Buick park Avenue Problems
mcrrt
I have a 93 Park Ave. Ultra with 85K miles that seems to have a mind of it's own. While I'm at work, the trunk will open by itself, the radio will turn on, and sometimes it will unlock itself. I have had this problem in the past 3 months and it seems to be getting worst. Anybody have any suggestions???
That is ALL over a span of 8 years and nearly 200,000 miles! Pretty amazing in my opinion. (My maintenance on my car was not nearly as often as recomended..and it still held up.)
-At a low speed the engine has a whine.
-I have taken the car to the dealership, where it was purchased, 11 times for repair.
On 10 out of the 11 Times there was, according to them, something wrong.
-On the last time (before I was going to arbitrate through the Better Business Bureau)after 3 minutes they found that nothing was wrong with the car, but General Motors had already sent parts to stop the whine. Nothing Worked.
When the car had 8000 miles on it I asked what the trade in value would be for another park avenue. They told me only 15,000 less than half of what I payed for it. I told them no and to get the whine out. (there is not only a whine but the lights dim way down also). After two new alternators, a change of the battery and parts sent from GM the dealership said it was in GM's hands and thaey can't fix it. I had no choice but to arbitrate under the lemmon law. I just used the wrong way to arbitrate. The BBB has good intentions, but they need a better system for selecting thier arbitraters. In october 2000 I called and told GM that I was going to trade cars and I asked them if they would give a break in price on a 2001 for the trouble I had with my 1999 Park Avenue. The answer was no, and I told them I was driving my last GM car after 50 years of owning nothing but GM cars. THIS DESIGN PROBLEM SHOULD BE FIXED OR THE CAR REPLACED!!!
Thanks for the advice concerning air conditioning and other helpful hints . Keep them coming.
I will be deleting your post in about 1 week, just so that others won't get the wrong idea.
bnormann
Maintenance & Repair Message Board
Buick never pings.
I talked to my dealer, and he said they could change the PROM (whatever that is) and this would change the shifting of the transmission. I'm not sure I want this.
Does anybody out there know what I am talking about?
There is no need for me to restate all the problems I've had with this machine as I've seen it time and again in Edmunds' web sites... two years ago a response told me to get rid of it as his father had one and took a loss to forestall further expensive repairs... This is not completely confined to GM as tons of our domestic autos are falling apart while still in their prime...
Downshifts are smooth and normal, but the whole car will shudder on each upshift through all four gears. Additionally, when cruising along in overdrive and sliding the selector into neutral, there is an immediate resistance lasting for a few seconds, similar feeling to dropping a gear at too high a speed. It is as if there is some foreign resistance, possibly the torque converter lock-up not completely releasing? I just don't know. Other than these terribly annoying symptoms, it doesn't appear to impair the performance of the car in any noticeable way.
I have taken the car to my independant mechanic and to the Buick dealer several times. Nobody can find a problem with the car, but of course, the problem is intermittent and has never occurred when it's in the shop.
Any suggestions or similar experiences?
66000 miles on it.
My recently purchased '92 Park Ave Ultra is accumulating water in the trunk tire well at an alarming rate every time it rains. The rear deck lid gasket seems to be intact, but I cannot be certain of the two gaskets in the tail lamp assembly. The last rain storm resulted in approximately 3/4 of an inch of rain in the bottom of the wheel well.
Except for the Jacques Cousteau trunk experience, it's been a fantastic car. I'd like to upgrade the existing supercharger with a '94 or '95 supercharger and throttle body assembly to pick up an additional 20 hp, but am having trouble locating the assy. All tips and tricks are welcome.
My guess is that GM designed it to use "disposable" alternator since they make it so easy to replace under the hood. It took me less than 20 minutes in the parking lot at Pep Boys to yank out the old, exchange at the counter, and install the new.
But as for solving the cause of the problem, I have no ideas.
After a while it comes around but does´I run perfectly anyway.
The diagnostic code is 44 (oxygen sensor-lean exhaust indicate) or (sensor circuit-lean exhaust)
If I keep it on 2000-3000 RPM it runs OK for a while but then it goes back to being "uneasy".
If I don´ touch the gas at all it just doesn´t´ run well.
Does anybody have an idea of what the problem is?
Annette
Any advice?
other people having the same problem. They have contacted GM for a fix. If you have this noise
please tell me what you did to correct it. Johnny
models. GM has choose not to do a thing. I would be interesting in joining a class action suite
are anything to get this problem solved. I am in the process of getting enough docmentation
to file under the Lemon Law. I can not believe the owners of cars with this problem are not
raising all kinds of stink. Wake up owners GM is giving us the shaft. Raise Hell!
new design. So it's out there now. Ask your dealer to order it. (I have had a great relationship with my dealer and while I thought of the Lemon Law and was told by several people to pursue it, I did not. I waited for this latest design. So far it works.)
