some chafed, pinched or exposed wires.
Dealers have computer diagostics that alledgedly can find the faulty circuits without having to physically remove any parts. The service techs would still have to do troubleshooting to isolate the faulty components. Finding shorted wires in a car chassisis a very tough job.
My local dealer charges $90 for that diagnostic before any estimate can be made! In the past they were unable to find intermittent shorts in my family's Celica.
I rear-ended my '97 Camry LE V6 into an Accord. The Accord was fine -- my car got the worst of it. It's going to need a whole new bumper, hood, headlight assemblys, and probably more.
Is there a way i can buy OEM parts, like the bumper and hood myself, rather than have the body shop do it and (I assume) mark up the cost to ridiculous levels? This is an out of pocket repair, not insurance.
If so, where would I look for these things?
thanks,
Matt
I would look on Ebay. I purchased a headlight for my '98 when a deer hit me, thus causing a dent in my hood and breaking the latches that hold the headlight in. It only cost me $20. Dealer is easily $70 or more! Personally, I would buy for both sides, because I am sure they have an "aged" look to them now. I also seen a fender for around $40 as well. As far as hoods go, I have only seen the aftermarket carbon fiber hoods that run $300! If you can't find a hood, then I would look at junkyards or go to the dealer, because shipping on one is EXPENSIVE.
Also, the bumper cover runs about $70, and I also seen bumpers for the rear for only about $100.
Good luck!
- Alex
I've read a number of complaints on these boards about clicks and rattles in the steering column of current Camrys so it seems likely that Toyota has a design issue with that particular part.
Or did your dealer indicate that this is a common problem in a variety of cars he sees?
Thanks for sharing that.
RAy
I haven't bought a new car in years and I get oil changes and fluid levels checked/ topped off every 3,000 miles at the cost of about $30.
Thanks for the help!
Toyota has had a service bulletin pertaining to this that dates back to July '04, but there is still no answer here. I know that this is exclusive to certain VIN's and was wondering if any of you fine folks have experienced similar episodes or have heard of this?
I am surprised that it took almost 9 months (it took them many months to have enough complaints to generate the service bulletin) to get this far and still Toyota hasn't figured out a fix. I am also wondering if other Solara's won't experience the same dilemma over the next few years.
B
The Camry has been one of our best trouble free autos we have ever owned.
And they also told me this problem is not normal, the representative personally saw it as the 2nd case of same problem.
The fuse box is right next to the battery.
There is a diagram in the cover which spells out which fuse controls which circuit.
The problem is most likely a defective brake light module, which is a circuit board inside a yellow plastic box, half the size of a cigarette pack, in the trunk, near the power antenna.
You can buy a used model from salvage yard for about $40. New module from dealer is about $150. You can plug it in without problem.
You can also take the circuit board out and look for cracked solder joints. Solder them back and it should work fine. That's what I did.
goodluck,
big harold
I suggest trouble shoot and test crank the engine at each stage in the following order:
1. Open the distributor cap. Inspect for any cracks, moisture etc...Replace the rotor ($5.00) then secure the cap. Crank the engine.
2. Use a sharp tool to mark the position of the distributor's 2 mounting screws relative to its mounting flanges, as the distributor's mounting position affects firing timing.
Remove the distributor. Check for open/damaged wires around the ignition coil inside the distributor. The coil could look fine on the outside but have burned wires inside. The stores can probably measure the inductance to find out whether it's still good or not. Replace the coil ($40) if necessary.
3. Remove and test the ignition module in another 92 Camry, or just replace the module ($150). The module is silver, the size of half cigarette pack, mounted on the left strut housing in the engine bay. Crank the engine.
The replacement parts are sold at auto part stores.
Try it. Remove one brake bulb and see whether the other works!
