2018 Wrangler JK Unlimited lease figures
artvandalay123artvandalay123 Member Posts: 1
edited January 2019 in Jeep
I'm looking for residual and money factor for a 2018 Jeep Wrangler JK Unlimited Sport S 36 mo, both 10K and 12K. I'm rather new to leasing, what do you mean when you say standard money factor? This is for North Carolina.
«1
  • kyfdxkyfdx Moderator Posts: 273,099
    Standard MF and 73%/72% residual
    The standard money factor from Chrysler Capital varies by month and model, but tends to be in the .00190-.00220 range. We don't know what it is exactly, this month, though.
  • edmundsusernjedmundsusernj Member Posts: 49
    Can you please provide residuals for 2018 Wrangler JK Unlimited Altitude, Freedom and Willys Wheeler W? Is the MF the same as listed above? Are there any +/- to the residual if auto vs. standard trans, radio 430 NAV, etc.? Looking at 24 and 36 months either 12k or 10k if it helps to increase residual. State NJ and zip code 08854. Thank you for your expertise!
  • MichaellMichaell Moderator Posts: 269,413
    edited January 2018
    12K numbers; add 1% for 10K
    Standard MF and 67% / 64% (Altitude), 74% / 71% (Freedom or Willys Wheeler)
    Individual options or packages, or transmission choice, do not change the numbers
    36 months is certainly the better deal
  • rdan2422rdan2422 Member Posts: 37
    edited February 2018
    looking for mf and residual on a wrangler limited, 4wd, altitude package, 36 month, 10k miles. Zip code is 28117
    thank you
    thank you
    2-door or 4-door?
    And, is this a JK as the topic title suggests?
    thank you
    2-door or 4-door? And, is this a JK as the topic title suggests?
    4dr, sorry new to jeeps so not what jk is
    rdan2422 said:
    thank you
    2-door or 4-door?
    JK is the "old" Wrangler; JL is the "brand new" Wrangler that was introduced just a few weeks ago.
    thank you
    Got it, jk is the model I am looking at
    rdan2422 said:
    rdan2422 said:
    thank you
    2-door or 4-door?
    Standard MF and 65% residual for 36/10.
    (looks like the Standard MF is .00193, this month, on this model)
    rdan2422 said:
    rdan2422 said:
    thank you
    2-door or 4-door?
    Standard MF and 65%
  • thebrig12thebrig12 Member Posts: 3
    I'm looking for residual and money factor for a 2018 Jeep Wrangler JK Unlimited Rubicon, Rubicon Recon and Golden Eagle. Zip 94577
    48 months, 10k miles. Thank you.
    Standard MF and 63% (Rubicon, Rubicon Recon) or 69% (Golden Eagle)
  • mparrenomparreno Member Posts: 29
    Good Morning Gentlemen,
    Could I please get the MF and RV for 2018 Wranger Unlimited JK Willy’s Wheeler W?
    Zip 32955
    36/10K
    36/12K
    thank you!
    Zip 32955
    36/10K
    36/12K
    thank you!
    Standard MF and 74%/73% residual
    Zip 32955
    36/10K
    36/12K
    thank you!
    Thank you for your response. Standard MF, is that .00193? Thanks again.
    Zip 32955
    36/10K
    36/12K
    thank you!
    It was last month... we haven't seen it for this month.
    It's likely to be close to that, though.
    Zip 32955
    36/10K
    36/12K
    thank you!
    It was last month... we haven't seen it for this month. It's likely to be close to that, though.
    I’m also looking into the Altitude model: 36/10K. Is that one still at 65% RV?
    mparreno said:
    Zip 32955
    36/10K
    36/12K
    thank you!
    66% for 36/10
    Good Morning again guys. I’m back at it again trying to figure out which model to go with. The dealer just showed me a Sahara that I also like.
    Whats the RV for a Sahara 36/10K-12K please?
    JKU Sahara
    66%/65% residual for 36 mo, 10K/12K
  • jwill4lifejwill4life Member Posts: 9
    Can I get the RV and MF for a 2018 wrangler jk unlimited sport 4x4? 36/15 I'm located in miami fl. Can I get the numbers for a Golden eagle, willys wheeler, and S models
    Standard MF
    71% residual on all of those trims.
  • toetrktoetrk Member Posts: 22
    Hello.  Looking for MF and RV on a 2018 2 door Willy’s.  24&36 10k/yr.   thank you.
    JK or JL?
    JK. sorry. and thanks again
    Standard MF and 70%/65% residual for 24/36 months.
  • el_shelbyel_shelby Member Posts: 16
    edited March 2018
    Hello, I was quoted a MF of .00266 and RV of 71% at 15k a year on a 2018 Jeep JKU Willys. Looking back through the post I see the RV is spot on, but is the quoted MF of .00266 correct? That translates to ~6.4% if my math is correct.
    The standard MF is in play this month. We don't know the exact rate used, but Chrysler Capital allows the dealer to mark it up by .00042.
    Might want to check with other dealers to see what rate they use.
  • benjeepfanbenjeepfan Member Posts: 3
    Hi there. I’m wondering what you have for the RV for a JKU Sahara 39/10. I was quoted 62% RV and .002028 (standard Chrysler Capital rate starting 7/6/18). However, I was told the RV was 63% last month. It appears the JK RV is dropping a lot since the JL came out. Thanks so much for your help!
    Unfortunately, we do not yet have the new numbers for the Wrangler.
    Residuals tend to drop as the year goes on, regardless of when the new models come out.
    The Sahara is the trim with the worst residuals on the Wrangler, however.
    edited July 2018
    Unfortunately, we do not yet have the new numbers for the Wrangler. Residuals tend to drop as the year goes on, regardless of when the new models come out. The Sahara is the trim with the worst residuals on the Wrangler, however.
    Thanks so much. Yes, it certainly seemed like the Sahara has had the lowest RV based on the past posts. When you get the numbers, I’d love to see the difference between a Sport S JKU 39/10 and a Sahara JKU 39/10. :smile: I like the look of the Sport S better (the rims, the plastic fenders I like for some reason, and the non-accented grill). But no one around here in Maryland has a Sport S JKU with the heated seats, side airbags and the sidestep.
    Standard MF and 69%/63% residual for SportS/Sahara for 39/10
  • FigsyFigsy Member Posts: 4
    Can you provide me with the residual for JK 36/15k yr and what you he MF is?
    zip 08533
    zip 08533
    Which trim?
    2-door or Unlimited?
  • ryfriryfri Member Posts: 32
    edited August 2018
    I'm looking for the residual and MF for a 2018 JKU Sport S
    36/12000 and 48/12000
    33426 zip
    33426 zip
    Standard MF and 70% / 65%
    33426 zip
    Appreciate it- does a Golden Eagle JKU change the RV at all?
    33426 zip
    No
  • ParisCatParisCat Member Posts: 6
    Hello. I'm looking for RV and MF for 2018 JKU Sport S, 36/10 or 36/12, zip 60056 (Chicago area). Thanks!
  • andyneedsacarandyneedsacar Member Posts: 21
    edited September 2018
    May I have the mf and residual for JK Rubicon 4x4 2-door for 02474? 36 months/12k Thank you.
    Standard MF and 58% residual
  • benkiafanbenkiafan Member Posts: 14
    Hi, I'm back again. Thanks for your help and info.
    Please let me know the September RV% for 2018 JKU Sport S at 36/10. Much appreciated! :)
    Standard MF and 68% residual
    I was curious what the RV% for a 2018 JKU Sport S is at 39/10 for zip 20781. Also, is there a way to find out what the standard Sept. MF is with Chrysler Capital at Tier 1? Many, many thanks! B)
    66% residual
    The one report we've had this month is .00209
    It's always somewhere around there.
    Thanks so much! They are telling me .00220 but I guess that's close enough. ;) You guys are lease masters! Because this info is so hard for people to get, this forum helps me and many others conduct their lease purchases with valuable knowledge to get a fair deal. My family has been in the market for 3 cars this year and the MF/RV figures have helped me assess what I can afford and what is reasonable. Have a great day!
    If they are quoting .00220, I wouldn't doubt it. That's very close to the last number we saw.
  • FricfracfrankFricfracfrank Member Posts: 49
    Can you provide residual and mf for wrangler JK v6 automatic 12/36 & 12/48 for 22134. Thanks
    Unlimited model?
    Which trim?
