2019 Subaru Impreza Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 274,099
edited August 2018 in Subaru
Ask your 2019 Impreza lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2019 Subaru Impreza here.
«13456714
  • mikegrahamjrmikegrahamjr Member Posts: 9
    Let me be the first.
    Looking for mf/resid for 2019 Impreza Limited 5-dr in 15090 (PA)
    12k / 36 mo
    Doesnt look like any incentives now
  • kyfdxkyfdx Moderator Posts: 274,099
    12k / 36 mo
    .00055 MF and 63% residual
  • grazinghippograzinghippo Member Posts: 7
    Hi:
    I would like the residual and MF for premium and limited 36/10 for Los Angeles - 90043. This is 2019 Impreza hatchback, CVT transmission. Thank you!
    Hi:
    Premium: .00150 MF and 67% residual
    Limited: .00055 MF and 64% residual
  • AutzenMemberAutzenMember Member Posts: 5
    I am comparing the '18 and '19 to see which leases better, so I will pose the same question I asked in the '18 forum here for the '19 models:
    MF and Residual for:
    98607 Zip Code
    '19 Impreza 4 door and 5 door, CVT on both
    1. Base
    2. Premium
    3. Sport
    Incentives available? (I know Costco has $500 available on top of everything else until Sept. 4)
    Do MF and Res change if Eyesight is added to either Prem or Sport versions?
    Thank you so much!
  • MichaellMichaell Moderator Posts: 269,865
    98607 Zip Code
    1. Base
    2. Premium
    3. Sport
    Thank you so much!
    I'll give you the same answer here, that I gave you there. :sunglasses:
    Please narrow your choices down to the top two.
    98607 Zip Code
    1. Base
    2. Premium
    3. Sport
    Thank you so much!
    Ok...let's narrow it down to the Base and Premium, both CVT, both Sedans. 36/12
    98607 Zip Code
    1. Base
    2. Premium
    3. Sport
    Thank you so much!
    Base - .00120 and 64%
    Prem - .00105 and 63%
  • JeffmorgJeffmorg Member Posts: 5
    Please post MF and residual for 2019 Impreza base model CVT sedan and hatch 36/10k for zip 11746. Thanks!
    Sedan - .00120 and 65%
    Hatch - .00170 and 68%
  • guddzyguddzy Member Posts: 12
    Could you please let me know current MF, Residual % and any incentives for 2019 2.0i Impreza sedan in base, premium, and sport trims. zip: 43215, 36mo/12K and 36mo/10k. Thanks!
    Premium - .00105 and 63%
    Sport - .00140 and 64%
  • robi77robi77 Member Posts: 44
    What's the money factor and residual value for 2019 and 2018 Subaru Impreza Hatchback (Automatic Transmission) at 10,000 miles/year for zip code 11362? Thank you.
    What trim level?
    2018 Impreza lease thread is here:
    https://forums.edmunds.com/discussion/47609/subaru/impreza/2018-subaru-impreza-lease-deals-and-prices#latest
    What's the money factor and residual value for 2019 and 2018 Subaru Impreza 2.0i Premium Hatchback (Automatic Transmission) at 10,000 miles/year for zip code 11362? Thank you.
    What lease term?
    And, note the link to the 2018 Impreza thread in the post above.
    2019
  • davester200davester200 Member Posts: 20
    Can you please provide the MF and RV as well as any lease cash for a 2019 subaru imprreza sport hatchback and limited hatchback  CVT trans 10/36 33437
    Sport - .00140 and 65%
    Limited - .00055 and 64%
  • aigochamalohaigochamaloh Member Posts: 138
    Another inquiry, TIA! 36/12 on base hatch 5MT, trying to compare to the 2018 I have numbers for already. 91784 zip.
  • schecke32schecke32 Member Posts: 7
    Could I please see MF and residual for the 2019 Subaru Impreza Limited Hatchback in 10530 using 36mos/12k please? TIA!
  • vwcarsmasalexvwcarsmasalex Member Posts: 8
    edited September 2018
    Could I get the RV and MF for an Impreza 2.0i with CVT for 36mos/10k? Zip code is 53703.
  • stevenlee4stevenlee4 Member Posts: 29
    Hello, could I get MF and residual for 2019 Impreza, base model, automatic, both 4- and 5-door, for 24/10 and 36/10, in CA? Thanks
    .00095 and 62%
    .00040 and 62%
    Sedan or Hatch?
    Skip the 24 month term; the numbers are lousy.
    Sedan - .00070 and 62%
    Hatch - .00140 and 66%
    Thanks Michaell, appreciate the advice on the 24 mo. term; we may need to do short term as this is business lease, is there a competing make/model we should look at that offers good 24 mo terms (Corolla, Civic, Mazda3)? I can post on those individual boards if easier.
  • Hello, could someone provide me with the MF/RV for the 2019 Subaru Impreza 2.0i (sedan/CVT) for 36/10 in zip code 48371?
    The Corolla or Civic would lease better for the 24 month term
    Base: .00070 MF and 62% residual
  • wilkeway59wilkeway59 Member Posts: 14
    Hello. Can I please have the MF/Residual for the 2019 Subaru Impreza Sport Sedan 5spd. 12k/yr 24 and 36 month? PA (18064). Also any incentives in this area?
    .00070 MF and 60% residual
    No support for 24 month leases from Subaru
  • lesseefairlesseefair Member Posts: 132
    May I please have the MF, RV and any incentives for:
    2019 "base" Impreza 2.0i 5-door (hatchback)
    Automatic transmission
    36 months/12,000 mi/yr
    Zip code: 53092
    Zip code: 53092
    .00140 MF and 65% residual
    No incentives
  • latsyrclatsyrc Member Posts: 4
    Could you please post MF, residual and incentives (based on 36/10K) for 2019 Impreza 2.0i Limited hatchback (CVT)?
    Zip code: 27510
    Zip code: 27510
    .00040 MF and 63% residual
  • lesseefair53092lesseefair53092 Member Posts: 4
    May I please have the MF and RV (and any incentives) for:
    2019 Impreza 2.0i (base)
    Hatchback
    CVT
    36mos/12k
    zip code 53092
    And how long are the current rates in effect? (Through October?)
  • RajivRajiv Member Posts: 4
    I would like the residual and MF for premium and limited. This is for 12k Miles and 36 months. This is 2019 Impreza sedan, CVT transmission. Thank you!
    Hatchback
    CVT
    36mos/12k
    zip code 53092
    Through Oct 31st
    LTD: .00040 MF and 60% residual
    Prem: .00055 MF and 60% residual
  • Proxi666Proxi666 Member Posts: 4
    Hello. Can I please get some information on the MF and RV for a 15k mile/36 month Lease at zip code 98133 on the following:
    2019 Subaru Impreza 5-door 2.0i base manual
    2019 Subaru Impreza 5-door 2.0i Sport manual
    What ZIP?
    Base: .00095 MF and 60% residual
    Sport: .00130 MF and 62% residual
  • alang22alang22 Member Posts: 11
    Looking for MF & residual for a 2019 Impreza 5-Door, Sport, Manual Trans. 10k miles / 36 months. ZIP 60076
    .00130 and 65%
  • Kirby125Kirby125 Member Posts: 6
    MF/RV and incentives:
    2019 Impreza 2.0i Base 5-door (hatchback)
    Automatic
    24 or 36 months
    10,000 mi/yr
    Zip code: 92116
    Automatic
    24 or 36 months
    10,000 mi/yr
    Zip code: 92116
    Skip the 24 month term.
    36/10 - .00140 and 66%
  • schticlesschticles Member Posts: 10
    My I please have MF, RV, and any incentives for a 2019 premium hatchback in 60555?
    36/12 and 36/15
